Question about Eiki LC-X1100 Multimedia Projector
Can get any power on on my eiki lcx 1100 projector
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 84 Answers
Thermal fuse, located under the lamp might be activated, open lampdoor and push carefully the little black pin. If it gives a click it was
activated due overheating. If not, replace 1uF, 2.2. uF and 220 uF capacitors in primary part of the power supply, it takes some work to get the pcb out of this model !!
Posted on Apr 17, 2014
4 Suggested Answers
siobens 510
  • 6 Answers
SOURCE: eiki projector daed
check first the fuse
Posted on Feb 05, 2009
projdoc
  • 2237 Answers
SOURCE: in few minutes after turn on the projector (Eiki Lc-xnb4m) ..
are any of the leds flashing? could be overheating. blow out the dust with canned air. if the lamp is old, it could be that it needs to be replaced. if the fans go out immediately as well, it could be the power supply.
Posted on Nov 18, 2009
SOURCE: No power to Eiki EIP-2500 projector
Look for buldging capacitors, or capacitors with black on the tops of them (like they got hot). Bad caps have left me dead in the water. Also look at all of your transistors (the ones with 3 prongs at the bottome (emitter collector base) look to see if some of them look burt or melted. Some transistors will have only 2 connected or maybe even one clipped off. Power transistors commonly have a screw at the top and screw into a "heat sink" or an aluminum block to help with heat. Hands down.... capacitors 9 out of 10 times have left me dead in the water. Heads up, capacitor manufactuers are manufacturing caps so that it's hard to see when the go bad, (buldge or blacken at the top). Looks like the old meausure voltage in parrallel and amperage in series will have to apply for these fixes. Get a schematic, change caps, check fuses for continuity. on my Eiki EIP-200 i notice a little buldging on C727 on my main power board (the board withthe Giant capacitor on it). Anything hot looking or burn marks, usually a replacment part is in store.
Posted on May 12, 2012
Have Eiki LC-X1000 projector. Recently had a power outage and since then it has not come back on. Have tried the reset, 230 AC ok and 300 DC volt ok, No standby light, nothing,then what can i do
dried out smd capacitors in primary part of power supply , common problem with this and similar models. 1uf, 2.2 uF and 1 radial 220 uF
replace bij 105 oC type
Apr 05, 2012 | Eiki LC-XG250 LCD Projector
Eiki LC-SD10 Projector will not power on.
any led on ? if no, check thermal switch near lamp house or dried out capacitors in power supply
Aug 20, 2011 | Eiki LC-SD10 Projector Multimedia...
Eiki EIP 1600T projector will not power on. Projector was running when power went off for just a few seconds. Will not power back up now. I have power to projector.
inside there is a thermal fuse, that might be activated, because the cooling of the lamp did not happen after the power surge.
You need to remove the upper cabinet to reach, but do this very carefully !!
May 22, 2011 | Eiki EIP-1600T DLP Projector
Our EIKI 4500 DLP projector work for about 40 mins then starts to power cycle. does it sound like the power supply to you. do you know where to get a replacement power supply for it?
This model has sometimes poor power supply boards.
replacing them is a terrible job, original boards are only available through official EIKI distributors.
partnumber = 9NK5600204232 ( manufacturer is SHARP)
Jan 11, 2011 | Eiki EIP-4500 DLP Projector Multimedia...
In few minutes after turn on the projector (Eiki Lc-xnb4m) , it shut off automaticlly. and i connect notebook with the projector ,no any reaction. i don't know how to operate it?
Aug 22, 2009 | Eiki LC-XE10 Projector Multimedia...
How to read the hours on an eiki projector lamp
simple!!! (if you know it..)
press the UP button on the projector for 20 seconds, and the hours used will be displayed briefly in the left upper corner of the screen.
Found the solution on Eiki web site, in FAQ section.
http://www.eiki.com/resources/resourcedownload.ashx?filename=/lamp_replacement/lc-xnb4_m_s_ms_lamp_replacement.pdf
Jun 20, 2009 | Eiki Projector lamp Projector Lamp for...
Won't power up
Hi, The owners manual says that if the red light is flashing, it is an indicator that it is ready to be turned on (use remote or onboard on button); flashing red & green - too high temperature inside, the unit is overheated. Check and clean the air filters; If the red light is steady, abnormal condition and you have to call for service. A copy of your manual is available at http://www.eiki.com/resources/resourcedownload.ashx?filename=/ownersmanuals/om_xb25_20_sb20.pdf Hope this be of some help. Pls post again how things turn up. good luck and kind regards.
Jul 31, 2007 | Eiki LC-SB20 Projector Multimedia...
Eiki LC-X1100 Multimedia Projector Logo
Top Eiki Office Equipment & Supplies Experts
jasbo
jasbo
neOen
Level 1 Expert
Jaime Hernandez
Are you an Eiki Office Equipment and Supply Expert? Answer questions, earn points and help others
