Question about Toshiba Satellite A205-S4617 Notebook
Acer orbicam when i try to use my orbicam it says that it it not connected. when i was about to use my yahoo messenger and clicked my webcam, it says "webcam not connected"..please help My Toshiba Sattelite a205 webcam
  • H P
    H P Jan 27, 2009
    my toshiba a205 laptop webcam will not connect. what is my solution??
Acer's built in webcam
Take your laptop to your local computer repair shop, as it will take too long to explain a solution.
Good Luck.
Jan 22, 2009 | Acer Aspire 5600 Series 5630-6951 Laptop
Acer webcam
You need to click on [Start] then click on [My Computer] and then [Acer Crystal Eye Webcam] will show up then click on the [Camera]. If this does not work then it could be that the cam driver needs reinstalling or maybe faulty. Take it back to your dealer!
Jan 09, 2009 | Yahoo Messenger
Acer crystal eye webcam cant use in yahoo messenger
may be the driver files are missing .. just update it and see ...
Oct 25, 2008 | Acer Aspire 5100 Notebook
Acer orbicam
What I would first recommend doing is reinstalling the driver for your camera. The driver is basically what allows your computer and web cam to connect to each other.
The Download: http://www.acer.com.sg/support/drivers.asp?product_type_=Acer+Notebook&product_name_=Acer+Aspire+5670+Series+&category_=Windows+XP+Drivers
After downloading that file , run it and install it...that should take care of your issue!
Sep 29, 2008 | Computers & Internet
Lost webcam driver
you can download the driver (webcam) from www.acerpanam.com
FYI, if you can't find the driver under AS 3680, try AS 5570 or AS 5570z
Aug 26, 2008 | Acer Aspire 5610-4648 Notebook
Instructions for use acer aspire5050-5430 notebook orbicam
These are the text-only instructions:
Launching the Acer OrbiCam
To launch the Acer OrbiCam, double-click on the Acer OrbiCam logo in the
desktop.
OR
Click Start > All Programs > Acer > Acer OrbiCam. The Acer OrbiCam capture
window appears.
Changing the Acer OrbiCam settings
Resolution
To change the capture resolution, click the displayed resolution at the bottom
right corner of the capture window, then select the desired resolution.
Note: Setting the camera resolution to 640 x 480 or larger does
not change the capture window size.
33
English
Options
Click Options to display the Window, Preview, and Folder tabs. Use the options
to change the capture window size, preview settings, and the folder for
captured photos or videos.
Camera Settings
Basic settings
Click the Camera Settings icon on the bottom right corner of the capture
display, then select Camera Settings from the pop-up menu. You can adjust the
Video, Audio, and Zoom/Face tracking options from this window.
34
English
Capture settings
From the Camera Settings window, click the Driver Settings button. The
Properties window appears.
Device Settings allows you to change the camera brightness, contrast, hue,
saturation, sharpness, etc.
Advanced Settings allows you to activate gain control, implement image mirror,
select image enhancements and anti-flicker settings, and turn on/off the camera
indicator.
Zoom/Face Track Settings allows you to adjust the zoom level and turn the
face-tracking feature on or off.
Capturing photos/videos
To capture a photo or a video clip, rotate the Acer OrbiCam to get the desired
angle, then click the Take a Picture or Record a Video button. The Windows
Picture and Fax Viewer or the Windows Media Player automatically launches to
display/play a preview of the photo/video clip.
Note: By default, all photos and videos are saved in the My
Pictures and My Videos folder.
Using the Acer OrbiCam as webcam
The Acer OrbiCam is automatically selected as the capture device of any Instant
Messenger (IM) application. To use the Acer OrbiCam as a webcam, open the IM
service, then select the video/webcam feature. You can now broadcast from
your location to an IM partner anywhere in the world.
Jun 10, 2008 | Acer Aspire 5100 Notebook
Acer orbicam
There are two software entities involved – the camera Drivers and the OrbiCam application itself – and BOTH need replacing/updating to fix this problem.
The new driver and a new version of webcam application (below) seem to fix the issue.
The correct files to download are:
Acer Orbicam driver (Bison)
Acer Orbicam Bison utility 1.0.0.13
These can be found here under the MS Windows Vista drop down menu:
http://support.acer-euro.com/drivers/notebook/as_9300.html
In order to fix the problem, you must download and install them both to make the Orbicam work correctly.
FOLLOW THE INSTRUCTIONS BELOW IN THE SAME ORDER:
1. remove the installed OrbiCam application and reboot if required;
2. install the new driver (preferably with the “driver update” wizard from Device Manager)
3. update the Orbicam application 1.0.0.13
After this, the webcam should function properly, even if the original Orbicam icon disappears.
To check everything is working OK run LiveCa07.exe or BisonM07.exe that are located in the c:\windows\bisonxxx\ folder or simply run Messenger
Feb 19, 2008 | Acer Aspire 5101WLMi Notebook
You need to configure the privacy settings on Yahoo Messenger.
Jan 26, 2008 | Acer Aspire 5500 5570-2609 Laptop
** Note ** When the My Pictures or Pictures folder gets full, camera will not work - Cut and Paste all pictures in that
folder to another folder and restart Orbicam program.
If that does not work then do this:
Start - Programs - look for Acer Empowering Technology then Acer E-Recovery - The look at the bottom and you will
"Backup", "Burn disk" and Restore" choose Restore - choose Apps and Drivers at the bottom of Restore tab (it will say
extracting) - once extracted - click Install or Guides and Manuals if needing Orbicam instructions - click Vista or (XP) on the left - click Drivers - click Camera or CCD - on the
right side of the screen, then look for Bison driver or (or your model which can be found in device manager - control panel - system - device manager - Imaging devices) you have then click a phrase that has something like "Install now", follow on screen instructions. Then repeat steps above and instead of driver choose Bison (or your model which can be found in device manager - control panel - system - device manager - Imaging devices) Utility
Nov 10, 2007 | Acer TravelMate 2300 Notebook
Toshiba Satellite A205-S4617 Notebook Logo
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
