Question about Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft. Front-Loading Washer
Whirlpool Dueu ht wfw8500sr resetting the ccu
Cycles do not work properly
2 Suggested Answers
philbran
  • 242 Answers
SOURCE: cold water keeps filling even when washer is off
if it still flows with the unit unplugged then replace the cold side inlet valve for the fix , it my be called the mixing valve on a part search. Phil
Posted on Jun 10, 2009
Ho do I reset the whirlpool error codes f6
F06 Drive motor tachometer error The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin the door will be unlocked after 3 minutes.
Potential Causes
• Check wire harness connections between the Drive Motor/Tachometer and the Motor ControlUnit (MCU), and between the MCU and the Central Control Unit (CCU)
• Check the Drive Motor
• Check the MCU
• Check the Wire Harness
Replace failed component.
Whirlpool Duet error f6 Google Search
Sep 06, 2014 | Whirlpool Duet WFW9151YW 27" Front-Load...
Tip
Why Is WHIRLPOOL Duet & Duet HT washing machine showing F/14 error code on...
The error F/14 is shown on the display due to EEPROM Error detected in the washing machine.
In this problem check the Central Control Unit (CCU) the ccu is not receiving the proper data from the EEPROM board in the machine. This will Help. Good Luck.
on Mar 11, 2010 | Washing Machines
I have the f13 error, on whirlpool duet ht, 9150. I have removed the top and I'm trying to run a drain and spin. The motor seems to work fine as it cycles through all four steps, but never seems to...
F13 codeindicates that the dispenser motor is not able to be driven to it's properposition.
*Check mechanical linkage from the dispenser motor to the top of thedispenser.
*Check wire harness connections to the dispenser motor and CentralControl Unit (CCU).
*Check the Dispenser Motor.
Toremove the error display, press Pause/Cancel twice. IfPause/Cancel does not work: *Unplug washer or disconnect power for oneminute.
*Plug in washer or reconnect power.
*Re-select the cycle and press Start. Hopethis helps.. Good luck! :)
Jun 09, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Washer will not start has a F - in display
The error indicates that there is no water detected entering machine or Pressure switch trip not detected..If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed.
Press PAUSE/CANCEL twice to clear the display.
  • If there is no water in the unit:
    1. Make sure that both valves at the water source(s) are turned on all the way.
    2. Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
  • 3. Verify inlet valve operation
  • If there is water in the unit:
    1. Verify Drain pump operation
    2. Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
  • Verify there is not a siphon problem
  • Verify wire harness connections to:Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
  • Check all hoses for possible leaks
  • Verify pressure switch operation
  • Verify flow meter operation
  • Verify CCU operation
Thank you !!
Aug 17, 2010 | Whirlpool WFW8500SR
I have an F26 code and my washer won't do anything and cannot find code in the manual what does it mean? It's a whirlpool duet ht
Hi, This F26 error means "door switch error" If the door has not been opened for three consecutive cycles or the door switch is open while the door is locked for more than 5 seconds
Do the following to fix the problem:
Open and close the door
Verify CCU operation by running a Diagnostic test or any cycle
Push the door and check if its completely closed
Apr 08, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I lost my manual and I am getting an F22 display. What does this mean?
CCU/Touchpad/LED assembly error(F-22)*
Hi.This error occurs if the touchpad/DED assembly is not able to transmit/receive data to/from the central control unit (CCU)
Check the following:::
A.Check the touch-pad/LED assembly by selecting different cycles and changing the modifiers and options available to confirm the touch-pad/LED is responding. If the results are negative, move on to the next step.
B.Unplug washer or disconnect power.(Make sure you unplug the unit for 5 minutes, thsi will reset the panel, and restore proper functions if the damage inst severe)
C.Check Wire Harness connectors to the touch-pad/LED assembly and Central Control Unit (CCU)
***((Ok, if all fails to revive proper functions above, this will confirm a major issue that concerns the wiring harness that is used to link the touch pad to the CCU))
Sep 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Cold water keeps filling even when washer is off
Jun 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool ht duet washer throwing codes. f11,f dl, f0
Serial Communication ErrorSerial Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.Check Wire Harness connectors to the MCU, the motor, and Central Control Unit (CCU)Check the Drive system for any worn or failed componenCheck Wire HarnessCheck MCUCheck CCU Check MotorCheck Wire Harness good luck
shaun
Mar 26, 2009 | Whirlpool GHW9400 Duet Washer
Code F28 error
F28 error is..
The communication between the Central Control Unit (CCU) and
Possible Causes/Procedure
1. Unplug washer or disconnect power.
2. Check wire harness connections to the MCU, the motor, and
Central Control Unit (CCU).
– Check connections of the CCU board within the housing.
– Make sure all grounding switches are engaged.
3. Check the drive system for any worn or failed components.
4. Plug in washer or reconnect power.
5. Verify CCU operation by running a Diagnostic Test or any
cycle.
6. Check the MCU by looking for operations of the drive motor.
7. Check the drive motor for powered rotations.
8. Check that the serial harness at the MCU is not mounted
upside down. The wires should be to the left when facing
the MCU connectors
If it is new call for service...
Aug 15, 2008 | Whirlpool WFW8500SR
Whirlpool duet ht
The error code F-11 on your washing machine means:--
both this parts needs to be checked.
You will have to check the following to confirm where the fault exactly is:---
Check Wire Harness connectors to the MCU, the motor, and Central Control Unit (CCU).
Check the Drive system for any worn or failed components.
Check MCU.
Check CCU.
Check Motor.
Check Wire Harness.
You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Aug 09, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft. Front-Loading Washer Logo
13 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
