Nexxtech Microphone Does not work
Nexxtech microphone
form a full question.
that was a statement.
Sep 29, 2013 | Computers & Internet
Webcam lag
That website doesn't work properly anymore please help, my nexxtech cam is waaaaaaaaaaay too slow.
May 25, 2012 | Computers & Internet
Nexxtech camera/skype/
Open skype go to tools options scroll to audio settings or video settings on the right you will see webcam setting you can change the settings from there click apply after changing any settings also you can see the webcam there you can even take a snapsot also make sure your settings are correct for a video call
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick
select audio from the microphone drop down list make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or
select the voice tab and make sure that you have the right media selected also select volume make sure the box for microphone has a tick in it
hope this helps you
Nov 25, 2011 | Computers & Internet
Nexxtech n2000 The manual says CD-R with "Digital"
I'm pretty sure it actually says something to the effect of "These discs are marked with "Digital Audio" and the logos shown below...', the operative word being AUDIO.
DATA discs do not work on a consumer CDRecorder.
Jul 09, 2011 | NexxTech N2000
I have nexxtech portable kit with a hard drive in it, it worked on windows xp, but winds 7 doesn't reconize it How do I fix this
Try your NexxTech on some other computer, to verify that it still works.
Try some other USB port on your computer.
Try some other USB device into the same USB port that you are trying to use for your NexxTech, to make sure that your computer's USB ports are working correctly.
Check that Windows 7 has loaded the device-drivers for your USB 2.0 ports on your computer's motherboard.
May 14, 2010 | NexxTech Portable Hi-Speed USB 2.0 Kit...
NO INSTALATION DISC TO MY NEXXTECH MOUSE MODEL#NWOMUMI
try to plug in then the machine may be recognize it automatically
Jan 15, 2009 | NexxTech NWOMUMI Mouse
Cannot get wireless keyboard mouse to work nexxtech model nwkbmcb
You can find the drivers here: http://www.nexxtech.com/nexxtech_usa.html
Hope this helps & please remember to rate my answer. Thanks.
Dec 31, 2008 | NexxTech NWOMMI Mouse
Video not showing
check the usb for working sometimes they do not
On my computer one works with anything but the other will not recognize the mouse
Jul 27, 2008 | Computers & Internet
NexxTech DP3222 DVD Player
Open tray, press on the remote, stop-2-3-7-9, press arrow down until 0 and press ok.
Make shure you put TV TYPE --> ntsc in the general setting
I tried this (on a multisystem set that can be "made to think" that it's a PAL or NTSC set as the case may be) and it worked. The Nexxtech DP3222 and the Entiveo DP3220 are basically the same unit except that (a) the hack for the Nexxtech doesn't require resetting every time you turn the unit on and off, unlike the Entiveo (this is really annoying) and (b) you can set the Nexxtech to multisystem, NTSC, or PAL standards, whereas the Entiveo is NTSC-only, but (c) the fast-forward on the Nexxtech is somewhat less intuitive than on the Entiveo (involves holding a button down). All in all, I prefer the Nexxtech, if only because it is more easily hackable. And I would have sworn that the Nexxtech had a blue screen saver on it before I started hacking it, because now it has a really gross-looking black-and-white screen saver. But I don't care about screen savers as long as the unit does what I want it to do.
Jan 28, 2008 | NexxTech DP3222 DVD Player
Programming my nexxtech 3-in-1 remote control
looking for instructions for  remote control nexxtech 3 in 1 universal
Oct 28, 2007 | Televison & Video
18 people viewed this question
 Grubhead
Grubhead
