Question about Motorola Computers & Internet
Blackberry torch 9860 with red x on the battery symbol , phone not charging
Blackberry 9860 dead...Red Led light blinking for few seconds and icon x shows on battery symbol, Battery not charging, attimes it will show yellow thunder light in the battery symbol as if its chargin but after awhile the symbol with Red X crossing the battery will appear, its not booting only showing Red Led light and after turns to X crossing the battery. i ve tried to charge for many hour but still showing the X symbol. also i ve used MCP ,CFI method by cleaning with wipe and Nuke all in vain. also try Fast Installer and JLCommand they r couldnt get inside my device. All the OS ve been installing r from the carrier so didnt need to delete the Vendor....after everything it will stuck at 'reconnecting JVM'...I Used Apploader from Program file and also Desktop Manager stop at the same place..'reconnecting JVM'... I ve searched diff forum for solution but everyone keep sayin almost everything and so far i ve not beaten Reconnecting JVM.... Dont knw what might probably be WRONG?,,The device just exceed the warrantty given and moreover i left where i bought the phone.,,so ve to look for solution on my own. Is there anyone out that knw how to get out of this... Really need your assistance..? Everything was perfect with the phone until a notice/advert poped up on my device asking me to Upgrade my DEVICE to latest , which i clicked on and asked me the time i wanted for the upgrading to start,,,blablabla..Everything went well and my fone was upgraded and worked for a day but at night my battery was down as usual and after like 45/50minutes that i wanted to charge my battery. ICON WITH RED X SYMBOL APPEARS ON THE BATTERY SYMBOL and since then i couldnt power it on. Anybody that knows what i can do , your advice, solution ll be highly appreciated, Thank you
  • Sleetaino Jan 24, 2013
    Thanks for all your responses...I ve tried all these, removing battery and put it back, even i whiped d phone with MCP nuke and wipe, before re installing and i used OS from the carrier of my device, so i didn't remove vendor but everything to no avail, The phone still hanging during installation aty reconnecting JVM..is there anything else i can do?
ganeshkhatri
  • 173 Answers
SOURCE: Blackberry red light then reboots!
This behavior indicates that no applications are installed on the BlackBerry smartphone.
CAUSE: The Application Loader tool in BlackBerry® Desktop Manager removed existing
applications from the BlackBerry smartphone, but failed to install new applications.
RESOLUTION:-
1) Verify that BlackBerry Device Software is installed on the computer.
2) If the BlackBerry smartphone is connected to a laptop computer using a docking station,disconnect the docking station from the laptop computer and connect the BlackBerry smartphone directly to the laptop computer.
3) If a third-party application uses the same communications port as the BlackBerry Desktop Software, close the third-party application.
4) If you use a USB adapter to connect the BlackBerry smartphone to a serial port, temporarily connect the BlackBerry smartphone to a USB port.
5) In the BlackBerry Desktop Manager, double-click Application Loader.
6) Follow the Application Loader tool prompts to install the BlackBerry Device Software.
Posted on Nov 19, 2009
tamilselvan
  • 45 Answers
SOURCE: My phone will not show it charging and will not turn on, red light flashing
dear
you have mentioned that ur phone is charging and not getting on. that means ON\OFF path is having problem .due to dry solder of ON\OFF switch its happening. please resolder it and then check it
Posted on Nov 07, 2007
  • 13 Answers
SOURCE: jvm error 547 blackberry 8320
try running app loader again but before you connect your phone up to the computer pull the battery out, then connect the phone, then put the battery back in. A lot of times it will force the connection to get established and then you should be able to run app loader.
Posted on Nov 19, 2008
nightlisa
  • 102 Answers
SOURCE: blackberry curve won't turn on...
Wipe it to start over. Sometimes when you change or add something like a THEME or a download it HOSES the BB completely. So delete what was on there and don't download a theme or any other wacky add-on.
To Sanitize or Clear out all the information in a Blackberry Device
Scroll to select the OPTIONS icon and press [Trackwheel] to select.
Scroll to select SECURITY and press [Trackwheel] to select.
On some units you may have to select GENERAL SETTINGS before getting the next menu.
Press [Trackwheel] again to access the Menu screen for the security.
Scroll to select the WIPE HANDHELD and press [Trackwheel] to select.
Scroll UP to select CONTINUE and press [Trackwheel] to select.
Type blackberry on keyboard to confirm the action press <-| key.
