Question about Carrier XHB123D X/Y Series Heat/Cool Air Conditioner
Carrier model #58rav070-12 will not ignite, blower keeps kicking on and light flashing
This happens every year, I have a new filter in the furnace. Single mom of two small kids and I just lost my job, waiting on unemployment. Help, what can I do to get it working until I can afford to call a repair person. It is 9 degrees out, blizzard in northeast ohio and with a 5 & 6 year old I cant make it to the store until tomorrow. But we need heat, please help:)
  • 534 Answers
SOURCE: Carrier model #58rav070-08 flashing error code #31
I would check the back of the unit to see if any debris has accumulated then check for the filter and make sure it is clean. Look at the front of the a/c where the filter sits and see if the coil behind the filter is dirty. If so the unit needes to be cleaned. This can be done by purchasing a can of coil cleaner at the hardware store and follow the directions to clean the coil. What the system is saying is there is a blockage somewhere causing this code. Not being serviced in 4 years would be the possible cause because of the amount of debris in the air over that 4 year period. Good luck on the repair hope this helped you.
Dave
Posted on Dec 08, 2009
vanni7
  • 163 Answers
SOURCE: 3 amp fuse blows on a carrier 58mcb furnace board
Hi!!! Does your ac unit work fine?If not check your low voltage problem..You have a low voltage problem check the wire going out to your condensor make sure that they are not touching..Good luck..Check low voltage wires..short in progress..
Posted on Jan 04, 2009
solveditnow
  • 39 Answers
SOURCE: (HVAC) Furnace Not Igniting Quickly
Make sure a back draft in the flue is not happening. Wind can blow it out until the flue heats up. The flame sensor may not be close enough to the burner flame. It may be weak and need to be replaced or if its an optical one it may be dirty and not see the flame very well. Its not wasting much gas but it puts extra wear and tear on the gas controls, is noisy, and, as you said, blows cold drafty air. A gas control system that has issues of any kind is not real safe. It needs to get fixed.
Posted on Jan 08, 2009
pierre1811
  • 144 Answers
SOURCE: Code 32 when wind blows
Hi and welcome to Fixya. I believe that the wind is affecting the draft. What I would recommend is to install a cap on the flue that is similar to a weather vane in that it rotates to block the wind from creating a downdraft in the flue. Some times depending on the direction and strength of the wind it will come up over the roof peak and then down the flue. A regular fixed cap may work too. You should be able to purchase one at your local hardware store. Please let me know if this was helpful. Good luck.
Posted on Jan 25, 2009
SOURCE: Furnace wont run
First of all when you flip the switch, it goes thru a startup sequence. THEN it turns on the Igniter (notice the red glow). Then the gas turns on.
Now at this point check the idiot light and it should be giving you a code of 34. That 34 (3 shorts 4 longs) says that there was a problem igniting the furnace. After it cycles thru at least 4 times and fails to ignite all the blowers, then is when you get a code 14 (1 short 3 longs)
NOTICE what's happening with ALL the burner Tubes each time it attempts to ignite. If only one or two are running....then this is your problem.
To fix all you do is take out the burner Tubes, look for debris, blow them out (blow from the front where all the jets are), and replace them in sequence from left to right (the tabs overlap).
Posted on Feb 01, 2009
I have a carrier furnace the control board keeps coming up with differ t led coxes ifiI reset it it works a couple times then flashes a new code had four different codes come up so far 21 22 31 34
Have to know the model and serial of the furnace.
locate code list usually inside or on the back of a door.
Operation sequence= call for heat--inducer blower motor--makes pressure switch--signals board to bring on hsi--after a set time gas valve opens and you have ignition--main blower motor comes on after a set time
Feb 05, 2014 | Heating & Cooling
I have a goodman furnace GMP100-4 REV B..about a year ago it was not working. The fan would start but it would not ignite. We found out we need a new ignitor and it was a good quick easy fix. Now a ye
Any light flashin on the control board? If not then look for a small fuse blown on the board. See lights a flashing count them flashes
A sampling of various failure codes on a furnace:
Read one LED flash that stays on continuously to mean your furnace has no signal coming from the thermostat and will not operate. Turn the power off and check the thermostat for improper settings or connections.
Interpret one LED flash that blinks on and off to mean your furnace has locked out because it could not ignite after three tries, and must be reset. Interrupt power to your furnace for 20 seconds or lower the thermostat so your furnace does not try to heat, then reset the thermostat to the previous setting. After one hour of lockout, your furnace will automatically reset itself and try to operate as usual.
Decipher two LED flashes to mean the draft blower is not working, or your furnace has a short in the pressure switch circuit. Turn off the furnace power and repair a short or replace the pressure switch.
