Question about HP LaserJet 4650 Color Printer
Error msg on HP4650dn
Error msg is 81.0180 E10 1 error , will not perform a calibrationalso.
    Genius:
  • 2,120 Answers
Unplug printer
remove network card and cable
plug printer in & turn on.
wait for boot sequence
unplug printer
reinstall network card and cable
plug in / turn on.
If it wont calibrate, you have a bad toner cartridge.
use only GENUINE HP
Posted on Jan 28, 2009
Error msg 5010 how to reset
The scanner unit cannot detect the home position, or
the scanner unit warming-up is not performed
properly at power-on. You can not reset the error. Flat cable or scanner unit is defective, if you are lucky it is just stucked.
Apr 02, 2016 | Canon PIXMA MP600 all-In-One InkJet...
Need help trouble shooting stuck on black screen dell inspiron 1720 so ran Diagnostics this is what i get backError code 0148 Msg:error code 2000-0148 Msg: unit 0:Ide error: status 1A error registry 0020h...
Error Code 0148
msg: Error Code 2000-0148
msg: Hard Optical Drive 0 - incorrect status 1 A Error
Register: 0020h
sense information: (02-0401)
sense: 70h 00h 02h 00h 00h 00h 00h 0Ah 00h 00h 00h 00h 04h 01h 00h 00h 00h 00h
Sorry but you have a hard drive issue. Replace the drive.
Mar 10, 2014 | Computers & Internet
TI89 is has locked up with error msg "undefined variable"
Without performing a hard reset, you can avoid implied multiplication and insert a multiplication sign (*) between a variable and a function. For example if you enter xsin(x) you must insert the multiplication sign (*) and write x*sin(x), otherwise the calculator will assume that xsin( is a function. It will look for it and not finding it, will send an error message. Similarly, if you want to enter x times y or some othervariable, you must insert the multiplication sign, x*y
Mar 06, 2012 | Texas Instruments TI89 Graphic Calculator
N73 when i try to open bluetooth application it show error msg as unable to perform bluetooth operations wht to do ??????? please suggest once i had already restored by*7780# still same problem continues
The error massege shows as unable to perform bluetooth operations when memory is full.
Try to delete some of the data applications and try to perform the bluetooth operation.
Even if you find the same problem to perform bluetooth the remove the battery when the mobile is switched on and remove the sim and reinsert after 2 mins.
Hope I helped you.
Thanks for using ' Fixya ' and have a nice day!!
Nov 09, 2009 | Nokia N73 Cellular Phone
D610 DST Short Status Test Fail
It appears your hard disk has died and it may not be possible for you to retrieve your data.
Remove your hard drive from the laptop and insert it into an USB harddrive adapter, (they are not expensive and you can use it later as a external hard drive). Then plug it into the USB port of a working computer. The computer should/may see it as an external drive, if you are lucky you will be able to copy your data, if not, you are out of luck.
There are companies that can recover data from faulty hard drives, but it will cost you an arm and a leg for their service.
Feb 17, 2009 | Dell Latitude D610 Notebook
Print not comming
my printer hp 2300 print only on page
Sep 17, 2008 | HP LaserJet 2300 Printer
I/O ERROR DEVICE MSG
i had same problem..couldn't solve it with tape over the lock switch and many other ways.. so i purchased a usb card reader (about $5 max) and now it works fine!..make sure the lock is off!
Jun 12, 2008 | Generic Memory PCI USB and Firewire Combo...
Unable to defragement the system
xp will not allow defrag on disk requiring error checking. run error checking utility first.
Sep 03, 2007 | Intel Thread Checker 2.1 (ITC021WSGB001)...
HP LaserJet 4650 Color Printer Logo
477 people viewed this question
Ben Johnson
