Question about Kodak ESP 3 Multifunction Printer/ Copier/ Scanner
Should you need to replace a printhead after 1000 copies?
Is it worth replacing a printhead - can you do it yourself?
  • Kodak Master
  • 32,281 Answers
No need to if the print outs are OK.
Posted on Jan 23, 2013
  • colleen quigley Jan 25, 2013
    It isn't printing due to a defective printhead - I was trying to figure out if a printhead capacity equals 1000 copies. I would hate to think I have to buy a kodak printhead every 1000 prints - the ink is already costing a small fortune.
  • Chris Hingee
    Chris Hingee Jan 26, 2013
    Print head is easily replaced.Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles. If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive. It may be more cost effective to buy a later model and better printer than replace the print head.
I have a dell vostro 1000 they said that the graphics card was fried. is there anyway to get it working again
You would have to replace the whole motherboard because it is an integrated graphics chip. It wouldn't be worth it at all. You are running Vista with minimal ram and a slow CPU so it's just not a good laptop. Get yourself a new computer.
May 22, 2012 | Dell Vostro 1000 1310 1400 1500 1510 1710...
While printing multiple copies in black the printing starts fadding after the first copy and gets worse, after 4 copies you can know longer see the printing. I thought it was the cartridge but it still...
That machine is very problematic. See reviews on Google. If your using HP ink then just save yourself the grief and replace the machine. if you have generic ink cartridges in the printer, replace them with OEM. Also, replacing the Printheads may fix the problem. Printheads and Ink cartridges both only have a 1 year shelf life. If they are out of date (date is stamped on them). Replace and retry.
Jun 25, 2010 | HP OfficeJet Pro k550 Printer
2000 VW 2.0 Beetle - Manual say not to replace timing belt?
General rule on most cars with a timing belt is change somewhere between 80K and 120K. On some cars, failure of timing belt will destory the engine.
If car is only worth $2500, and labor (parts are cheap on this usually) is $1000, if you can't do it yourself, need to decide if you risk it.
Are you willing to throw away the car when the timing belt breaks? Or spend the $1000, and have some other failure that renders the car useless 5000 miles later?
This is really a financial decision you have to make. If engine blows, you may be able to get $500 for it from junkyard, and you still have your $1000 saved from not changing the timing belt.
Aug 05, 2009 | Volkswagen New Beetle Cars & Trucks
I get the error message: "The following printhead(s) has a problem; yellow/black"
antiochpc may be correct but something worth trying first.
Open the printer lid and press OK for 5 seconds (as per screen instructions) to get the printer to put the printhead carriage unit in the replacement position.
Take the black and yellow printhead out of the carriage unit and check for any smear or soiling on the circuit board at the back of the printhead (don't touch the underside where the nozzles are!).
Using a cotton bud, carefully wipe off any ink or other moisture/grease, that may have built up.
Do the same to the back of the printhead slot circuit are but again, be careful and gentle.
Try slotting the printhead back into position, close the carriage unit blue lid and close the printer lid.
If it's worked you'll find the printer will run a self test routine and then return to normal operation.. If not, it's definitely replacement time.
Jan 24, 2009 | HP Officejet Pro L7680 All-In-One Printer
THE COLORS OUR NOT RIGHT
You mean you replaced the ink cartridges, since the printhead can only be replaced from the kodak tech support because it is not for sale.
What you need to do is to call them or go to kodak.com/go/aiosupport to have your real Printhead replaced (this is where the ink cartridges go) because that is causing the issue.
Nov 17, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Canon Pixma MP780 print quality fault
My daugther also has a Pix780 so I just replaced my print head with hers and now the colour prints great. I guess I'll try cleaning mine first and if that doesn't work, I'll purchase a new one when the dealer who services Canon opens on Tuesday. I could also buy one from the Canon website for something like $60. I copied the following from Canon's sites under the FAQs. Sounds like you may need to replace your printhead.
How does a Canon Printhead work?
The printhead delivers very small drops of ink onto the paper. The ink from the cartridge is transported via small tubes. Heating elements heat the tubes, creating a small bubble of ink. The heating element determines the size of the drop to be applied to the paper.
How do I know I may need to replace my printhead?
There are a few symptoms that may indicate printhead failure or a clogged printhead. If the following symptoms continue even after replacing the ink cartridges and trying the troubleshooting steps in your user's manual or those listed below, you may need to replace your printhead:
  • Pages come out blank, or you see poor print quality
  • Pages you print appear to be missing colors
  • Colors on the printed page are quite a bit different from what shows on the screen
  • Horizontal white lines or light-colored lines or light streaks appear throughout the page
Why would the printhead have problems?
After hours of printing, the heating elements may fail after being turned on and off hundreds of thousands of times. The printhead can also become clogged or blocked with paper debris or solidified ink. If your print quality is poor or your printer will not print at all, it may be time to change your printhead.
Aug 29, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Problems replacing ink cartridges in epson 1000 ics
Turn off printer, unplug it from power supply.
Replug and turn it back on
Tilt scanner so that you can see the printhead, press menu and select change cartridge, press copy button.
Feb 24, 2008 | Epson 1000 ICS All-In-One InkJet Printer
Kodak ESP 3 Multifunction Printer/ Copier/ Scanner Logo
14 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