Read three LED flashes to mean your furnace has an open pressure switch circuit or it has an induced draft blower operating. Check the pressure switch hose of your furnace for blocks or an improper connection. Also, look for blockages in the flue, and tighten any loose wiring.
Translate four LED flashes to mean your furnace has a primary limit circuit open, possibly from loose wiring or blocked filters. Check and clean filters, tighten wiring and check the flue for blockages.
Interpret five LED flashes to mean your furnace senses a flame without a call for heat. This could be from a gas valve closing slowly or a burner flame lingering.
Read seven LED flashes as a warning of a low flame sense microamp signal. This could happen with a coated flame sensor or a lazy flame from poor gas pressure. Turn off the power and adjust the gas pressure according to the information on the rating plate.
See eight LED flashes as meaning an igniter circuit problem due to a bad igniter or an igniter connected improperly. Replace the bad igniter or check the ground wiring, making necessary corrections.
Decipher nine LED flashes to mean the high-stage pressure switch circuit will not close during a high-stage-induced draft blower operation. Your furnace may have a pinched or blocked pressure switch hose, a blocked flue or loose wiring.
Read continuous flashing on the LED to mean your furnace has a reversed polarity of 115 volts. Turn off the power and correct the wiring polarity after reviewing the wiring diagram.
Nov 29, 2011 | Goodman Heating & Cooling
Carrier 58STA furnace code 33, no ignition blower stays on. I have a Carrier 58STA furnace. It's getting a code 33 and never trying to ignite. The blower constantly stays on. It is pushing good air...
33 is a limit switch open take your furnace doors off and there should be a wiring diagram. on this furnace the blower will run if this is open. check rool out swict and linits. it sounds like you have a problem with over heating. how does the fire look ? is the vent blocked ? things like thathttp://www.scribd.com/doc/20861415/Carrier-58pav-Service-Maint i think page 9 has falt codes
Feb 11, 2011 | Heating & Cooling
Furnace goes on red light stays on exhaust fan for heat chamber goes on gas igniter comes on but soon as gas comes on furnace kicks off have to shut off power for furnace for it to reycyckle but same...
Check your filter to make sure it is not plugged. If it is plugged - replace with filter recommended for your furnace. Every manufacture recommends you have your furnace checked and cleaned on an anual basis to keep itrunning safely and at it's top efficiency. If the filter is plugged or the blower wheel plugged, the furnace will shut itself off. Make sure all registers are uncovered - suppply and return registers.
Jan 03, 2011 | Heating & Cooling
Our Carrier Furnace will sometimes work fine, however, at times, it will just not go on. Our thermosat is set to 68 and many times it will drop to 65 or even 63 without turning on. It happens every so...
obtain the code it flashes on the board next time it goes down and let me know what you got. There are too many variables to guess Id rather hit it right on the head. I will be waitiing for your response. The board is usually located in the blower section of the furnace.
Dec 16, 2010 | Carrier 38CKC036 Air Conditioner
I have a Goodman GMS90904 and it's been working great for about four years. All of the sudden, i realize it's running a lot, so upon inspection, what's really happening is that it's firing up, the flame...
Even though this furnace is newer, I highly suggest a licensed tech make sure that this problem is not due to a breach in the heat exchanger causing the flames to go out when the fan comes on. That said, first check that the filter is clean and then check the flame sensor rod. If there is "chalky" build up on the end remove it with sand paper. If this cures the problem then purchase a new flame sensor for a more permanent repair.
Nov 28, 2010 | Goodman GMS90703BXA Heater
Jan 08, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Just washed permanent filter on older Carrier heater/ air in garage. (Can't find model No.) IT'S TALL. a/c coil sits on top of it. The top panel on heater has vent slits.. The bottom panel is solid and...
no wehen you take the bottom panel off to get to the filteer what happens is that there is a blower door saftey switch that opens until the door is replaced correctly on the furnace so that there is no recirculation of the combustion air thru your return. the panel for the top that has the vent slits in it usually goes on after the blower door is correctly installed and secured. i commend you for changinf your filter your self but i also am affraid that you may not be able to get the panels back on correctly and the furnace not come back on. usually you have to put the bottom panel on with it appproximately 1" above the middle part of the furnace and then push it in and down to engage correctly. then the top gets put on simularly but on the upper part of the furnace then pusked in and down until it locks in place. Hope that htis helps you and have a Happy New Year.
Jan 01, 2009 | Carrier Heating & Cooling
Carrier XHB123D X/Y Series Heat/Cool Air Conditioner Logo
363 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
