Question about Dell Studio XPS 13 (dydwgn3_4) PC Notebook
Dell xps 13 beeps constantly
Powering up, all I get is a blue screen Powering up while holding down F2 causes a series of beeps and the blue screen Holding or tapping F8 results only in blue screen; Holding Fn+F1 does not work
  • Dell Master
  • 7,627 Answers
If your are tapping the F key repeatedly it will beep after the first one. If you don't tap, does it still beep? Try remove ALL Media DVD,CD,USB. shutting down, unplug, remove battery, plug in, reboot.Press and hold the F-8, Take a look at this : http://en.community.dell.com/owners-club/xps/f/3681/t/19278287.aspx
Posted on Jan 23, 2013
  • 50 Answers
SOURCE: DELL Latitude D510
unmountable boot volume means that either your system is corrupted, your boot.ini is damaged, or your boot sector is corrupt. Try this:
"You can boot to the XP cd and when you see the Welcome to setup press the letter R
You will get a dos prompt
Then type "chkdsk /p" without the quotes and hit enter
When that is done type "fixboot" and hit enter
"Y" and enter at the prompt
Then type "exit" and hit enter
The system will now reboot into Windows"
Posted on Nov 19, 2007
Geekman
  • 32281 Answers
SOURCE: Dell Inspiron 1501 laptop screen will not work.
If you hear the hard drive spinning and you think Windows is working but you can't see an image then :-
You could have a defective screen - a defective inverter or a CCFL lamp or simply the video cable needs reseating. After reseating the video cable and the problem is still there then :-
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display or appear black.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Posted on May 21, 2009
ArmenianTech
  • 24 Answers
SOURCE: Dell XPS M2010 Starting Problems
Ok. Here is the thing. I hope everybody sold their problem, but I will just post for others who may experience the same thing.
1st believe it or not : there is nothing wrong with motherboard, as when you press the power button, computer will shut down. with defective motherboard it will just continue running untill you will unplug it.
2nd believe it or not : it can not be battery issue or hard drive issue, because it does not make any scenes in any way. I have to agree that hard drive on the right is semi-correct answer.
REASON:
IT is video card that messing up everything. And it is located right under right hard drive. That's why when somebody removed hard drive he/she accidentally corrected the cooling system of video card , which returned M2010 to live.
CONFIRMATION:
1. First remove the top cover from the computer. There are 2 sides the plastic things. If you look at the back of your laptop you will see 2 small holes , one on every edge of the back. You stick something there it will loose the front cover.
2. unscrew all the screws hat have ">" or "<" signs next to them. there are something about 15-16 screws in total: this will allow you to open the cover under wich you can find the motherboard and stuff. When you open the cover pry to start the computer, and you will see that fans will not start even after 1-2 minutes after you hit the power button.
3. Remove the right hard drive and under it you will find screws A, B, C, D (silver) and also 1,2,3,4 (black) unscrew the black ones first, them remove video card with the cooling mechanism. now try to turn on the machine. you can see that after like 20-30 seconds fans start working which means that motherboard is fine and it was the video card that was giving problems.
SOLUTION:
1. I am not sure what causes the issue but I have fixed it this way:
uscrew silver screws and disconnect cooling part from the actual video card.
2. clean both, video card and cooling system not touching sky blue foam ICs. That staff is needed to cool the chips on the video card.
3. let them dry for an hour or so after cleening, than apply some Thermal compound, thermal paste and re assemble the video card with the cooling staff. (mek sure no screw is loose or something)
4. put it back and turn on the computer. If it works , whell .. it works now :)
if not then either you levae some liquid on the video card or screws are loose. try to play a bit with screws. but my personal suggestion is just to wait for a minute or two until video card gets hot and fixes liquid problems itself :)
Try it. It worked for me perfectly ...
Posted on Oct 08, 2009
  • 266 Answers
SOURCE: my dell xps m1530 laptop seems to be on but nothing on screen
Remove the battery and power cable from the system and press the power button for about 5 seconds, then plug in the charger and start the laptop. it will work. shutdown it and put the battery back and start once again . now you can see its working
Posted on Feb 12, 2010
  • 3940 Answers
SOURCE: How do I boot this Dell Inspiron 1440 in Safe Mode?
