Question about Dishwashers
Have a teel pump motor runs but want pump water
    Genius:
  • Dishwashers Master
  • 1,669 Answers
Either the impeller is not on the shaft tightly or there is something clogged in the intake or outflow pipe.
Posted on Jan 23, 2013
Motor runs but does not pump water
Is there water over the pump housing? Is intake on the bottom clear of debris? This may sound stupid, but is hose frozen or blocked?
Mar 28, 2014 | Utilitech 0.33-HP Thermoplastic...
Holding water
Good Day,
Your washing machine is fully automatic?
the washing cycle is normal?
if yes do the same maybe it will help you.
for the fully automatic washing machine mostly have drain pump, please check the filter of your drain pump, how? remove the cup of your drain pump like a ordinary cup, screw it clock wise or counter clock wise.
Remove drain pump filter and clean it, some hair pins, cotton buds or coins or any small item that coz of clog up.
if your washing machine dont have drain pump ,but fully automatic check the drain motor if running or not? how? open the back cover for top loader washing machine only, select spin cycle and press start to see the drain motor running? the drain motor is like a small box with small wire to pull the lever of the drain to remove water inside, if the motor running or pull the lever of the water pipe but water still inside the washing machine, remove the drain cup or cover and clean it or check if have coin or cloth inside that coz of clog or water stuck,
if the drain pump or drain motor is weak this is will cause and long time draining or totally not running the drain pump or drain motor and its cause of totally stop the cycle of washing machine in rinse time or spin time, because all fully automatic washing machine, after washing cycle the drain pump or drain motor must be on, to remove water before start the next cycle. rinse or spin cycle.
Nov 02, 2013 | Washing Machines
Pool pump not pumping
A few things to look at-
  • Did you fill the pump pot with water?
  • Check to make sure that the pot lid o-ring is in place.
  • Verify that your plumbing is sound and has no suction leak.
  • Check water level in pool.
  • Make sure the voltage is correct. Many pumps come pre-wired for 220v. If you have 110v supplying the motor it will run at half speed. There is a diagram on the side of the motor showing how to convert to 110V. Make sure that your supply is 110v before converting the motor. If you switch the motor to run on 110v and hook it up to 220v it will ruin the motor instantly.
Feb 19, 2013 | A O Smith Motors A O Smith 1hp 115/230v Ur...
Submersible sump pump leaking oil. are repair parts available. Pump is Teel 1p914
If it is leaking oil then the case is cracked and it would be as mush to fix it as to replace it.
If it is fairly new the take it back for a replacement if not you can get parts but the case is not one of them.
The problem is that if oil is getting out water is getting in and the pump will fail very soon.
Mar 01, 2011 | Plumbing
The Pump overheated
IS IT'S A STA RITE CHANCES ARE THE PUMP CAN BE SAVED. IT WILL NEED A NEW IMPELLER,SHAFT SEAL AND DIFFUSER. THESE ARE TUFF PUMPS. BRING IT TO YOUR LOCAL POOL PUMP MOTOR REPAIR GUY .. USE YOUR ZIP-CODE IN YOUR SEARCH ..PUMP REPAIR IS THE GREEN THING TO DO AND IT SAVES YOU MONEY ! . PLEASE VOTE GUYS-N-GALS
May 05, 2010 | A.O. Smith SQ1102 Pool Pump Motor
Teel pump M#IP985B will not pump, motor runs good, it will pump if suction hose is higher than inlet, but not below inlet, what could be wrong?
Typically, there is foreing material in the veins of the pump, I suggest that you disassemble the pump and inspect the impeller, and remove foreign material.
Sep 17, 2009 | Plumbing
I removed my pump because water would not drain. i plugged up and pump still does not move, but winding sound is present. Does the motor require a load to run? And does this mean the pump is bad?
Hi, water pump doesn't require load to run, check motor (coi)l with ohm meter (multi-tester), check for continuity, good job, removing pump and cleaning it, it's a commom problem with washing machine. it's possible your pump motor burnt out, two things you can do, to check pump, (1) two wires that you remove from pump motor, put volt meter,put power to machine, be careful, check for correct voltage, if voltage is present, and pump didn't work, then water pump motor, burnt out (2) remove water pump, make extension cord, plug directly to receptacle, if it's good, it will run, if it didn't run, replace it, good luck
Aug 08, 2009 | Whirlpool LSR6332K Top Load Washer
Last cycle water will not emptying
Your pump is more than likely shot!
Defective Lid Switch
Check lid switch for proper operation. Check the switch for continuity. If it is found to be open, replace the switch assembly.
Defective Water Pump
If the motor is running and water is not pumping it could be a defective water pump. Ensure the tub to pump water hose is clear. If so, replace the pump.
Defective Motor
If the motor is not running, the pump will not work. Most washing machine use a reversible motor and it is possible for the machine to agitate and not spin or drain.
Please leave a goo rating
Dec 01, 2008 | Frigidaire ATF6000ES Front Load Washer
Dishwashers Logo
46 people viewed this question
Top Dishwashers Experts
