Question about Air Tools & Compressors
Motomaster air compressor 058-7949-6
Regulator
2 Suggested Answers
  • 103 Answers
SOURCE: how do you regulate the air pressure on FUWA AIRBRUSH COMPRESSOR
There is usually a regulator where the air coupling is. if not,just add one with some simple fittings and a regulator you can find at home depot in tool dept.
Posted on Jul 16, 2009
Where can I buy a Makita Mac2400 air compressor regulator
Makita parts are available at WWW.toolpartsdirect.com A small universal regulator may also work if the fittings match-up. When using a universal regulator make sure that the regulator fits thru the hole in the panel or just adjust the hole size. Universal regulator costs about 20 dollars. Good luck
Mar 03, 2015 | Makita & Sealed Mac2400 Big Bore 2.5 Hp...
What does ocp mean on the 3000 motomaster power inverter
Unit is overheating.
1. Check fans are running. and unit is in a cool place where air can flow freely.
2. If fans not working try using an external fan to see if the OCP error goes way.
Reduce the load on the outlets (Disconnect some stuff i possible)
Apr 04, 2014 | Eliminator MotoMaster Mobile Power...
Will not allow me to regulate air. compressor kicks on and builds to max pressure.
All air compressors build pressure in the tank(s) to their maximum allowed by the pressure switch. The regulator only controls the pressure of the air available at the outlet. That's why they have two pressure guages, one for tank pressure and one for outlet pressure. If you cannot control the air pressure at the outlet then you have a defective/broken regulator. Dewalt does not make the regulator as a seperate part for their air compressors, you have to buy the entire manifold which includes a regulator to fix this problem.
Jan 31, 2011 | Dewalt 2 Hp 4 GAL Air Compressor
Compressor won't build psi above 30,is this typical of the regulator or pump? the compressor is a 3 gal craftman about 1 yr old.
sounds like the regulator is faulty, normal running air should reach 110 psi, this will allow you to run tools...
Jan 30, 2010 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
How do you regulate the air pressure on FUWA AIRBRUSH COMPRESSOR
Jul 16, 2009 | Fuwa Fuwa Kutsuwa Fuwa Air Compressor MA...
Air compressor pressure not regulating
Usually you cannot adjust the cut out pressure of the tank/motor itself, this is why they have regulators, which regulates the pressure flowing down the air lines (regulators like these dont regulate actual tank pressure cutout). To regulate air flow using the regulator knob, you actually have to have air flowing through the hose while you make the regulator/pressure adjustments as regulators regulate pressure DOWNSTREAM from the actual regulator itself.. so air flowing through is a must. Attach an air blower or something similar and let air start flowing through the hose. Now turn your regulator knob in the "-" direction to decrease regulated pressure. It is best to bring pressure all the way down to "0" first, then open the regulator up (by turning to the "+" side) and pressure will rise until you get to the desired pressure needed for the air tool in use. The tank pressure will still be between 80-125 PSI as the motor regulates and keeps the pressure in the tank between these values automatically, but your line/hose air flow pressure will remain at the regulated pressure (say 40 PSI or whatever you set using the regulator knob).
Hope that helps and makes sense.
Please rate this solution on FixYa!
Jun 18, 2009 | Makita Factory-Reconditioned 2.5 HP Air...
Air compressor regulator installatlion
The arrow denotes direction of air flow; It should point towards the air hose connection(s)
Mar 11, 2009 | Craftsman Air Tools & Compressors
Air Tools & Compressors Logo
505 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
