Question about Panasonic KX-FLM600 Printer
I am having problems with toner
My towner ran out and I replaced it and now my copies and faxes com out really dark all over.
  • Jeno2320 Dec 12, 2007
    Faxes I receive print dark all over and cannot be read. The first page of a fax is readable however subsequent pages are not readable--the additional pages are pitch black.
  • 98 Answers
Can you try a different toner cartridge ?
Posted on Jul 22, 2007
SOURCE:
We are getting black faxes and dark grey copies
I recommend to clean out an optics. Take apart a cartridge and well blow through, clean the rollers and contacts.
Jan 14, 2010 | Brother IntelliFAX 4100 Laser Fax
Thick Dark Line on received and copies of faxes
don't know the model of machine, but usually caused by the drum unit or toner cartridge. many machines have both drum and toner in 1 unit. try replacing.
Nov 18, 2009 | Televison & Video
Sent faxes not printing clear
Per Brother's User manual,
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_IntelliFax_4100_4750e_5750e_EN_98.PDF
Clean the machine’s interior and the primary
corona wire of the toner cartridge This is a common cause for your printing/copying problem. This should solve your issue. Best of luck.
Greg
May 20, 2009 | Brother IntelliFAX 4100 Laser Fax
OKI 4550 fax
try to boot the front cover and clean the glass over the lens
Dec 29, 2008 | OKIFAX 4500 Plain Paper LED Fax
Cartridge dumping toner? dark copies.
Check the drum- if there is any lines or ghost images replace it if not its problem with fixing unit.
Be sure that you cleaned your copy glass.
Pls. send the model of your machine.The G3 is fax protocol
Nov 25, 2008 | Canon - SUPER G3 FAX BOARD-T1 (0450B002AA)
Fax prints to dark
have you replaced the drum??? are you using brother oem toner???? generic toner will give you all kinds of problems
Oct 29, 2008 | Brother IntelliFAX 2800 Laser Fax
Paper has dark marks down middle
If you make a copy, does the copy have dark areas down the middle of the page? If so, remove the toner cartridge and gently roll it around to redistribute the toner inside, maybe even replace the toner cartridge if you've had it a long while. If you still see unevenness, you may need to have the machine looked at.
If the copies you make on your machine look fine, then I would suspect that the person sending you the fax has a dirty scanning element. Check with them to see if they can clean the scanning element and it should improve the fax quality.
Oct 23, 2008 | Canon FAXPHONE L170 Plain Paper Laser
Black Copies
is there toner in the machine ? ( toner spill)
check the manual for the location of the glass, in the maintenance section, if it has toner on it copies will be black or dark, other wise the scaning glass is bad
http://www.retrevo.com/s/canon+7000+manual
Dec 31, 2007 | Canon LaserClass 7000 Plain Paper Fax
Copies and outgoing fax quality
your machine most likely has toner spills in it.
if you send faxes face side down follow these instructions ;
1- take out toner
2- look for thin glass strip on bottom inside the machine
3-wipe clean
if you make copies side up then do the same except look for glass strip on the upper side of machine
Nov 27, 2007 | Brother IntelliFAX 4100 Laser Fax
64 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Shannon Murphy
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
