Question about Dishwashers
Dishwasher not working
Hi my tricity bendix dishwasher is getting stuck mid cycle and just keeps washing until you manually move the dial forward or switch it off. it also does not seem to be heating up.thanks
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 100 Answers
Sounds like the heater is not working. it's washing while waiting for it to heat to correct temperature.
if you are not electrically minded i'd get an engineer out or ring one for a quote.
Posted on Jan 27, 2009
Tricity bendix washing machine won't work on any of the settings
Hi, mine is the same - it will literally go on forever and it wont seem to ever 'finish' like it wont drain properly either - is it the 800 model? quite and old machine with a button you push in and twist to select the cycle and pull out to turn it on? its just awful it wont give an indication whether its completed any cycle! did you get yours fixed?
Feb 25, 2016 | Tricity Bendix Washing Machines
Hi there, I have a Tricity bendix dishwasher, approximately ten years old. the other night in the middle of the wash cycle, it went pop, tripped the mains at the board and there was a smell of burning in...
You know, I think the best thing to do would be to replace the dishwasher. It is ten years old and a new one would be more energy efficient and you would save money in the long run.
Jun 29, 2017 | Tricity Bendix Dishwashers
Kenmore Heavy Duty Series 70 washing machine gets stuck in cycle.
Either your timing motor has broken or the gears that it drives are stripped. The timing motor is easy to replace but if the gears are stripped you will need a whole new dial assembly.
May 09, 2017 | Kenmore Washing Machines
Dishwasher stuck in cycle
Hi
I have a similar problem, did you find the cause of the problem?
Geoff
Jan 13, 2010 | Dishwashers
MAINS ELECTRICITY FUSE TRIPS WHEN DISHWASHER TURNED ON
Hi, I think you will need to check the heater or the wash pump, as these are the first things to energised. IOf yo could give me some more information then i could tell you where to after these things have been tested ok!
Get back to me......
Jan 10, 2009 | Tricity Bendix 24 in. DH102 Free-standing...
My Tricity Bendix won't work
Check out the water inlet solenoid valve if this is clicking then it is probably the water level pressure switch which appears to be controling the flow of water mechanicaly dependent on whether the water is high enough in the machine and therefore giving enough pressure to close the switch .This may be stuck closed.
Oct 17, 2007 | Tricity Bendix 24 in. DH102 Free-standing...
Dishwasher stuck in cycle tricity bendix DH 104
if this is stopping early in the cycle, the timer has just moved a little before it stops then it is highly likely to be a heater fault, check the element for open circuit, this can be accessed from under the machine, work with safety,
Sep 16, 2007 | Tricity Bendix AW1000W Front Load Washer
Tricity Bendix AW1400W Won't spin or agitate.
this could either b the motor brushes or the timer check the brushes first they r mounted on either side of the motor unplug the machine b4 u start good luck
Aug 26, 2007 | Tricity Bendix AW1400W Front Load Washer
My tricity bendix washing machine flashing and beeping end light
Hi, we had something similar happen just before christmas. Our machine seemed to finish a cycle and started making beeping noise with end light flashing. Then when I switched it back on to do another load it just started beeping with end light flashing no matter what cycle was selected. Engineer has been out and advised that it is a fault with the motherboard so has ordered another one. Hope this is of some help. Machine was tricity bendix aw1400w.
Dec 14, 2006 | Tricity Bendix AW1400W Front Load Washer
Dishwashers Logo
248 people viewed this question
Top Dishwashers Experts
