Question about Kodak EasyShare C315 Digital Camera
Memory Card Error on my Canon Power Shot S2 15 using Kodak SD car
I went to view photo's and it says Memory Card Error.
It first said Memory card locked?
  • 6,831 Answers
Hello
OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card and switch the lever on the left side to the unlock.
If the error is still displayed after you did the above, you might want to try the card in another camera.
If the card works in another camera . the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
Posted on Sep 27, 2010
My canon power shot A420 blink a massage card locked ,card error when i micro sd card adaptor in it and my adaptor is also unlock mod
SD and Mini SD memory cards has a small slide switch on the edge of the card, which write protects data on the memory card or add photos to the SD card. Slide the switch from the LOCK position to the UNLOCK position, which is furthest away from the contacts.
Feb 02, 2013 | Canon PowerShot A420 Digital Camera
Tip
How to Recover Lost Photos and Video from Canon PowerShot SD780 IS
<span> <span><img src="maggiena_8.jpg" /><br /></b></span>Canon PowerShot SD780 IS</b> may be the slimmest Digital ELPH Canon has ever created with dimensions 2.10" h x .70" w x 3.40" l, .26 pounds and 2.5 display size. It captivates the senses with bold saturated colors and a daringly original design that matches the intensity of Canon's most innovative camera technology.</span> <span><br /></span> <span><span> <p>Owning to its wonderful picture quality as well as high resolution, it becomes the first choice for many photographer lovers. One more reason that it turns out to be so popular is it supports various standard storage media like SD/SDHC, Multimedia Card, MMC Plus and HC MMC Plus memory cards</b>. images, Video and other multimedia file like songs can be saved there. Usually, keeping a backup of data like pictures and other multimedia files is recommended at the very beginning in case the data was lost by mistake in the process of using the camera. However, if you forgot to backup, you have to use a third party program to <a href="http://www.card-data-recovery.com/">retrieve Canon PowerShot SD780 IS data</a>.<br /> <p><br />Cases about losing data</b><br /> <ul> <li>1. When connect Canon PowerShot SD780 IS to your computer and being transferring vocation photos from SD card to computer, accidently your camera shut down due to low battery. After change the battery and restart camera again, you may encounter the error message "memory card error" that means the memory card is inaccessible.</li> <li>2. While reading data or writing data to SDHC card, "I/O device error" occurs and all photos and video miss.</li> <li>3. On the process of shot, message "memory card is full" pops up to you. However, after deleting some pictures, it shows the same result.</li> <li>4. Connect your SD card reader to computer, the window pops up with message "you have to format SD card before using it". After formatting SD card, all your pictures and video lose.</li></ul> <p>Resolution</b><br />If the above phenomena happen, don't panic, lost photos and video in Canon PowerShot SD780 IS are recoverable. First thing to do is stop using camera to shot for fear that the data was overwritten. For the first two cases, make sure the SDHC memory card is properly inserted. If it still can't be recognized, try to use a card reader to connect it to PC. Or else you have to format memory card and use effective photo recovery software to get back lost photos. For the last two cases, you should rely on <a href="http://www.card-data-recovery.com/">Canon PowerShot SD780 IS picture recovery</a> program. There are many effective Canon digital camera photo recovery program available in the internet, just choose the perfect one for your camera. <br /></b><br /><br /></span></span>
on Jul 20, 2011 | Cameras
I TOOK SOME PHOTOS WITH THE CANON POWER SHOT A530 (ABOUT FIVE). I DO NOT KNOW HOW TO VIEW THE INTERNAL MEMORY PHOTOS. ALSO CAN I HAVE THEM SWITCHED TO THE SD CARD? I DID'NT KNOW AT THE TIME THE CARD WAS...
First, promise to never use the internal memory again. Go into the menu and there should be an entry for "copy" which should allow you to copy the internal memory to a memory card. After that, you should "format" the camera with no card inserted to erase the internal memory.
Jan 21, 2011 | Canon PowerShot A530 Digital Camera
I have a Canon Power Shot A520 and have just put in a new memory card 4GB and new batteries. When I turn on camera is says memory card error at the top of the sceen. Why is that?
The A520 is designed to work with SD cards. Your 4GB card is actually an SDHC card. While it fits into the slot, it is electronically incompatible.
You need to use SD cards 2GB and smaller.
Oct 05, 2010 | Canon PowerShot A520 Digital Camera
SD Memory Card Pictures Missing
First make sure that the photos are not actually on the camera's internal memory and not shot on the card to start with. Do this by trying to look at the photos through the camera with the card out of the card slot. Next before taking anymore pictures try putting the card into a different computer and card reader. If it still shows up empty you can try several recovery softwares online for free, only paying for them after they have found your photos and are ready for saving. If that doesn't work if you have a local photo store still they will offer recovery service and recovery services are available from companies like DriveSavers.com. Be warned, it can be expensive.
Nov 11, 2017 | Kodak EasyShare C875 Digital Camera
Memory Card Error
You could take the card to a store that has a Kodak picture maker machine (Walmart, etc.). From there, you can print your pics or even make a cd of them. The card may be faulty or just may not work in Canon cameras.
Aug 28, 2009 | Canon PowerShot A520 Digital Camera
Formatting required after taking photos on card and dont want to lose photos already on card
Did you use the camera to format the card before you shot any pictures. If not, the camera can't use the card and used its own memory to store the photos. Use the camera to format the card, then the camera can continue to shoot more photos and store them on the card. When you download them to the computer, remember to get the one from the camera too.
May 11, 2009 | Lexar Professional High-Speed 2GB Secure...
Retrieving pictures from SD card
You may take a look at this SD card photo recovery guide which helped me get back deleted photos after reformat the SD card
recover photos after reformat SD card
good luck!
Dec 03, 2008 | Kodak EasyShare C613 Digital Camera
Kodak EasyShare C315 Digital Camera Logo
163 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
