Question about Motorola Talkabout FRS 250 (14 Channels) 2-Way Radio
No trasnsmission coming out of the speaker on one. 1 works ok and the other one doesn't
Can't get radio to communicate but channels are right
  • Motorola Master
  • 3,904 Answers
I don't know if the smaller ones like what you have operate the same as my 2 watt motorolas but I have a sub frequency on top of the channel. Check into that.
Posted on Jan 23, 2013
My rear speakers won't work in my 2001 Malibu. Stock system and wires to speaker okay. fader set Correct. Could it be speakers are junk?
Get a known good speaker an hook it up in place of the old ones an see if it works , if it does the old one is no good . Now if it doesn't work the radio isn't set correctly or that channel of the radio is blown .
Oct 23, 2016 | 2001 Chevrolet Malibu
I have two T5510 Motorola. Walkie talkies and when
Good job describing. The channel is the channel number, the upper right is the "tone". If everything matches, they should talk to each other. Try pressing the squelch button on each to make certain the speakers work. It is also possible the mic openings are clogged with debris or the audio jacks have something in them. If the audio jack has a broken pin or even debris in it, it is possible the speaker will remain muted. If you are using audio accessories, unplug them and turn the radio off/on. Do you have a tone on power up? Other than that, how old are they? Do you know the history? If they got wet, corrosion likely set in and you need new radios. Yes, I know some say waterproof, they mean resistant.
Sep 04, 2014 | Radio Communications
Chat live
1) you must the headphones in any radio, for to see if the problem they are.
2) if they are o.k go control panel use the utility system restore put the last date that you know that was working.
God bless you
Jul 25, 2013 | Sony VAIO Computers & Internet
Right fader knob doesn't do nothing. No sound come out from my right speaker when I turn the right knob up
PV series mixers from peavey suffer from horrible sliders pots quality, so be prepared to change that pot, it is pretty easy to change, real difficult comes out when you are trying to reach it, let me know a bit further to help you out troubleshoot accurately the issue.
Jan 18, 2013 | Peavey Pv 20 USB 20 Channel Mixing Board...
One of my walkie talkie's transmits but doesn't receive...WHY?
Your speaker is blown. The microphone still works but you can't hear any audio. Take it back if there not to old.
Nov 01, 2012 | Motorola TalkAbout T6530R (14 Channels)...
MY REAR SPEAKERS ON FOCUS 2007 HVE STOPPED WORKING DOES ANYONE KNOW WHAT FUSE COVERS THEM SO I CAN CHECK IF BLOWN ?
There is no fuse to the speakers your rear speaker wires should run under the kick plateon drivers side broken or disconnected wire or burned out channel in radio.
Oct 21, 2012 | Cars & Trucks
Toyota Corolla 1997 I've installed kickers in the rear (KS series to match the front)... had those going for a couple of weeks with no problems. Yesterday i went to install the KS400 series in the...
take one of the front speakers out and pull out the head unit and unplug a set of audio wires(front right, front left ect.) and hook it up directly from the radio to the speaker there for bypassing all the cars wires. If it works then there's a problem with the car's wiring(maybe an inline amp). If it doesn't work, then try a known good speaker from somewhere else(home stereo speaker for example) and connect it to the radio, if the speaker works, your radio is fine and there may be a problem with the speakers. If it doesn't work then you have a problem with the head unit.
Jul 22, 2011 | Kicker KS400 Coaxial Car Speaker
Hi, I have a 3 year old Onkyo TX-SR506 receiver that I bought secondhand. The receiver can get very dusty so I was cleaning the top with a damp cloth while listening to music. Suddenly the music stopped...
I don't think its a harmless coincidence that it happened while you were touching it.
Assuming 'damp' means 'no dripping' I'd discount mositure as the cause. Was there something else you may have touched or caused to move during your actions, like speaker wires? Retrace your steps (with power off) and imagine what may have moved.
Disconnect the speaker wires at the receiver and see if that helps. If so, you just need to start adding speakers until it fails again or not, then isolate the cause if it is related to specific channel(s). If it doesn't come up 'naked' something cooked inside and a hands-on tech needs to get involved.
In the future - turn it off when manilpulating anything on, near or attached to it.
Jul 12, 2011 | Onkyo TX-SR506 Receiver
Display doesn't work
THERE ARE 2 DIFFERENT POWER WIRES CONNECTING THIS PLAYER TO 12 VOLTS FROM YOUR CAR ... ONE WIRE MAKES THE UNIT WORK WHEN THE KEY IN YOUR IGNITION IS SWITCHED ON AND ANOTHER THAT HAS 12 VOLTS ALL THE TIME TO KEEP THE RADIO CHANNELS PROGRAMMED AND SUPPLIES MAIN POWER TO THE UNIT , MY GUESS IS
THE WIRE THAT CONNECTS TO IGNITION HAS COME APART AND THIS LEAVES YOU WITH
NO DISPLAY ...... CHECK IT ........
Jun 10, 2011 | Car Audio & Video
We bought two Maxon S1 walkie talkies. They do not work. We have tried all the channels (1-8) and several privacy options, but even at ten metres we cannot communicate. Sometimes voice comes through but...
I had the same problem. Take your radio to the professional service. One was ok, but the second has problem with frequency keeping. They shown it on a scanner. The second problem was settings. The output power was set 25 mW, and the band was set wrong to the long range communication. Only professional service can fix it.
May 09, 2011 | Maxon TK14-1B (14 Channels) 2-Way Radio
Motorola Talkabout FRS 250 (14 Channels) 2-Way Radio Logo
59 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Greg Cann
Greg Cann
SHARCNET-USA
SHARCNET-USA
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
