Question about AT&T High Speed DSL Modem
Yes i want to find out if a cable modem will work with your dsl phone internet service?
    New Friend:
  • 33 Answers
Yes, DSL allow their customers to use their existing phone line for voice or fax. DSL modems are designed like a normal telephone, you just use router, hub, switch, you will need to disconnect and get help from good a service provider. Internet connections are available through cable connection lines. Verizon FIOS Promotion Code Save up to 50
Posted on Feb 23, 2015
    Brigadier General:
  • 10,406 Answers
A cable-modem connects with a coax-cable to the cable-company's network, but a DSL-modem connects with telephone-cable to the telephone-company's network.
Posted on May 27, 2009
Magicjack doesn't always work right sometimes the phone works , sometimes I get an error 3002 message when I try to call out.
Actiontech what, they many vast models, and routers, and mix.
what are you exact connections here>
NO PC stated, HP model number, this is HP forum. so.....what?
no OS stated, opr. system , windows WHAT?
No modem models stated.
No ISP service stated,
what ISP, what service,? DSL> must I GUESS that?
My guess is not DSL no land line but it is possible to buy DSL
with Landline, disabled, I did for years.
or cable modem, ? uses COAX ! not 2wire twisted like DSL.
or are you doing the MAGIC jack , with NO COMPUTER owned
The magic jack does not plugin to any modem ethernet port
ever. its usb.
Broadband, high-speed internet, cable internet, DSL - WiFi, Fios fiber. and more , dial up? nah you dont have LAND LINE./
error codes,. the first page in the manual states !
Contact your Internet service provider to verify your modem allows more than one device to access the Internet if you receive error 3002 when trying to use MagicJack Plus. Some modems and modem/routers-in-one may not be compatible for use with MagicJack Plus if multiple devices are connected to your network.
We dont know what ISP you have nor the connection type
cable tv modem, DSL, FIOS what?
nor the modem you have , you never said,
this is far more complex
its not magic at all,
fire walls set wrong
ISP blocks you, at your mixed, router and modem
using the routers, USB port is a FAIL.
if you want great help answer what you have and what is connected
in details.
the MAGIC jack as 3 ways to connect,
USB or ethernet.?
Jun 11, 2017 | HP Computers & Internet
I have an at&t 2wire 2701hg-b but i dont have at&t internet i have charter and i am not able to figure out how to get my internet to work with this router please help
att 2 wire is a Adsl Modem (Requires a telephone line jack to get the signals) but charter communication is a cable internet service (not DSL) , Requires a TV cable service for internet .
These two jacks differs and there working differs ..
Means : Att works with the username and password type of authentication but charter requires the MAC address of modem for authentication .
Therefore for a cable internet 2wire 2701hg-b modem cant be used . But yes in case charters has username and password authentication and works with the telephone jack in house then its possible to use the same modem.
Aug 19, 2011 | 2wire (2701HG-B) Wireless Router
If i buy a dell inspiron 580 that does not have a modem, can i still plug it into the dsl router and get internet okay?
Yes, you do not need a modem. You connect a LAN cable from the computer to the DSL modem to access your Internet Service Provider.
Jul 27, 2011 | Dell Inspiron 580 Desktop Computer (Intel...
I recently moved from Cable ISP to DSL ISP service. For the DSL service, I was asked to configure my Router to use PPPoE with Dynamic IP addressing. I also provided the router with my username and password...
The reason you have no internet is because the router is specifically for cable. your description contains errors what i think you mean is that you have gone from cable dsl to an adsl, correct me if i am wrong. Basically your modem connected to your router via an ethernet cable and then the router fed the wireless signal to your wireless devices or via ethernet through the 4 ports in the back. With adsl you have a feed from your phone line to an adsl modem so the only way for you to get the dsl router working is to have two ethernet leads connecting to your pc, one from the modem to the pc and one from the pc to the router. You would also need to setup internet sharing on the pc thats connected to both devices.