F8 at boot
or
MSCONFIG, Boot.ini tab, check safeboot (You will need undo this to boot in normal mode)
Posted on Apr 22, 2010
Dell xps touch sreen just blinking blue light but blank screen
Sounds like it went to sleep due to low battery power. May be time for a new battery if it isn't holding charge well.
Plug it into the wall and push the power button once. It may come back on. If not...
Hold the power button down until the machine shuts off completely. If that doesn't work, remove the battery.
Feb 04, 2015 | Dell Computers & Internet
Dell xps 9100 constant beeps upon startup
Beep Codes
Your computer might emit a series of beeps
during start-up if the monitor cannot display
errors or problems. The following repetitive
beep codes help you troubleshoot problems
with your computer.
NOTE: To replace parts, see the Service
Manual on the Dell Support website at
support.dell.com.
One beep - BIOS ROM checksum failure;
possible motherboard failure
Contact Dell (see "Contacting Dell" on page 53).
Two beeps - No RAM detected
Remove the memory modules, reinstall
one module and restart the computer. If
the computer starts normally, reinstall anadditional module. Continue until you have
identified a faulty module or reinstalled all
modules without an error.
If available, install memory modules of the
same type in your computer.
Three beeps - Possible motherboard failure
Contact Dell (see "Contacting Dell' on page 53).
Four beeps - RAM read/write failure
Ensure that no special memory module/
memory connector placement requirements
exist (see the Service Manual on the Dell
Support website at support.dell.com).
Verify that the memory modules that you are
installing are compatible with your computer.
Five beeps - Real Time Clock failure
Replace the battery.
Six beeps - Video BIOS test failure
May 22, 2014 | Dell Studio Xps 9100 Desktop Computer
4 beeps on dell xps 13
4 beeps on startup is a RAM error. Locate the ram stick(s), remove and re-seat them. Make sure you do this with the machine powered off and the battery removed!!!
Feb 18, 2014 | Dell XPS 1340 Notebook
Dell XPS 1530 will not start up black screen. Tried holding down the Fn, F8 & on buttons, but still wont start
Hi David,
The fact you have no screen to get into the BIOS menu, indicates a big problem, and the culprit is the car power adapter.
Never, ever, use anything but the recommended adapter to power your unit, else disaster, followed by an agonising death for your PC/Laptop.
Your cars amperage is not compatible with your units amperage, unless you are using recommended DELL adapter for the car.
I hope you have not pickled your unit, but if so, you'll know better next time.
Cheers,
Peter
Feb 20, 2013 | Dell XPS M1530, M 1530, PP28L Series...
Dell 8400 blue screen xoooooo24
if you are getting a series of beeps when powering up, please indicate how many.
Mar 22, 2009 | Dell Dimension 8400 PC Desktop
Unable to reboot CPU
when its powering on let it get a little ways in then hold the power on off button until it just shuts off. Then boot it on and see if it gives you a safe boot option if it does select it. Then do a system restore to before this problem started. Hopefully this will restore the drivers.
Jan 16, 2009 | Dell XPS 200 PC Desktop
I have a Dell XPS 400 with Microsoft XP. It recently shut down with a Blue screen stating that a recently installed driver is possibly bad. I was able to restart the CPU after a while and with in a few...
don't reboot instead reinstall the windows may solve this problem.i recommend ur xps laptop use windows vista ultimate because its have great performance i heard.
Jan 15, 2009 | Dell XPS 200 PC Desktop
Dell Lattitude D620 is...
Do you mean reset?
Restart the computer and as soon as you see the dell logo tap the F2 key repaetedly. once you are on the blue BIOS screen use the down arrow key to go to maintenance and hit enter. go to load defaults and select continue. hit esc then save and exit.
Hope this helps. =)
Oct 09, 2008 | Dell Latitude D600 Notebook
Toshiba Satellite 1400
To Access the Bios Setup Utility Here Is A List Of Key Commands And The Make/Model They Are For..
