Question about Sony KDL-52XBR5 52 in. LCD HDTV
My sony kdl-52xbr5 52 in. has double images within the first 7 minutes
Images appear doubled within the first 7 minutes when you start the tv and after that everything appears ok, What can be the cause
  • Sony Master
  • 933 Answers
Sounds like you have a bad LCD panel. Go to youtube and search Sony LCD tab problems, and you will find several videos showing you the problem and possible fixes!
Posted on Jan 30, 2013
SOURCE: Sony XBR4 - 46 inch Double Imaging and 1/2 screen dark
Sorry not a solution...We also have exact same problem (TV about 1.5 years old) - out of warranty - all Sony told me to try was to un-plug TV for 2 minutes - useless. I am trying to decide if I should bring to service store to try to fix. I hate to spend a couple of hundred dollars to find out it costs $2000 - less then a new one. Anyone have any suggestions?
Posted on Oct 23, 2009
tvhelp-Dave
  • 178 Answers
SOURCE: When we turn on the tv, the left side of the
I think 80% is the panel, and other 20% maybe the t-con board or LVDS cable. rock the cable or cool down the t-con to test it.
Posted on Apr 27, 2010
Testimonial: "We had sent it out to a repair shop and was told that, after replacing the board, it WAS the panel..which is $3000 for the part and $300 for the labor"
stihl_070509
  • 95 Answers
SOURCE: I have a Sony KDL40W4500
hi,
T-Con board failure or poor connection of flexible wire and LVDS cable. Sometimes these connection loosen up from their terminals. Try to unplug and reconnect these cables to refresh the connections. If the symptoms still persist you need to replace the T-Con board. T-Con board is installed on the upper side of your LCD TV and it has two flexible wire connected to LCD PANEL . stihl_070509.jpg
Posted on Jan 05, 2011
SOURCE: Sony Bravia LCD KDL 46V4100 has distortion with
I have this exact same problem on my same model TV. It started just before Christmas. Have you been able to find any resolution?
Posted on Jan 07, 2011
bukol
  • 84 Answers
SOURCE: On power up of my Sony KDL52Z5100 I get horizontal
side fittings or lack of contacts of the logic controller interface to lcd panel.
Posted on Feb 25, 2011
My Sony KDL-32S3000 picture is getting dark
It sounds that the main digital board to your TV is faulty. Contact any experienced service technician.
Oct 21, 2012 | Sony KDL-32S3000 32 in. LCD Television
Upgraded to Hd and tv started messing up. Double images for first 10 minutes and sometimes tv picture goes off and lines up and down.
Your HDTV is capable of up to 1080P resolution. SDTV (standard def) signals are 480i; EDTV (enhanced def) is 480P; HDTV are 720P, (there is no 720i) 1080i and 1080P. Generally, those modes ending in "P" look better than those ending in "i". 1080i is the highest possible for broadcast TV, but BluRay disks and Directv have 1080P display capabilities.
The double picture you're describing sounds like the TV is set to display only standard or enhanced def signals while the Dish Network box is supplying it with HD signals. You should locate the control for the TV's resolution and make sure it is set to "1080P" and then set the output of your Dish Network set top box to the highest output it offers. Do the same for your BluRay player and any other devices, too.
Once set correctly, you should have a great picture once again. I hope this helps & good luck!
Sep 04, 2012 | Sony KDL-40XBR4 40 in. LCD HDTV
Tv shows double images
This is a problem within the convergence circuit. If you can solder you should be able to repair this yourself. Let me know if you wish to attempt the repair and I'll provide additional details and instructions.
Dan
Jan 27, 2009 | Toshiba 55H70 55" Rear Projection...
Double picture at star up
if you have cable telivison try unpluging the cable from wall and tv the replugging it. make sure the connections are secure and also make sure the cable is plugged in straight. or your cable might be bad.
Jan 09, 2009 | Sony KDL-40XBR4 40 in. LCD HDTV
I am getting double images while watching TV;
There maybe some loose components on the circuit and that needs resoldering. Bring it to the repair shop to done.
Dec 02, 2008 | Zenith C27A24T 27" TV
Panasonic PT-51HX41 rear projection tv showing shadow/double images.
Unplug the TV from the ac wall outlet for about 4 minutes then plug it back in and turn it on. If it still has a double image then tell me if it's affecting the menu screen from the TV (not the cable menu). And is the double image in red and blue?
C-Dog
Feb 18, 2008 | Sony KP-41T65 41" Rear Projection...
Sony KDL-52XBR5 52 in. LCD HDTV Logo
680 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