Either do it that way or buy an adsl router
Nov 10, 2010 | D-Link DI-624M Router (DI624MRE)
Followed all the set up steps but my DSL light would not stay on
  • 1 Plug the Ethernet cable into the Internet port on your wall. If you do not have Internet ports installed in your home, connect a phone line adapter to a phone line jack. The adapter makes the phone line wider so Ethernet cables can connect to it. This does not block your phone from use.
  • 2 Plug the other end of the Ethernet cable into the Internet port on the back side of the Netgear DSL modem.
  • 3 Connect the Netgear DSL modem to a local power source. The power plug inserts into the modem via a small port on the rear of the modem.
  • 4 Insert a second Ethernet cable into one of the numbered ports on the back of the modem. Run the cable to your computer and plug it into the Ethernet port on the computer.
  • 5 Look on the back end of the DSL modem for an HTTP: address. Type this into your Internet browser's search bar. The Netgear DSL modem menu appears on the screen.
  • 6 Select how many computers are to use the modem, if you are using it with other DSL modems and set up a password (the default username and password is "admin"). Click "OK" to initiate the changes you made to the menu. You can now use your Netgear DSL modem to connect to the Internet.
  • Read more: How to Install a Netgear DSL Modem '
    Sep 27, 2010 | NetGear DGN2000 Wireless Router
    Is d-link 655 N wireless router compatible with Touchstone Telephony Modem TM602 that came with my cable/phone/internet service?thank you Joseph
    Yes. D-LINK would be *STUPID* to try to market a router that is *NOT* compatible with *ALL* cable-modem (or DSL-modem) units.
    Jun 24, 2010 | D-Link Xtreme N DIR-655 Wireless Router
    Can the microsoft MN700 Router be used with cable internet instead of DSL from the phone company?I switched from Verizon DSL to Comcast Cable internet but can not find an answer if the MN700 is compatible...
    I would say yes but i have not tested it personaly, but what i know about routers it should work with. Cable internet and dsl are exactly the same thing. The only difference is how its delivered to your house and the speed of it.
    DSL tands for "Digital Subscriber Line." It is medium for transferring data over regular phone lines and can be used to connect to the Internet
    cable the same thing except it is internet though the cable line. you u run the out of your
    you probably wont even have to change any settings on it either. the line out of the back of your cable modem will plug into the same spot the old cable ran to when you just had dsl.
    if this has been helpful please mark it has fixya. also please rate me, and if you have found it very helpful or informative please recommend me.
    Nov 16, 2009 | Microsoft MN-700 Wireless Router
    Just connected router to clear network modem and VoIP (wireless phone service), now when the phone ring, it disconnects me from the internet and the connection is lost until the phone call is complete.
    Is your modem a DSL or cable modem?
    If it is a DSL modem do you have a DSL filter on each phone line to the phones in your house?
    The DSL modem does not need a DSL filter on the phone line.
    Nov 09, 2009 | NetGear WGR614 Wireless Router
    A friend gave me old 2Wire 1701HG wireless modem/router. It didn't come with power cord, cables etc. I found a 4.5V cord from old walkman that worked. Anyway, have ATT DSL service with speedstream 4100...
    That would seem to be AT&T's favorite house brand...
    Me thinks the SpeedStream was their SLOWEST
    "2wire" was their next iteration of SLOW "DSL"
    Yes... You will need to contact THEM ... or whom-so-ever is your INTERNET SERVICE PROVIDER (ISP)...
    As I recall... the PRICE DIFFERENCE from one
    service to the other was about $10 per month.
    Give them your pirated modem number and they
    will need to register it as a digital subscriber
    in order for you to gain internet access.
    Carnac the Magnificent
    May 08, 2017 | 2wire Computers & Internet
    Internet service to service routing
    you cant use a cable modem and a dsl modem at the same time as its a dsl dialler and a router and a cable modem works differently, all the settings wont match, you will have to purchase a seperate router or cable modem/router
    May 13, 2007 | 2wire (1000-400108-001) Router
    AT&T High Speed DSL Modem Logo
    222 people viewed this question
    Top AT&T Computers & Internet Experts
    Computer Repairing
    Computer Repairing
    Prashant M
    Prashant M
    Are you an AT&T Computer and Internet Expert? Answer questions, earn points and help others
