Question about Maytag Atlantis MDE7400AY Electric Dryer
Maytag gas dryer doesn't dry properly
My maytag gas dryer heats up but not very high,it is taking me three times to dry my clothes
  • mennnis Feb 24, 2009
    I too have a maytag gas dryer and the vent plugs off after very little use, thus the clothes do not dry. When the vent is open, there appears to be a high amount of moisture. THere seems to be a fair amount of lint in the lint screen, but there seems to be way to much going through the vent and outside.
    Any ideas
SOUNDS LIKE A RESTRICTION IN THE VENT. CHECK AIR FLOW WHERE VENT EXITS HOUSE. IF IT IS NOT STRONG, INSPECT VENT LINE BEHIND DRYER. IS IT CRUSHED OR CLOGGED WITH LINT? THIS WILL CAUSE DRYER TO SHORT CYCLE. IF VENT IS NOT CLOGGED, CHECK AIR FLOW AT BACK OF DRYER WITH VENT DISCONNECTED. IS AIR FLOW STRONG? OF NOT, PROBLEM IS WITH BLOWER.
Posted on Jan 27, 2009
Dryer not heating properly
More often When you experience a problem like this with your dryer it is becouse of a clogged dryer vent hose or the vent in the wall. Disconet your dryer vent hose from the dryer to see if it will dry properly. Then you will know if the dryer or the vent.
http://www.on-timeappliance.com/dryerrepair.html
Mar 28, 2012 | Maytag Dryers
No or poor heat from dryer what do i check first i cleaned all dryer vents sensor dry reads double than normal too start ,clothes take 2 or 3 times to dry
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101,,./'
Apr 26, 2011 | Maytag Neptune MDG5500AW Gas Dryer
Gas dryer dosn't heat properly
The problem is the dryer coils are failing. They tend to fail as they heat up. They are inexpensive and easy to replace. Here is a link that should help http://appliancehelponline.com/gdryertroublevideo.html
Jul 07, 2010 | Maytag MDG3600BW Gas Dryer
It seems like the burners are not all lighting. Maytag Epic Z gas
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer Troubleshooting2_bing.gif Electric2_bing.gif Dryer won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 11, 2010 | Maytag EPICz 6.7 Cu. Ft. 8-Cycle King-Size...
My Maytag Quite Plus clothes dryer gets warm but not as hot as it use to. It seems to take a very long time to dry clothes. Vent is clear. The moisture gage seems to flicker lately.
most dryers have two heating elemts and when one goes out this increases the drying time and could cause a elec. short and trip a braker can be replaced.. There is also a saftey switch that goes bad and will not let the heating elemt work properly ?
Mar 25, 2010 | Maytag Neptune MDG5500AW Gas Dryer
The gas maytag neptune intellidry gas dryer does not dry clothes. It does not have enough heat. It will take about 5 cycles to dry 1 load.
how do i set this dryer to dry my clothes??? what is the right setting?? should i use the time dry setting or the more dry/less dry setting?? Clothes never dry???????????????????????????????????????????????????????
Jun 28, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Not heating properly, many cycles to dry loads
Check the following to address this issue--
Note: Normal drying time for a dryer is about 45 minutes (some may take up to an hour).
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
Jun 02, 2009 | Maytag SDG3606A Gas Dryer
Maytag Atlantis MDG7600AWW Not Heating
the gas coils have a problem. as the dryer heats p the coils on the gas valve are failing causing the dryer not to heat. replace the coils and you should have no problem
Oct 22, 2007 | Dryers
Maytag Atlantis MDE7400AY Electric Dryer Logo
283 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
