Question about Emerson InSinkErator W-152 Hot Water Heater
Leaking water tank on Insinkerator hot water dispenser
Leaking water tank
  • Emerson Master
  • 5,245 Answers
Jan 2013
1) If the tank is leaking, then Replace with new dispenser.
http://waterheatertimer.org/How-to-install-under-counter-water-heater.html
2) Add comment and attach photo of leak.
Posted on Jan 23, 2013
  • 4 Answers
SOURCE: Insinkerator instant hot water tank leaking
When you cut the pipe it has to be cut square or it will leak . Try recutting the end of the pipe and then reinserting it. If this doesn't work then the only thing you can do is replace the fitting.
Posted on Dec 16, 2008
  • 92 Answers
SOURCE: Can you clean the tank on an Emerson Hot 1 model hot water dispen
if it was me i would try to get vinegar into it let it sit for a while and flush it out
Posted on Feb 05, 2009
  • 659 Answers
SOURCE: insinkerator hot water heater takes a long time to dispense water
It may have mineral deposit buildup on the inside. You will need to consult your maintenance manual to see how to flush the unit and clear it of deposits. You can also contact Insinkerator for the information as well. You can use vinegar to clean it just like you would a coffee pot. Take the inlet supply off and using a funnel pour the vinegar in and turn the unit on.
Posted on Apr 03, 2009
gary1121
  • 332 Answers
SOURCE: can a insinkerator hot1 be hooked into a low
there shouldn't be a proble it actually would work less if you are getting low pressure,, but how did you come to the conclusion that it is low pressure,, do yo have a guage, you should not loose that much pressure on any fixture
Posted on Jun 06, 2009
mrhotandcold
  • 248 Answers
SOURCE: brownish water from insinkerator
sometimes with well supply you are better to have two filters one outside easy access then another as supply enters your property best of luck
Posted on Nov 10, 2009
Instant hot water tap - hot steam but delay and no hot water
This unit is set way too hot. The steam is pressuring the water out of the unit.
Feb 18, 2014 | Emerson InSinkErator C1300 Chrome...
In sink erator instant hot tank leaking at the bottom of the tank
Must replace tank.
Insinkerator stainless steel tank does not have anode rod to protect against depleted tank wall.
Copy following link for tips installing under counter heater, and manuals for several different brands
Add comment as needed and fixya will not send me email to reply with more detail
Jul 15, 2013 | Water Heaters
Insinkerator hot tap faq
Check all the connections, take the cover off after you shut down the power. If the connectors are not leaking, replace it
May 04, 2013 | In-Sink-Erator InSinkErator HC-WAVESN-SS...
I have an insinkerator hot water dispenser with stainless steel tank, and the tank is now leaking. I'm wondering if it can be fixed or needs to be replaced
Replace water heater if tank wall is leaking.
These things have short warranty period.
Stainless steel will theoretically last longer, but steel tank water heaters have replaceable anode rod to prevent rust-out.
http://waterheatertimer.org/Replace-anode-rod.html
Be sure to recycle the old metal.
http://waterheatertimer.org/How-to-recycle-water-heater.html
Oct 29, 2012 | Emerson InSinkErator C1300 Chrome...
Hi, my insinkerator hot water dispenser is leaking from the bottom screw. It is a couple of years old. Moder SST
My unit is 3 1.2 tears old. It started to delay the flowing of hot water. Today I held the lever down until hot water came out but I noticed water leaking from inside the unit. I figured that the tank failed, and since it was over 3 years old I decided to open it up. What I found was that there is a plastic tube at the top of the unit that was very discolored and brittle which developed a crack. when I touched it it completely severed. I called the Insinkerator hotline at 1800-558-5700 and they told me that opening the unit voids the warranty. I said that it appears to be out of warranty and I needed just the plastic tube for repair. The per on on the phone said that as a one time courtesy that a new unit would be shipped to me free of charge and that I could install it myself or they will have a tech do it. I opted to do it myself. Hope this helps
Nov 05, 2010 | Emerson InSinkErator W-152 Point-Of-Use...
Feb 05, 2009 | Emerson InSinkErator C1300 Chrome...
Dec 16, 2008 | Emerson InSinkErator W-152 Point-Of-Use...
InSinkErator Instant Hot Water Faucet leaking from heater unit model #GN1100
Make sure that there is no leaks traveling down the hoses or at the connections on the top. The tanks can leak, if you have the Stainless Steel tank the following information applies - Stainless Steel Tank: 3 years, with an extended service plan available when installed by an InSinkErator Pro Circle™ plumber. I you product is under warranty I believe that you can call the number that is printed on the tank and literature.
Dec 04, 2008 | Mountain Plumbing Mountain The "Little...
Emerson InSinkErator W-152 Hot Water Heater Logo
452 people viewed this question
Top Emerson Water Heaters Experts
Gil Shultz
ray gallant
Are you an Emerson Water Heater Expert? Answer questions, earn points and help others
