Question about Panasonic SCBTT770 Theater System
Panasonic SC-BTT770 Sound muting automatically
I have the Panasonic SCBTT770 Theater System and for some reason when i play Xbox or watch DirecTV (both hooked up to the BluRay player that comes with this), the sound will randomly mute itself (turn all the way down even when its up at 20) about 15 minutes into play. Ive found if i turn it off and back on, sometimes the sound doesn't mute itself. But this happens everyday. And has been since i set it up. :(
tech48
  • 624 Answers
SOURCE: Panasonic home theater system pt760
Make sure you have put the transmitter for the wirless speaker in the slot on the back of the reciever, it is a slim white device that is about 3 to 5 inches long?? and maybe half an inch thick. and make sure it is put in the right way.
Then make sure the wireless speaker is plugged in to the wall outlet.
If this does not work for you it may require being taken in to an authorized panasonic service center. when one part of the wireless system fails (transmitter or reciever) they both must be replaced. they are not interchangable from one panasonic to another.
They have a code in each unit that lets the wireless speaker that came with it only work with the reciever it was sold with.
I have even seen times where the store that sells them swapped the transmitters of two units and then they had two customers very mad at them because the wireless speakers did not work for either person.
Let me know if I can be of any more help.
Posted on Jun 19, 2008
tech48
  • 624 Answers
SOURCE: intermittent sound with Panasonic SC-HT900 home theater system
I will get back with you on this tommorow with more information when I can get the technical data I need from where I work.
These units are know for the problem you are describing.
If you have to connect all of your speakers to the subwoofer, then yes, you can replace the subwoofer and it will fix your problem. I just don't remember right now if this unit is the one with the amplifier built into the sub woofer, but I think it is.
Since you paid another repair center you really should take it back to them to fix it right. They probably did not test it long enough to verify if they fixed your problem.
I know it is a real pain to have to take it back, more so if it is far away, but the problem you are having is nothing you will be able to fix yourself unless you have some decent electronic troubleshooting and soldering skills.
Get back with you soon,
Dave
SOURCE: cant get my viera linked panasonic to play through surround sound
I had the same problem, so i contacted panasonic, I am including the email they sent me.
For connections of audio, so that you can hear all tv audio through the
surround system, connect either an optical audio cable or red & white
analog audio cables from the tv to the home theater. If you are using
optical audio, there is a plug on back of tv labeled for digital audio
output and an input on the surround sound system. If you plan on using
analog red and white, use the PROG OUT red and white output jacks on the
back of the tv to the AUX input on the home theater.
For video connections, to get HD you will need to be using either HDMI or
Component cables. HDMI is the cable that will provided 1080p signal (the
best HD signal), but if the source does not output 1080p, then your tv
will not display 1080p. Most cable boxes output at 1080i or 720p when on
HD stations. This signal still provides great picture quality, but HDMI is
not needed to get these HD signals. You can use component cables for your
cable box and the DVD player output to the tv for video. HDMI might give
you a slightly better picture quality but the signal will be the same.
To make the connection, you will want to connect from the cable box to the
tv (component or hdmi). Also from the home theater system to the tv using
hdmi or the video cables from component (red, blue, & green cables).
We hope this information is helpful to you.
Thank You,
Panasonic Consumer
Posted on Dec 17, 2008
SOURCE: No sound through the Panasonic cinema surround sound on TV
Had a similar problem mate. I solved it by connecting the tv to the PT460 system with a scart lead. You then have to have the AV channel selected on the PT460 system to listen to the tv. You will always have to have the AV channel on the PT460 selected to listen to any sound transmitted through the tv - be it playstation/xbox or any other device that you may connect in the future with HDMI leads or otherwise. Hope this helps
Posted on Jan 04, 2009
SOURCE: I have the Panasonic SC-BT100
Cooling fan is probably dirty or not running. Check the fan by removing it with the two screws on the back and make certain that it's plugged in and the short, black wire (that appears to go to nothing) is "securing" the plug to the board.
Posted on Apr 14, 2009
Plasma tv/home theater
Is your Panasonic set to monitor the HDMI input? Just like selecting a mode input on the Tv you must also select the mode input on the surround system.
Bill
Dec 07, 2007 | Televison & Video
Youtube videos wont play
It seems like you have a software problem.I cannot help you,you have to take it in for repairs.
Dec 05, 2011 | Panasonic SCBTT770 Theater System
Hooking Up Panasonic sc-ht670 home theater to Dish DVR 625 and Panasonic TH-42PHD7UY Plasma TV
You will need to run a set of audio cables from the TV1 output on the rear of the 625 directly to one of the three audio inputs on the surround system. Thanks for using Fix Ya.
May 13, 2009 | DISH Network DVR-625 DTV Receiver /...
I have the Panasonic SC-BT100 Blue-Ray Disc Home Theater Sound System, and whenever we watch a dvd it plays fine and after a while the tv turns blue but the sound goes off.. after a while it will come back...
Jan 03, 2009 | Panasonic SC-BT100 Theater System
Its possible connect a 5.1 sound pc card to Panasonic SC-HT500 hearing the 6 separate channels?
I am afraid the answer is no - this particular Panasonic will only play full surround when watching DVDs. It does not have the right inputs to grab more than stereo sound from your computer.
-Tha Mp3 Doctor
Aug 10, 2008 | Panasonic SC-HT500 System
Panasonic SC-PT850w sound cuts out
Are you watching 10HD off the air from an antenna? You are losing video and audio intermittently, which may just be indicative of a weak signal. Does your TV have a signal meter?
Apr 27, 2008 | Panasonic Home Theater System System
Panasonic SCBTT770 Theater System Logo
41 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
