Question about Panasonic PT-61LCX65 61" Rear Projection HDTV
Unlocking Panasonic pt-61lcx65 don't have lock code
Slinteriors
  • 8617 Answers
SOURCE: Panasonic large screen Model # PT-61LCX65
Here is the proceedure to replace the lamp and reset the lamp hours.
Lamp Replacement Procedure:
1. Press the POWER button to turn off the power.
2. Wait for about 1 minute until the cooling fan stops.
Note:
The lamp cooling fan will continue to operate for about 1
minute after the power is turned off. Do not unplug the AC
Cord from the outlet until the fan has stopped. Avoid
interrupting the power by using circuit breakers or switchable
power strips.
3. After the cooling fan has stopped, unplug the AC Cord from
the outlet.
Note:
Please wait more than one hour before replacing the lamp.
[ Forced cooling function ]
If you need to replace the lamp more urgently:
- The Projection display has a forced cooling feature.
After the POWER button is turned OFF, and during the
first minute of the normal cooling fan operation, press
the VOLUME UP button on the unit and CH UP key on
the remote at the same time for more than 5 seconds.
The cooling fan operates for about 10 minutes. (LAMP
LED will flash 5 times every 5 second and POWER LED
will flash red for 10 minutes.)
4. Remove the Front Cover Unit from the latches.
5. Turn the Knob to the left.
6. Pull the Lamp Cover out.
7. Loosen the Screw on the Lamp. Then, pull the Lamp.
Note:
Because the Lamp may still be hot, use caution when
handling.
8. Install the new Lamp, and tighten the Screw.
9. Install the Lamp Cover, and turn the Knob to the right.
10. Install the Front Cover Unit.
Lamp Time Reset Procedure:
Be sure to reset the Lamp time to "0" after replacing the new
Lamp.
1. Plug in the AC Cord, and turn on the power by pressing the
POWER button.
2. Press and hold the VOLUME DOWN button on the unit and
the SPLIT key on the remote together for over 5 seconds
in power on condition.
When the reset is finished, the display will indicate that the lamp hrs have been reset to 0 and the LAMP LED goes out.
Posted on Jul 26, 2008
SOURCE: Panasonic PT-61LCX65 Bulb Reset
hold the volume button down on the t.v. & the split button on the remote at the same time for about 8 to 10 seconds.The t.v. tech. did this with my panasonic 61lcx65. Also I had 2 fairly large red / orange & 1 blue spots on the screen which I thought were a result of the bulb being bad , but the tech. attached a device he called an eeprom jig & it reset the chip ? Now the picture is like new again.
Posted on Sep 20, 2008
  • 159 Answers
SOURCE: panasonic PT-61LCX65 tv has color spots
if you mean color spots size of a dime or so.
  • easiest: it is dust in some step of the projection light path.
  • hardest: the light engine could be damage
if you mean little ones as little dots (a neddle punshing) red and blue but always there:
  • condition call it: pixels always on: light engine is the reason.
as you see the light engine is the main part here, IT is expensive repair. so if you can survive with those little dots do it.
IF it is dust, is good idea asking for and estimate to see if can works.
Posted on Apr 18, 2009
freetek
  • 5568 Answers
SOURCE: Vertical lines across screen on my panasonic tv PT-61LCX65
Try setting a portable fan aimed toward the cooling vents on the back of the set. If this eliminates or reduces the occurance of the lines, this means a circuit that controls the off/on of individual pixels has developed a thermal problem. This circuit is ordinarily loacted on the main circuit board and is likely to degrade further. You might inquire at the Panasonic service center if they have an exchange program in place and they will probably be able to confirm my suspicions.
Posted on Aug 09, 2009
  • 65 Answers
SOURCE: Blue & green star like spots on Panasonic rear projection LCD TV
The EEPROM needs to be reprogrammed. You should contact Panasonic customer care as they may fix this at no charge to you.
Why wont ps3 play out of hdmi port or input connections on Panasonic PT-61LCX65?
becaue you need to enable hdmi on the setting of your TV and perhaps you also need to adjust to the same HDMI value in both PS3 and TV Menus
Apr 01, 2015 | Panasonic PT-61LCX65 61" Rear Projection...
Panasonic pt-61LCX65 osd air filter cleaning came on screen and the unit shut down in 1 minute. I would like to know exactly where the air filter is where I can clean it myself.
This is stright from Panasonic.
The consumer is not able to change the air filter. It will have to be done by an
authorized Panasonic service center."
Jan 22, 2010 | Panasonic PT-61LCX65 61" Rear Projection...
I replaced my lamp on my PT-61LCX65 last year and
Depending on how much you watch this set the lamp could be out again, they don't have to look blown to be blown.
Sep 04, 2009 | Panasonic PT-61LCX65 61" Rear Projection...
LAMP RESET PANASONIC PT-61LCX65
I am sending the instructions to your email address now.
Jun 08, 2008 | Panasonic PT-61LCX65 61" Rear Projection...
Please send me the instruction on lamp replacement
sorry I dont have the instructions for panasonic. but it should be straight forward remove the back and the lamp housing should be right there.
Mar 14, 2008 | Panasonic PT-61LCX65 61" Rear Projection...
Panasonic projection tv
call panasonic, bulb blown under warranty for 18 months the bulb is 284.00 just had mine replaced. it's a little over a year old
Dec 27, 2007 | Panasonic PT-61LCX65 61" Rear Projection...
Panasonic PT-61LCX65 61" Rear Projection HDTV Logo
35 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
