Question about Boating
How do i check my transducer to see if it's working correctly
My vexlar fish finder only flashe's red it go akll the way around the screen
    Problem Solver:
  • 5 Answers
The transducer itself is like a speaker for higher frequencies.you can measure its internal resistance and capitance using multimeter and compare it to the numbers that the datasheet shows.For resistance any number below 200kohm is acceptable
Posted on Jan 24, 2013
Editor925
  • 285 Answers
SOURCE: CAN I POWER MY FISH FINDER GOING DIRECTLY TO THE
Yes you can. Basically the red wire goes to the fuse box connection. The fuse box should then be wired into the positive battery terminal. The black wire is the negative ground wire and needs to go directly back to your negative battery terminal or to a common negative buss bar.
Posted on Jun 15, 2009
ward_knutson
  • 64 Answers
SOURCE: i need a manual for humminbird wide 100 fish finder
You can find the manual you need at: http://www.humminbird.com/support/FAQ.aspx?faqid=72
It is listed in the legacy products area with the wide series of units.
Posted on Nov 26, 2008
SOURCE: Marine Faria depth finder, with thru the hull transducer.
I'm having the exact same problem. I spoke with the service manager at Faria (Ted) and he was thinking that as long as the gauge is showing a reading, it should default to reading the depth. I'll probably send the guage in to FARIA - they'll repair it for $55. You bring up a good point - maybe the transducer is bad? I put a call in to the Tedmeister to see what he thinks. I'll post if he sheds any light.
Posted on Aug 18, 2009
tbirdfan1
  • 3051 Answers
SOURCE: fish finder manual
hello there:
here is a link that will help you get the manual u need ok?
best regards micha
Eagle 250 DS - FishEasy GPS safe.gif Learn more about the Eagle FishEasy 250 DS before you decide to buy. Download User Guide and Manual ... fish finder EAGLE FISHEASY 250DS. www.bestfishfinder. ...
www.retrevo.com/s/Eagle-250-DS-GPS-review-manual/id/23493bh848/t/1-2 - 69k - Cached el
Posted on Aug 27, 2009
dnewcombe1
  • 1564 Answers
SOURCE: I have an Eagle Fisheasy fish finder & need to replace transducer
You can find out which one is serving the device you wish to repair by waving a small spade or wide metal object about a foot from each of the existing transducers and have someone else monitoring the insruments on the concole.
Posted on Sep 07, 2009
Why don't I see fish on my lowrance elite5 hdi fish locator
Sounds like you do not have your transducer connected.
You will know it is working if you have a bottom sounding. If you have a bottom sounding (depth reading) and it is correct then you may have to fine tune the finder to see the fish.
I have the same finder on my boat. http://njsaltfish.com/index.php/captainsfocus?sid=61
Sep 17, 2015 | Lowrance HDS 5 Fishfinder GPS Chart...
Lowrance Elite 4X fish finder that reads between 1.5' and 2.5'
Hey Anon
The transducer installation is more important than anything.. next to correct wiring! You must make sure the mounting is good,,, if its outside the hull, make sure its sitting 1/16th below the hull with no obstructions.. if its inside the hull, the medium you used to fix the puck to the hull must be porosity free and the puck sitting as level with the WATER as possible..
Now, take the manual to the lake with you and DO NOTHING but read the manual and apply what you read to the unit,,, read -repeat - read-repeat.. forget about fishing... now read-repeat and learn... IF nothing seems to be reading correctly.. its probably the transducer installation.. YOU DID use a/the transducer specifically for this unit!!
Jun 24, 2017 | Lowrance Elite-4x Fishfinder
My depth finder keeps loseing the bottom and just flickers the last reading
Hi, if this happens when stationery check the angle of the transducer, if it only happens when moving check the height of the transducer also. Regards Phil
Jul 02, 2012 | Lowrance Lcx 38c Hd Fish Finder Gps (200...
I just bought a used boat with a Humminbird 160 fish finder on it but, the only thing that shows up on the screen is the temperature, NO DEPTH and NO FISH, is there a setting i need to set as i am clueless...
Check to make sure the transducer is hooked up correctly, and check the actual transducer for signs of damage. Transducers are fragile, and a good whack can break the crystal inside. For more troubleshooting, here is a helpful link with the Owners Manual for your Humminbird.
http://store.humminbird.com/media/document/PiranhaMAX_150-160-170-180-190c.pdf
Aug 29, 2011 | Boating
When we are deep water (500 ft or deeper) the fish finder will display 3.5-10 ft. and won't show the fish or shows tons of fish. Are we able to set the depth that we would like to see eg: if we are...
Im not familiar with your particular unit but you should be using a low frequency transducer for water over 500'; something like a 50 kHz transducer or a dual frequency transducer like a 50/200kHz for detail with the high freq. but increased depth range on the lower frequency. As far as setting it to 250 ft, you should be able to use the range feature and adjust the maximum to 250'. typically the factory default is automatic so it will caonstantly adjust the range based on the maximum current depth.
May 22, 2011 | Standard Horizon Standard Ff520 Fish...
Fishfinder 400c?
Hi there.
Ok in WIDE beam mode the cone extends out 45 degrees from the transducer. This covers a fair area, but is best used only in shallow waters as the beam may not have enough power to penetrate deeper waters effectively. 30ft should be fine for WIDE mode however. Using a bit of trigonometry, the beam would extend to a diameter of 60 feet from the center point of the transducer on the sea/river floor.
The beam is a direct beam... It is not a rotational beam from the transducer... i.e. it does not rotate like a radar beam but shoots downward in the cone arc constantly. Imagine a torch being turned on and off very rapidly... The light shoots straight out from the torch in its own cone shape. This is essentially what the transducer does when it shoots out a signal every millisecond or so.
The image you see on the screen is the result of the hole cone of signals, however, the strongest sonar returns occur near the center of the beam. Weaker returns are shown which are located towards the outer edges of the sonar cone where the signal power is less. So if a fish passes right on the edge of the beam, it will only show up as maybe 1 pixel on the sounder screen as it is a weak return on the edge of the sonar cone, whereas if that fish passes under the center of the beam, it will show a larger, more continuous or arched shaped return as the fish moves from the outside of the beam, through the center of the beam, and out to the other edge of the beam under the boat.
Regarding the flasher... I would advise not to use this. It does work by showing a continuous top and bottom reading which displays as constant flashes around the circle readout. Anything it picks up in the beam will show as flashes in between the top and bottom readings. Using the display is far better and with practice allows you to better identify fish and bottom structure readings. Flashers were earlier forms of sonar readouts. Some older folk still like them but I believe the normal display is better for finding and identifying fish and can show structure shape as well (the flasher mode really cannot).
Hope that helps!
Please rate this solution on FixYa!
Jun 02, 2009 | Garmin Fishfinder 400c With Dual Beam...
Rl70c raymarine depth finder problem
fish finder transducer needs to be on before you boot your system. check your hsb cables and termination
Jul 12, 2008 | Raymarine RL70CRC GPS Receiver
Installing an old used lowrance fish finder
I don't think your old fish finder is the LMS-332C GPS Receiver listed above in the description. You don't need the speed wheel for the fish finder to function just the transducer and transducer mount. You should mount that on the back of the boat towards the center but not too close to the motor and not too close to the side of the board. Don't let it hand below the level of the boat. That should keep it from getting hit by the trailer or dragging on the bottom. Try to make it as level as possible. The green and white wires may be for the speed wheel but i'd need a model number for clarification. Hope this helps.
Apr 26, 2008 | Lowrance LMS-332C GPS Receiver
Boating Logo
732 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
