I use a HP Deskjet 1420 for some minor printing needs in the office. The black ink recently ran out of all the cartridges I had. I refilled the cartridges (HP 21). However, it will not print black ink now. Color prints fine. And the ink levels show that the black ink cartridge is full. However, when I print a document with black text nothing is on the page: not one dot of black.
sagarjd
  • 95 Answers
SOURCE: How do I reset the ink levels?
We have an issue of missing or replace yellow cartridge. Please feel free to contact the HP support for replacement of the printer, if the printer is in warranty status. HP would replace the printer.
Posted on Jan 13, 2008
  • 137 Answers
SOURCE: Not printing after color cartridge ran out - new black cartridge installed.
Yes, this printer has fixed printheads and must have ink in each color to prevent damage to the printheads. Even when printing black only each color is spit in the servicing area to keep the printhead unclogged.
Regards,
Bob Headrick, Microsoft MVP Printing/Imaging
Posted on Jul 18, 2008
SOURCE: Check print cartridge error
Try pushing it gently using some pressure. I had the same problem and it got solved using a little push.
Posted on Sep 02, 2008
  • 320 Answers
SOURCE: HP Deskjet F4280 Ink Level
when you refill the cardtridge, you can not reset the ink level... because refilling doesn't show the ink levels.. you no need to worry. if ink is there in the carttridge it will print...
Shouldn't worry about it. They are only a rough guide. The only time to worry about it is when the printer stops working and it has told you it's run out of ink! Thank you.......
Posted on Jan 29, 2009
  • 1751 Answers
SOURCE: HP Deskjet D1460 (Ink level problem)
Hi
They key to successful refills is to remove air bubbles from cartridges check here the right way
Posted on Nov 23, 2010
Can I print on my hp 6122 deskjet with only a black ink cartridge? I have no color ink.
Yes, all HP Deskjet printer models feature a 'single cartridge print mode'. Just remove the cartridge you don't wish to print with; the printer will automatically revert into either greyscale printing (if color cartridge remains installed) or black only printing (if the black cartridge remains installed). However, if the installed ink cartridge is electrically damaged/defective the printer will display an alert message; it will need to be replaced with a new cartridge.
For more information on the use of refilled ink cartridges or advanced HP printer problem diagnosis please visit Inkjet411:
http://www.inkjet411.com
Sep 03, 2013 | HP Office Equipment & Supplies
I have a HP 1460 printer & I have now no black ink in my printer.can this printer support any duplicate cartaige(local cartaige)?
No, that printer only uses the 21 Black and 22 color cartridges. The best thing to do when you run out of ink is to buy a refill kit and then refill each cartridge at home. This saves lots of money in the long run. Click on the link below to view a refill kit for your HP D1460:
http://cgi.ebay.com/Refill-ink-HP-21-Deskjet-1420-1430-1460-BK-4oz-s-/320621581336?pt=BI_Toner&hash=item4aa6891418
Feb 13, 2011 | HP DeskJet D1460 InkJet Printer
I got a refilled hp 27 cartridge refilled at a local office supply store and installed it into my hp deskjet 3740. It prints in "normal" mode but the text is faded. I used the calibrate and clean...
It is probably the "refilled" cartridges. Return them and buy a know good brand. Office Depot's brand seems to work fine in my HP printers.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 10, 2011 | HP DeskJet 3740 InkJet Printer
How to refill the cortrideg hp deskjet f4288.
Hi
the most important is to remove all
the air from the cartridge that has
left inside durring refilling that is why
professionals are using special machines
that refill in 0 air πρεσυρε using vaccum pump
you can check here a video on how to refill
with out any special equipment
Hope I had help you
Dec 08, 2010 | HP DeskJet F380 All-In-One Printer
Just installed refilled black ink cartridge on hp
By using refilled cartridges you will always have this problem. Each cartridge has a chip that lets the printer know when it is full or empty. By pressing the ok button you may be able to clear this message. However, most of the time you can still be able to print and ignore the message.
May 28, 2010 | HP Deskjet D4260 Printer
Hi there, I have recently changed the black ink cartridge in my HP Deskjet 3845 printer, but it now prints with purple ink. Can you help?
have you cleaned the print head? done a test page? i had a simlilar problem with a lexmark but it turned out to be a refilled cartridge. if you are using genuine hp cartridges i would recommend printing a test page and checking the solid colours .
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpa00224&tmp_task=solveCategory&lc=en&dlc=en&cc=us&lang=en&product=372330
hope this helps!
Jan 19, 2010 | HP Deskjet 3845 InkJet Printer
Printer Toolbox Not Recognizing New Black Ink
The Deskjet 6940 will only show ink level for original HP cartrdgies. Refilled or reman cartridges will show as empty or unknown in the toolbox. This is not an issue with the driver, the cartrdige itself has information that it has been previously used and this is not resettable. You can continue to print with a cartrdige that has unknown ink levels, you will just not get low ink warnings.
Regards,
Bob Headrick, Micosoft MVP Printing/Imaging
Apr 24, 2008 | HP Deskjet 6940 InkJet Printer
Flashing ink refill light
Sometimes refilling them over and over doesn't work well. Once ok...but i suggest that you buy a new cartridge. I know that they are expensive but it will help. Also take some Rubbing alchohol and a q-tip...clean inside where the cartridge sits..that will help...this is for sure a bad ink cartridge
Feb 28, 2007 | HP DeskJet 810c InkJet Printer
24 people viewed this question
jasbo
jasbo
