Question about Philips Magnavox 50ML8105D 50" HDTV DLP TV
Have no converter for my tv
I want to adjust the colour on the tv via the tv buttons, how can i do this
  • perrym29 Jan 27, 2009
    the only buttons on the tv are, volume, prev/play/next, stop open/close, output dv/vcr chaneup/down, eject/stop
    the tv does not have a menu button
    Genius:
  • 2,920 Answers
You have to use the menu button on front of the tv and go to the picture controls and it should take you to the color control
Posted on Jan 27, 2009
  • Ronnie Houston Jan 27, 2009
    there has to be a button there to take you to the menu for the color contrast etc...all tvs have them or i guess i should say most tvs do ...there is a button there somewhere for you to set the picture colors and all the rest.
Why screen shows different colours than the originals?
there are colour settings in the menu or buttons at the side of the screen. Use them to adjust the colour or have the tv repaired by a technical shop
Mar 30, 2015 | Televison & Video
Why cant i change the tint of my picture? the menue keeps skipping the tint option
If you're watching UK TV broadcasts then we don't have a need for tint. Similarly, with HDMI sources you shouldn't need tint either because the TV's colour decoder isn't active.
Tint is a throw-back to the American analogue TV system called NTSC. Their system doesn't lock the colour phase to the sync signal. So depending how far the TV was from the transmitter the colour would be further and further out of whack. Hence the industry joke that NTSC stood for Never Twice (the) Same Colour ...N - T - S - C. The Tint control was used to re-time the colour signal. The UK didn't have this issue because our TV system (PAL - Phase Alternate Line) includes information to lock the colour signal phase.
Strictly speaking, Tint is only required with NTSC analogue composite signals. This is where the brightness information is mixed with colour on a sub-carrier frequency. So, that would be signals via an aerial lead or from the yellow video connection which is how most of us first see a composite signal. These signals are encoded as NTSC. Any signals where the colour and brightness (luma) information is kept separate shouldn't need Tint. So, S-video, Component and RGB at 60Hz all bypass a TVs NTSC decoder. If the TV is correctly designed then the Tint option should not be available. Some TV manufacturers break the convention though, for the simple reason that many old school US consumers grew up adjusting Tint, so it's too much of a culture shock to take away that feature.
To recap then, if Tint isn't available then it's because the signal doesn't need that adjustment. The colour timing is already bang on accurate.
Sep 16, 2014 | Televison & Video
Laptop to TV rolling screen
Difference in vertical frequency between TV and converter.Adjust colour settings PAL or NTSC on both TV and set top box.
Apr 08, 2014 | Televison & Video
I have an aspire one laptop and a video convertor.
Are you connecting the svga out of the laptop to hdmi of tv via a converter? This set should have an svga input on it. try connecting this directly to svga on computer. Computers and converters and hdmi inputs on tvs are always a challenge. Newer laptops have hdmi outputs on them and are seem to work better.
Jan 05, 2014 | Panasonic TH-50PX50U 50 in. Plasma HDTV
To adjust the colour and brightness of the tv
yes there should be a menu button, normally in the middle of the remote, than you scould be able to change all your settings.
Apr 19, 2012 | Televison & Video
Theres no brightness setting in menu. it only has cc sleeptimer and exit. how do i change the brightness?
Hello
You can adjust the brightness control on your 19PR19 Philips Tv. For that you have to go to picture contol menu
Do it as follows
To adjust your TVs picture control, select a channel and follow these steps.
[1] Press the Menu Button on the remote control to display onscreen menu.
[2] Press Cursor up or Cursor Down button until the word Brightness is hilighted. For each press of Cursor Up or Cursor Down button you can go through Colour, Picture, Sharpness, Tint, Colour temp etc, depending on the adjustment you want to make.
[3] Press Cursor right or Cursor Left buttons to increase or decrese the selected option. Ok.
Nov 17, 2010 | Philips 19PR19 19" TV
Convergence problems, can't find any access to adjust via menus.
NO !! You can't adjust that out. You have a convergence failure. You need to take it to a shop. You won't be able to fix it yourself. The more you adjust it the more ANY shop is going to charge you to fix it. Let me know how it turns out.
Oct 14, 2008 | RCA P61930BL 61" Rear Projection...
No sound on TV
If you do not get result you can purchase one video rf converter. Rf converter contains one video input in yellow colour and two audio in red and white colour and one cable connector as outout. Connect dvd output to this converter and tune the program in which place you receive dvd signal.
Sep 16, 2007 | Durabrand DWT1905 TV
Philips Magnavox 50ML8105D 50" HDTV DLP TV Logo
18 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
