Question about Xerox WorkCentre XD125F All-In-One Laser Printer
Waste ink reservoir
Where is the waste ink reservoir? Is it on the end of the toner cartridge?
millerfam805
    President:
  • 8,637 Answers
Here is Information that should help. Bud
Information
To get answers for any other questions you might have regarding your
WorkCentre, to register your warranty by phone, or for assistance with the
installation of your WorkCentre you may call:
1 – 800 – TEAM – XRX (1 – 800 – 832 – 6979)
Posted on Jan 27, 2009
How to reset toner ended
Do you mean waste ink cartridge reset? Post your exact printer model number and I can try and help you further.
Mar 15, 2015 | Office Equipment & Supplies
Changing waste container
The is no waste container on Phaser 6500. There is a "waste collection box" in every toner cartridge and the waste toner is discarded along with the empty cartridge. The is also a waste toner reservoir on the transfer belt and this one will be replaced along with the transfer belt.
If there is an error message saying, for example, "Waste Full Cyan Cartridge", it means the waste toner counter reached the replacement value for that color and you have to replace the corresponding cartridge. But the waste collection box is not really full.
Sep 30, 2012 | Xerox 6500/N Phaser Laser Printer
Hello! My Samsung ML 2010 Laser Print has started to print pages with streaks of ink across them. This makes the pages more difficult to read, and certainly cannot be used for formal letters. It also...
there must be waste toner in your toner cartridge
the waste toner box is fitted above the drum in toner cartridge with 2 no screw open it and empty then try to print
Jan 26, 2011 | Samsung ML 2010 Laser Printer
Its saying reset drum basket, the waste toner is not being transported to the waste toner box. but have taken everything out an put a new waste box in. ?????
It is the "transport" of the "waste" toner-ink from the toner-cartridge along its path to the "basket" that is the problem.
Take a look for how the waste toner "moves" along its path; the path may be clogged.
Sep 01, 2010 | Office Equipment & Supplies
It says used ink jet full. I don't know what that means. All of my color ink jets are full and I can't even make them come forward to check them but I'm sure they are full. What is the used ink jet.
Used ink jet is probably something like the 'waste toner' cartridge in laser printers. Look in the manual for a reservoir that has waste ink somewhere. Hopefully it'snot in the ink jet cartridge.
What year,make,model printer is this for further research?
Jul 02, 2010 | Office Equipment & Supplies
Waste toner gets full before toner runs out
Actually, the waste toner should get full sometime before the regular toner runs out in laser printers that have several toner cartridges compared to the single waste toner reservoir.
You can dump the toner reservoir out and avoid buying the empty waste toner 'reservoir.'
I did this on my Brother Laser printer and saved about $30 or so for an empty plastic waste toner bottle or jar.
If this is the way the Kyocera-4020DN is, then I would put the waste toner, which is just that, waste, and put it into a plastic zip loc storage bag and throw it away. Don't breath the toner.
Good luck on this repair.
Jul 19, 2010 | Office Equipment & Supplies
The color images have vertical banding or streaking but the text appears fine. the occasional blace and white image doesn't seem to have this. what can we do to fix the problem? thanks!
Good lunk attempting to follow solution #1, intended for an ink jet printer. LOL!
It seems like you are low on toner for one of the cartridges.
First, try taking out a color toner cartridge, hold it horizontally, and shake end-to-end. This loosens any possible clumps of toner and reactivates static charge between the particles. Repeat this for each color.
Second, print a color page with each toner color separate. For example, a line of cyan text, a line of yellow text, and a line of magenta text. This will help isolate which cartridge has the problem.
Third, check the toner level of each problem cartridge. There is a little clear window on the cartridge you can use for this purpose. Hold the cartridge vertically and tilt slowly toward the side with the window. If you pass a 45 degree angle before the toner appears in the window, it is nearing empty and must be replaced or refilled (yes, refilling is an option). Otherwise, there is likely a different problem, for which I only recommend replacing the cartridge.
Don't forget to empty the waste toner bottle (responsibly, of course). By the time you run low on toner in one of your cartridges, it will likely be nearing capacity.
Aug 16, 2009 | Konica Minolta magicolor 2430 DL Laser...
Waste ink near full
Well there WILL BE a reservoir on the machine that holds all the "waste" ink that did not make it to the paper. The message is refering to that reservoir. usually loacted in the inside of the machine downhill (as gravity goes) from the point of collection.
Apr 01, 2009 | Office Equipment & Supplies
CLP300 Waste tank
Just found the troubleshooting manual for the printer and emptied out the waste tank. Seems to work fine now.
Aug 31, 2008 | Samsung CLP 300 Laser Printer
Pagepro printer toner empty problem
1. It tries to pump toner into a reservoir. If it doesn't activate a full sensor for the reservoir, it shows toner low. 2. Take the toner out and shake it hard about 10 times, this will make any settled toner loose, and should solve this. The problem is normally caused by old toner (your supplier might have had it on their shelf for a year or two).
Aug 11, 2007 | NEC Nefax 655E Plain Paper Laser Fax
Xerox WorkCentre XD125F All-In-One Laser Printer Logo
89 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