Acer - Aspire, Power, Veriton, Extensa, Ferrari, TravelMate, Altos
  • Press Del or F2 immediately after powering on.
  • The BIOS on the Acer Altos 600 server uses the Ctrl+Alt+Esc key and the F1 key for advanced options.
  • Older Acer computers may use also use the F1 or Ctrl+Alt+Esc keys to access BIOS.
Compaq - Presario, Prolinea, Deskpro, Systempro, Portable
  • Press F10 while the cursor in the top right corner of the screen is blinking.
  • Older Compaq computers may use the F1, F2, F10, or Del key to give access to BIOS.
Dell - XPS, Dimension, Inspiron, Latitude. OptiPlex, Precision, Vostro
  • Press F2 when the Dell logo appears. Press every few seconds until the message Entering Setup appears.
  • Older Dell desktops and laptops may instead use Ctrl+Alt+Enter or Del to enter BIOS.
  • Older Dell laptops may use Fn+Esc or Fn+F1.
eMachines - eMonster, eTower, eOne, S-Series, T-Series
  • Press Tab or Del while the eMachine logo displays on screen.
  • Other eMachine computers may use F2 to enter BIOS.
Fujitsu - LifeBook, Esprimo, Amilo, Tablet, DeskPower
  • Press F2 once the Fujitsu logo appears.
Gateway - DX, FX, One, GM, GT, GX, Profile, Astro
  • Press the F1 key repeatedly after restarting the computer.
  • Some older Gateway computers use F2 to access the BIOS Setup utility.
Hewlett-Packard (HP) - Pavilion, TouchSmart, Vectra, OmniBook, Tablet
  • Press the F1 key after restarting the computer.
  • HP Tablet PCs may use F10 or F12.
  • Other HP computers may allow access to BIOS using the F2 or Esc keys.
IBM - PC, XT, AT
  • Press F1 immediately after powering on the computer.
  • Older IBM computers (including some laptops) may utilize the F2 key for BIOS entry.
Lenovo (formerly IBM) - ThinkPad, IdeaPad, 3000 Series, ThinkCentre, ThinkStation
  • Press F1 or F2 after powering on the computer.
  • Older Lenovo products allow access to BIOS using Ctrl+Alt+F3, Ctrl+Alt+Ins, or Fn+F1.
Micron (MPC Computers) - ClientPro, TransPort
  • Press F1, F2 or Del immediately after powering on the PC.
NEC - PowerMate, Versa, W-Series
  • Press F2 to enter the BIOS Setup.
Packard Bell - 8900 Series, 9000 Series, Pulsar, Platinum, EasyNote, imedia, iextreme
  • Press F1, F2, or Del to enter BIOS.
Sharp - Notebook Laptops, Actius UltraLite
  • Press F2 after the computer starts.
  • Some very old Sharp PCs require a Setup Diagnostics Disk to access BIOS.
Shuttle - Glamor G-Series, D'vo, Prima P2-Series, Workstation, X Mini XPC, Surveillance
  • Press F2 or Del on startup.
Sony - VAIO, PCG-Series, VGN-Series
  • Press F1, F2 or F3 after turning on the computer.
Toshiba - Portégé, Satellite, Tecra
  • Press F1 or Esc after powering on to access BIOS.
The following companies are either closed for business or no longer manufacture or support mainstream computers systems so verifying the following BIOS access information is nearly impossible. I have included what I could dig up for anyone who might be interested:
ARI / ALR / AST (Advantage) - Press the Ctrl+Alt+Esc or Ctrl+Alt+Del keys.
Cybermax - Press the Esc key.
Tandon - Press the Ctrl+Shift+Esc keys.
Good Luck and Hope it helps...
http://www.wnycomputerpro.com
Jun 12, 2008 | Toshiba Satellite A35-S159 Notebook
Dell Studio XPS 13 (dydwgn3_4) PC Notebook Logo
568 people viewed this question
Alun Cox
