Calypso GVW9959K Top Load Washer model 110.22062101 It has stopped draining I took out the water pump on the bottom but I cannot find the filter to check it. How do I take it apart?
  • 15,935 Answers
The inlet screen is in the inlet hose on the pump.
There is no easy accessible filter on this model.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 14, 2010
Calypso washer won't drain
It sounds like you may have something stuck in the pump...try and locate the pump(normaly at the bottom of machine)and unscrew the aware that the machine may still have water in it....once you unscrew the cover,have a look and a feel inside...there may be a coin or other object stoppint the pump from turning...remove any foreighn object...replace the screw on cover and try to drain the water again....this should solve your problem.
Jan 17, 2013 | Whirlpool Calypso GVW9959K Top Load Washer
Washer stops when Ld comes up on display before final spin, but washer drains fine.
ld flashes if it takes longer than 5 min to pump out water to the point where the operating pressure switch resets.check the drain line for kinks,check drain for blockage,check pump operation.
Jan 19, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
FL code washer not draining
“FL” (Over Fill) flashes
The washer will beep every 10 seconds with no time-out. The
pump will cycle one half minute on, one half minute off, until
the overfill switch is reset or power is discontinued to the unit.
Press STOP/CANCEL to clear the display. Shut off the water
faucets to the inlet hoses if water continues to flow.
Here is the complete manual.
Jan 08, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Water pump out??
The washer filled with too much water, causing a switch to trip. Then everything stops. It tries to drain during FL but if it can't drain, the washer powers down.Choose Drain & Spin to let the washer drain. Then you have to take the washer apart. Fix the problem. I personally can't tell you what to do because I don't own a Calypso.
Bad Pump
High Water Flow
Other Causes
Jul 30, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
My calypso washes spins but do not drain the water out what could be the cause
the DRAIN MOTOR PUMP is clogged , need to open washer , disconnect the drain hoses , take out the little motor pump , and remove any debris and lint collected , hope this helps, AJ
Jul 14, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Starts to fill then STOPS
I just had the same problem with mine. The error message I got was F1. My problem was a bound up pump(I believe it was a piece of yarn or rug). Anyways, I drained the water and took the bottom plate off to access the pump. A good pair of needle nose pliers, a long flathead scerwdriver and a little patience to remove the material. I reassembled and have tested it. Works great. Be sure to check for leaks during test, just in case..........
May 03, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool calypso model GVW9959K-0 leaking during rinse cycle
hi my name is joyce
Sounds like your pump is leaking. if it is leaking when you are on a spin cycle.
now if it is stuck on f1 cycle and wont drain unplug and let stay unpluged for 60 seconds and replug and see if you can restart on drain and spin cycle. let me know if I can help with any other problems.
Feb 06, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
What does ld mean?
ld mean long, drain. the machine was unable to drain out water in a given amount of time, calypso is imfamous for collecting lint in the pump assy, id open that up and have a look
May 02, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Washing Machines Logo
47 people viewed this question
Top Washing Machines Experts