System responds with ERASING INFORMATION.
Posted on Mar 25, 2009
fleshgear
  • 541 Answers
SOURCE: Blackberry 8900 wont turn on
the problem could be in charger or battery,
if the problem is in charger,try to charge it wit your laptop
or else try to charge your iphone battery with a battery charger,
if it doest work try a different battery
Posted on Aug 10, 2009
My blacberry freezes when rebooting. What sould I do to fix that.
Read and maybe try some suggestions by other users of Torch 9860.
Good Luck
Jan 19, 2015 | RIM BlackBerry Torch 9860
Tip
Colour full BlackBerry ..If you are a Blackberry user.You must read this
In BlackBerry LED indicator blinks in different colors to deliver different notifications to the user:
Blinking RED: The LED indicator blinks red whenever you have incoming or waiting communication messages on your phone - new email, new call or missed
call,
Blinking GREEN: this is Coverage Indicator light. This lets you know you are connected to a network.
Blinking BLUE:If your phone is connected to a Bluetooth device, such as a Bluetooth headset it blinks blue.
Blinking YELLOW: A blinking yellow light means it is time to charge your BlackBerry
on Dec 15, 2009 | Cell Phones
Bb bold wont charge
Welcome to the BlackBerry Support Community Forums.
Have you tried plugging the BlackBerry is different outlets or tried a different USB cord?
Does the BlackBerry show a charging symbol or is the LED flashing red or green?
I look forward to your reply.
Feb 24, 2012 | RIM BlackBerry Bold 9000 Smartphone
Hi i have a 8220 and red light is blinking on charging. I have checked very possible thing even the charger but cant get around pls help! thanks
Please don't worry this is caused because of various reasons.The lights explains what could be the problem
Orange and Yellow lights mean no defects in the mobile.Orange is phone battery is very low.Yellow is for boot up..
Red light means-You have power management problem.
You have to understand why it is being caused..
1)Due to dead battery.The phone will charge but you phone battery will not get charged it acts like it is getting charged.Behind the scene it cant store the charge.
2)Due to charger is not working properly no charge in the battery.
So you have replace this accordingly..
Please try this some time phone booting may be stopped,
This is not a solution when the battery is dead or fully down....
Sometimes The boot cycle of the phone is stopped.You have to start it.Remove the battery and place it again and press the red 'end' button continuously until the red light flashing stays on.Press green button' call' button and hold the red button...Now press these two buttons alternatively until you see hour glass symbol.Now when you see hour glass wait and see the phone booting....
Please do rate the solution if the issue is resolved or post a comment for further assistance.
thank you for using fixya have a nice day:-)
Aug 01, 2010 | RIM BlackBerry Pearl Flip 8220 Cellular...
Hi my blackberry pearl has a blinking red light and it wont turn on
LED indicator keeps on blinking (red light) but no screen its water dep i rehot the phone 100%ok done
Dec 07, 2009 | RIM BlackBerry Pearl Smartphone
Red led light is flashing while charging and it won't turn on
I just called Verizon Wireless who said that the phone may need to be charged completely for a few hours. Try taking the battery out and putting it back on as well.
May 02, 2009 | RIM BlackBerry Storm 9530 Smartphone
The battery on my blackberry 8310 went dead. I
ok so what u basically do is just keep the charger in the usb port. then take the battery out then plug it back in. this totally works!
Apr 01, 2009 | RIM Blackberry 8310 8320 8330 Curve 8100...
Blackberry will not turn on, I just get a red light
this happened with my first blackberry and it never turned back on guess what softwar glitch it was never goig to work again so i got a new one the second one started having issues within a month and eventually got to the point where i couldnt wifi it would turn off on me for no reason tell me i had no service when i should have hang up on people freeze and simply sucked took it in to get it fixed guess what another software glitch that one went to blackberry heaven and i got another one this one is only 1 month old has all updated software and hey guess what no issues at all i suppose every phone has bugs in it to begin with look the aple iphone blew up when it first came out until they fixed the issues with it.
if your on a plan ur under warranty with blackberry take it back and there policy basically replaces the phone.
good luck
Jul 30, 2008 | RIM BlackBerry Pearl 8100
Computers & Internet Logo
759 people viewed this question
Top Motorola Computers & Internet Experts
Prashant M
Prashant M
Are you a Motorola Computer and Internet Expert? Answer questions, earn points and help others
