About 3 to 4 inch ball found in drain. does this belong in there
    Genius:
  • Washing Mach... Master
  • 1,669 Answers
If the ball is rubber and the machine is operating normally, it is probably acting as a valve to keep water flowing in one direction.
Posted on Jan 23, 2013
Tip
Fisher & Payel washer wouldn't work
A repairman examined my washer and told me I needed a new drain pump. The washer wouldn't drain the water out after filling. I suggested he check the drain because I had recently washed a rug and suspected the drain as clogged with lint. He took out the drain pump and diagnosed that I needed a new pump. After he left, I watched a youtube video on this problem. They man in the video carefully showed how to remove the drain pump. I then removed the drain pump myself and found an inch size ball of lint that was clogging the drain pump up inside. I removed the lint and reinstalled the same pump and the washer has worked fine ever since. I learned this after an expensive service call fee and he wanted to charge me another $150+ for new drain pump and installation.
on Jan 22, 2010 | Fisher and Paykel GWL11 Top Load Washer
WOULD SOFT WATER HAVE A BAD EFFECT ON THIS MODEL AS IT HAS RUSTY BITS
Hot water heaters are a collector of sediment. The proper care includes flushing out the collected debris through the low side drain faucet. The problem is the faucet is not designed correctly to carry out the needed task. If you are handy... turn off the water and gas or electricity to your water heater. Relieve the water pressure through the temperature/pressure relief valve on the side of the water heater tank. Once pressure is relieved close the valve. Determine if you have a 1/2 inch or a 3/4 inch diameter drain valve hole in the side of the tank where the drain valve is located. The drain valve can be removed with channel lock pliers, an 8 or 10 inch adjustable wrench, or a small 8 to 10 inch pipe wrench. Water will leak out the threaded hole while the valve is out. If everything is closed maybe 2 cups of water will leak out of the hot water tank as you check drain valve thread size. DO NOT take your time checking thread size. After you know the pipe thread size go to the hardware store ( Home Depot, Lowe's etc) purchase a short nipple (1 1/2 to 3 inch depending on available space) and a ball valve (brass) due to the water temperature. You will also need a brass adapter for pipe thread to garden hose thread (male both ends). This adapter goes into the ball valve to allow for the connection of a garden hose. Connect the pipe and valve together using the correct pipe thread sealant and install in place of the original plastic drain valve. Install pipe to hose adapter using thread sealant. With the ball valve in place turn the water back on. Gas or electricity back on. Connect a garden hose to the ball valve. Place the other end of the garden hose in a safe area as hot water and debris will be expelled through the hose. With water on, Gas or Electricity on and the relief valve closed actuate the ball valve to the full open position for approximately 3 seconds then close the valve. Repeat the open and close of the ball valve three times. Observe the debris that emptied out of the garden hose. You may be surprised at what you see. If the water runs clear, disconnect the garden hose the task is completed. You can wait until the following year to repeat the process. Your pipe and valve are now a part of the water heater, they may remain in place. Put the hose away.
Aug 31, 2015 | Water Water Heaters
Golf rules questions
if the ball had been abandoned no, if belongs to someone in your group, yes
Aug 18, 2014 | Cars & Trucks
Washer stopped. F6 code, didn't drain.
that is called an eco ball it is part off the machine
its job is to save money by not heating the water below it in the drain pipe
Dec 29, 2013 | Kenmore 46462 Front Load Washer
The front drain is leaking
Hi there.
Check first if there are no foreign objects hangings on the ball causing leak.
If you really need to change the ball valve, cling the jaw of a 14-inch pipe wrench on the neck of the valve connected to the fryer drain and turn it counter clockwise (***do this with no oil on fry tank and make sure that the tank is cold).
Wrap a teflon tape on the thread before installing the new ball valve.
Regards.
Jul 21, 2013 | Pitco Frialator SG14 Deep Fryer
Whirlpool AWM6120 - small ping pong size ball found in black drain part????
The ball is supposed to be there. It should be in the drain hose at the bottom of the drum. It is part of the eco system of the washer. In the service manual its called an "eco lock"
Oct 13, 2012 | Whirlpool AWM6120 Front Load Washer
After removing the bottom assembly from my frigidaire dishwasher to clean it, I reassembled it and now the spray arm won't work although the machine fills and drains. I found a small white ball in the...
The ball goes under item 10 this picture:
http://www.appliancepartspros.com/partsearch/frame_diagram.aspx?diagram_id=381580&pkw_=basket&model_id=5120395&NewWindow=1
You can enlarge the picture once opened. The Expert Gene Strote was correct. I just like this picture better because you can instantly expand it with explorer.
Manual Number 5995477345.pdf is a service manual not for your unit but will show you the sump and were the ball goes.
http://appliancedigest.com/index.php?/files/file/147-frigidaire-fully-integrated-direct-feed-model-dishwashers-5995477345-service-manual/ (registration required)
A service manual that will show you the sump area and the ball.
Thanks for choosing FixYa, and myself.
Kelly
Jul 30, 2011 | Frigidaire 24 in. FDB510LC Free-standing...
Should there be a ball in the drain hotpoint
yes the ball should be in there,but shouldnt cause you any major problems if removed.
Aug 03, 2009 | Hotpoint Aquarius WF220 Front Load Washer
Washing Machines Logo
16 people viewed this question
Top Washing Machines Experts
