Question about Hotpoint BWM12 Front Load Washer
I cant open the door on the filter pump of my hotpoint wf541.
I wondered if there is some form of locking device on it.It will turn so far then stops.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 100 Answers
It's probably because there's something blocking it like coins etc
or socks!
its only a plastic frame behind the bit you turn so it may break if you force it.
you could free it by turning it back and forth untill it opens but it may be worth getting a new filter cover to replace it before you do in case it does break.
Posted on Jan 27, 2009
How to troubleshoot central locking.
Wondering if the door lock mechanisms needs greasing
like some form of resistance to movement may put the power locking out of kilter ..
May 15, 2016 | Mitsubishi Lancer Cars & Trucks
Unable to turn the ignition switch to the "lock"
mannual or auto- auto try playing with the ****** shifter the has a locking cable that stops the key cylender form completly turning to the relese slot
Jul 20, 2011 | 1988 Jeep Cherokee
Hotpointt FFA80 freezer door kept opening on its own. noted that ice had formed and was pushing drawers against door. cover removed from coils and found solid with ice. left to defrost but when plugged...
Does the light inside the fridge come on? if it does then you are getting power. If not you are not getting primary voltage. As far as resets or cut outs there is three things that can stop the power to the compressor 1 the cold control (thermostat you set to raise or lower temp) 2 defrost control that is suppose to cycle and put the fridge into the defrost cycle about one time every 24 hours. 3 the over load heat activated cut off that is a small round device usually on the side of the compressor (the big black round can that is in the bottom of the fridge) Since ice formed I would check the defrost control first. It is a timer that should advance slowly on its own but usually can be turned by hand to advance to the defrost position. the defrost timer is usually at the bottom of the fridge and many times can be seen from the front of the fridge when the "kick plate" or bottom grate is removed. if you can find the little knob on the defrost timer try to turn it to the right (clock wise) and see if anything changes. Since the ice formed either the heat element that defrosts the coils or the defrost control has probably stopped working.
Apr 22, 2011 | Refrigerators
My steering bumps when i turn the wheel. im wondering if it needs grease? also the power steering squeals when you turn it too far either way
turning to full lock will cause the pas clutch to squeel,the pumping feeling is the pump starting to go(wait a few months then replace.)it will get heavier and heavier.....
Jul 14, 2010 | 1998 Toyota Camry
The ignition in the vehicle i want to purchase was punched out and i am having problems starting the car. there is an anti theft device installed and i was wondering if that would have anything to do with...
you can remove the ignition switch (the electrical part) from the ignition lock (the key and lock part} and put a screwdriver in the switch part, and turn it like it was the key. as far as the anti theft part goes it may be an aftermarket alarm system installed on the starter circuit.
if that is the case it usually only keeps it from turning over not running.
so you may be able to just bypass a relay,
Look for a wire that someone cut in half up by the switch, and attached there own wire to both ends. just remove there wires and reattach, or temperarily jumper the factory wire back together. see if it turns over.
Nov 04, 2009 | 1990 Nissan Maxima
Car door lock freezes when cold
put a drop of engine oil down the barrel ,works wonders
Mar 12, 2009 | 2000 Volkswagen Beetle
Control Locked
push and hold in far right button on conrtol panel( look closly you see control lock) hold for 3 secs and it will turn off
Mar 02, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Hotpoint BWM12 Front Load Washer Logo
481 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
