Question about Ricoh GX3050sfn InkJet Printer
How to sove system error s001 on a ricoh printer Gx3050sfn All-in-one Inkjet Printer
SOURCE: Error message on Ricoh Aficio BP 20 PCL 6 printer
Flashing orange means low toner.....solid red should be a paper jam
Posted on Feb 21, 2009
  • 5 Answers
SOURCE: first time I turned the power on the machine said "Warning system error S0001"
The cause is the lock lever of scanner unit is locked. Lift the scanner lid and unlock the scanner unit with the switch located under the lid on the left side.
Posted on Jun 03, 2009
Dicedonions
  • 118 Answers
SOURCE: Ricoh SP C811DN error sc549
unplug printer, wait minute, plug in, should reset.
check Ricoh website to trouble shoot if does not reset.
Posted on Apr 29, 2010
  • 903 Answers
SOURCE: my ricoh printer is showinf an error of sc440-2
sc440 on the CL7000 is a drum motor error. sc440-2 is specific to the color drum motor. The problem is either the motor itself, the drum gear position sensor, or one or more of the color photoconductor units. The photoconductor units you can replace yourself if you have extras -- see if that will clear up the problem.
If they don't, you'll need to contact a service technician to inspect (and replace if need be) the motor and sensor.
Please rate this solution if it was helpful. Thanks!
Posted on Sep 17, 2010
mariolands
  • 2296 Answers
SOURCE: Ricoh Gx7000 inkjet A3 Printer - what does 'error
Error 990 indicates a dirty sensor, so either a maintenance unit is dirty or you have a clogged print head. You can read more about this error on Richo website where you can see in the images what you need to clean.
Posted on Feb 13, 2011
Erro s001 gx3000s
If you wish to get some details; check the site linked here. Pull up older posts.......
http://electro-medical.blogspot.com/
Jun 17, 2016 | Ricoh GX3000sf InkJet Printer
How d-o i get my windows 7 64 bit to recognize the scan and fax functions
there is a win 7 fax and scan installation download available from microsoft
Apr 08, 2016 | Ricoh GelSprinter GX3050SFN Multifunction...
How to solve system error s001
you can try pulling out and reseating the Waste Ink tank which is located behind the machine behind a plastic door cover (left side of machine as you are looking at it from behind). Turn the machine off and on using the main power switch. If the code comes back then you will more than likely need a new Waste Ink Tank.
Jan 23, 2013 | Ricoh Gx3050sfn All-in-one Inkjet Printer
I have a Ricoh GX3050sfn, it says the collector unit is almost full. I have installed a new unit, but it is still saying that the collector unit is almost full!
O.K. I had this problem also. Here is the solution to reset the Collector Full or Collector Near Full Alarm:
1: Press the following buttons: Clear (Yellow Button) then 1, 0, 7 in that sequence then press and hold the Clear/Stop button. After a few seconds, the printers service menu will appear.
2. Scroll, using the arrow button, up til you see 'Engine Maintenance' in the lcd display. When you have that on the display press the 'Yes' button.
3. The LCD screen will read 1000. Using the arrow buttons change the first number to 5. Use the right arrow button to move the cursor to the last digit and using the up arrow button change the last digit to 3. The display should now read '5003'
4a: When you have '5003' in the display Press the 'Yes' button. The display will change to 'RST:WASTE:R'. 4b:Press the 'Yes' button. 'EXEC' will appear on the display. 4c: Press the 'Yes' button again. The display will change to 'OK?'. 4d: Press the 'Yes' button again. The lcd will read 'RUNNING'.
When it's done running it will revert back to the 'RST:WASTE:R' on the display.
5. At this point turn off the printer. Wait 10 seconds or so, then power the printer back on. After the printer is done starting up the error should be cleared and your free to continue on. YAY! You beat the system!
Another quick tip: If your collector is near full or even partially full, find yourself some latex gloves, a plastic knife and some paper towels. You can carefully clean the collected ink out of the tank with the knife using the paper towels to clean the blade off between scoops. If you're not careful, it can get messy,but in that way, with the reset instructions above, you can easily re-use a collector tank 3 or 4 times.
Mr. Wizard
Jan 31, 2011 | Ricoh GX3050sfn InkJet Printer
System error 0990. What to do?
I was told it was a bubble in the line and you would have to turn it off and let it reset 9 or 10 times for the system to work the bubble out.
Sep 16, 2010 | Ricoh GX3050sfn InkJet Printer
How to fixe error(0990) in Richo gx3050sfn
Error 990 is an error that has to do with the ink carridge system. This is a Ricoh defect. If your printer is still under warranty you can call Ricoh and inform them of the error and they should replace it. To try and fix is 50/50. We usually just recommend getting a replacement.
Jan 19, 2010 | Ricoh GX3050sfn InkJet Printer
I have a brand new Ricoh GX 3050sfn. When I cnonect it and turn power on, I get system error s001. What can I do?
The travel lock is on open the top and on the front left underside there is a switch push it back and it should work fine
Dec 20, 2009 | Ricoh Aficio GX3000 All-In-One Printer
First time I turned the power on the machine said "Warning system error S0001"
Jun 03, 2009 | Ricoh GX3000S InkJet Printer
Hello, we're getting an error code of 990 on a GX5050n inkjet printer. The printer is fairly new with only a dozen or so printouts. Thanks.
make sure printer is off. Then old down escape and online button at the same time. Continue to hold these two buttons down then turn on printer. Continue to hold those two buttons down (will take about 2 - 3 minutes). This should clear that message - worked for me!!!
Aug 07, 2008 | Ricoh Aficio GX3050N Printer
Ricoh GX3050sfn InkJet Printer Logo
278 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
