Question about JVC Audio Players & Recorders
JVC Car Deck KD-R810 "LT" message
I've had the unit for 3 years with no issues. Turned the car on today and on the main display were the letters "LT" near the top left hand corner of the screen. Sound quality was greatly reduced (bass was muffled, mid's ok, high's sounded like a tin can). I thought it may be the equalizer settings but all my custom bass/mid/treble and Loud settings were still intact. I have a sort of "U" setting - bass +5, mid +1, treble +5. Changing the equalizer and audio settings doesn't help much as everything still sounds like a tin can. What is this "LT" error?
3 Suggested Answers
SOURCE: jvc rx-5032v audio/vido control receiver
HI MATE YOU NEED THE REMOTE
Posted on Aug 19, 2008
fixyathing
  • 341 Answers
SOURCE: Equalizer setting help
try to use the preset equalizer settings after which you can come back to the parametric equalizer and adjust to your own taste. no problem if you don't connect the subwoofer just make sure you set the hi-pass filter to off so that you will hear the full range to your speakers. but, I advice you to put a subwoofer. There is more dynamics to the lower freqs too. don't adjust the source level if there is no problem. take note the EQ of your head unit is a parametric equalizer. hope this helps while you read about parametric EQs.
Posted on May 12, 2009
I have a JVC KD-R80-BT it is one week old and when it s cold outside the clock stop working
I had the same issue. I found that this is normal system function for one of the three clock displays. This will only affect the large clock display. When the unit is too hot or too cold, a symbol LT will appear on the screen in the upper right corner. When LT disappears, the unit temperature is at a satisfactory level and the clock will function normally. In the manual, it says that displays is frozen until the unit heats up or cools down because scrolling would be fuzzy.
Jan 27, 2013 | JVC KD-R80BT AM/FM CD/MP3 Car Stereo...
JVC KD-R810 power wont stay on
If it was working early, then it is failed. It needs to be serviced.
If it never worked since you installed, then check wiring.
Feb 08, 2012 | JVC Kd-r810
I need a user manual for the JVC KD-R810 car receiver
is it possible to download a free owners manual for my jvc
vhs and cd recorder model no HRXVC26U ?
mistyharb@aol.com
Aug 04, 2011 | JVC Kd-r810
I attach my new ipod touch to my JVC car stereo and the screen displays CANNOT PLAY. What is my problem?
Are you attaching it via usb on the deck or aux? Because if it is via usb the touch is probably not supported.
Nov 08, 2009 | JVC AM FM CD DET FACE CAR STEREO
Jvc kd lx111 deck wont eject cd
I just had this problem today and when I attempted to eject the CD it would give me an error message that stated (ERR 32). Apparently this means that there is something blocking the movement of the screen, a little manipulation should help the issue. Another variable could be the Eject lock feature, essentially a "child lock" for your disc. When this lock is activated it prevents the CD in the deck to be ejected. You can change this by holding down the blue source button and the eject button simultaneously for about 2 or 3 seconds. A message should appear saying "No Eject" and one that repeatedly flashes "Eject on" These two things seemed to help me alot when I had this issue. If those things don't work I would recommend calling JVC, much to my suprise they were actually really helpful. Their number is 1-800-252-5722.
Nov 07, 2008 | JVC KD-LX111 CD Player
No able to play mp3s on Car CD DECK
unfortunately the jvc radio model # kd-g140 will not play mp3 on a cd disk- it will play a mp3 player thru the aux jack on the front of the head unit- please rate my help
May 19, 2008 | JVC 50W x 4 MOSFET CD Deck with MP3...
JVC KD-AVX1 Sirius Just Quit
Hi guys i need help i bought a use KD-AVX1 and i don't know how to use it i need help how to get a manual for my radios appresiated your help.
Apr 29, 2007 | JVC KD-AVX1 Car DVD Player
Error 10 message on display screen
Same issue but pressing Power and SEL would not reset unit. Found solution. Once again disconnected the car battery. Removed the face unit from the radio base and then reconnected the battery. Replacing the face unit AFTER the power was re-established solved the issue. (Probably pulling the radio fuse rather than toying with the battery connection would have done the same thing.)
Mar 09, 2007 | JVC KD-S640 CD Player
26 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
