I am looking for a electric fireplace blower motor # YJ61/200 120v 21w E327392 SHENZHEN ZHAOLI
2 Suggested Answers
SOURCE: I have an electric fire
I just repaired ours and it is quite simple,if it is the same type.First remove the front cover frame, then with a screw driver repove the clip at the top of glass,ease out the glass and lift up to remove.Remove the plastic logs and you look inside and you will see your burnt out lights,remove them, buy the same type and replace them, normally they are standard candleobra light that you can buy at any hardware store.
Posted on Nov 12, 2010
When I turn my electric fireplace on, the fan blows for about 30 seconds and then quits blowing.
How to revive/lubricate your fireplace blower fan or any ...
? 26:34
www.youtube.com/watch?v=JbX_XtKS1p0
Jan 30, 2013 - Uploaded by varietytubechan My fireplace blower fan had stopped working. ... This is demonstrated on a FK4, GFK4, R7-RB74K (Electric Motor Warehouse), HB-RB74K ...
5 Electric Portable Fireplace Repair Tips ' DoItYourself.com
www.doityourself.com/stry/5-electric-portable-fireplace-repair-tips
Electric portable fireplaces are a convenient way to warm a room, barn, patio, ... If the light or coloring of the fireplace is not working, you may need to replace the ... is not working as well as it should, you may need to inspect and clean the fan.
Oct 26, 2015 | Dryers
Elco fireplace blower wont work
If your blower/fan blows air into a "box" with tubes that conduct heated air out through the screen, that assembly may have failed. I had one that burned out and had to be replaced.
Dec 03, 2013 | Leisure HOMEPRIDE Electric Fireplace...
I have a china electric fireplace model ND 20-B the blower motor needs to be replaced how hard is this to do and where do i find one
Not a whole lot of information about the fireplace/free standing stove you have. Other than it's a direct import from China and the specs, which didn't list a blower. http://cixijasun.en.made-in-china.com/product/NeCQduwOPHhD/China-Electric-Fireplace-ND-20B-.html
With only the little information about the company, there's not much chance in finding the part (blower) you're looking for. However, 98% of all the electric fireplaces and stoves, like yours are China imports and are made almost identically, but have some replacement parts available. The solution is, finding a similar unit to yours by another manufacturer, that uses the same size and type blower. Most use what are called squirrel cage blowers rated at 120 cfm and is rated for 230 volts. Based on the voltage requirement, I feel pretty sure, it was never sold in the USA. With some online research, you may can find one.
Hope this helped you and thanks for choosing FixYa.
Sep 20, 2011 | Heating & Cooling
We have an electric fireplace - the blower fan is now not working - was working fine - but just stopped
Don't despair, it's very common with electric fireplace/heaters. They weren't built to run long periods of time and most fail within one year.
A couple of things may have caused your problem. These fans get clogged with dust, lint and/or pet hair and is puts a strain on their continued operation. If you're fortunate enough to still have your Owners Manual, it will show/tell you how to access the fan motor and blades under the lower portion of the firebox. Clean the fan and motor using a vacuum cleaner, that has a hose and a brush attachment. Attempt this only after you have unplugged the fireplace from the wall. If you have a can of compressed air with a straw nozzle (like you clean your computer with) use that to blow out the nooks and crannies. Reassemble the bottom of the firebox, plug in the cord and give it a try.
If that didn't solve your problem, either the fan motor is bad or the switch to turn the fan on is bad.
Those parts you'll have to purchase directly from Dimplex USA.
Hope this helps you solve the problem.
Feb 10, 2011 | ACE Dimplex (r) Compact Electric Fireplace...
The fireplace blower does not work therefore there is no or very little heat from my dimplex elect fireplace---thanks
This is a constant problem for ALL electric fireplaces with heaters. Either the Owners Manual fails to the manufacturer not telling you that the heating elements need routine cleaning, because they are sucking in household air to heat it and send it back out, So whatever is float in your household air (dust, lint & pet hair) near the floor goes into it, clogs it up and causes the heating element to overheat and fail. Or customers who have purchased these units don't read the Owners Manual.
These units, no matter who the manufacturer is were not designed to heat for long periods of time. In fact the heater element doesn't produce much more heat that a blow drier on high heat.
The heater and the blower and are in the lower compartment of the firebox. If you can access it, you can clean it with a shop vac and a brush attachment on the end of the hose. Be sure to unplug the fireplace from the wall outlet before attempting this. If cleaning it doesn't help, the blower motor will have to be replaced. You can order one from Dimplex USA.
Feb 06, 2011 | ACE Dimplex (r) Compact Electric Fireplace...
Need to replace noisy fan motor on Dimplex 6901470100 Not sure how to gett access to blower. Thanks
If you no longer have your Owners Manual go to the Dimplex home page and click on the Help tab. You should be able to download the Owners Manual for your model fireplace there in a pdf format. Also look for a Trouble Shooting tab.
Jan 31, 2011 | ACE Dimplex (r) Compact Electric Fireplace...
Gas fireplace question
Simulated gas log fireplaces usually don't have a blower of any type. They depend on the radiant and conducted heat much like there was a real wood fire in the firebox. Look in the manual to determine if a blower was included, but I doubt it because of risk that CO would be propelled into the living space.
Jan 15, 2009 | Leisure HOMEPRIDE Electric Fireplace...
Blower motor on wood burner only turns slow.
go to thehandyhandyman.com he will be glad to help you
Dec 26, 2008 | Kitchen Appliances - Others
Chicagao electric fireplace heater doesn't work
MY HEATER NOT WORKING,BLOWER AND LIGHT COME ON NO HEAT
Oct 25, 2008 | Heating & Cooling
Heating & Cooling Logo
116 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
