Question about Starrett Electronic Caliper
Shut down starrett 733
How do I shut down the Starrett 733. I don't want to take the battery out as it's a pain putting it back in-please help!
On some Starrett calipers, there is no way of turnig them off, which means about once a year you have to replace the battery. sorry
Posted on Sep 30, 2013
  • 3 Answers
SOURCE: checking level accuracy
You do not need to replace it. If it does not read the same when you reverse it, on one end there are a nut over and under the tube and plug assembly. Adjust those up or down until it reads the same.
Starrett Tech Support
Posted on May 15, 2009
  • 3 Answers
SOURCE: How do you replace the bubble in a starrett 98 Level
Contact me at Starrett and I can email you the instructions on how to change the vial only if you want. The other option is to purchase a new tube and plug assembly (the silver tube with the vial). That is much easier to do. After, you can always send the old one in for repair. Third option is to send out the tube and plug assembly to be repaired.
Most people will change the vial only the first time, after that they go with option 2 or 3.
My email is pnault@starrett.com
  • 384 Answers
SOURCE: Hi. I just received a Starrett 98Z12 machinist
Sit level on near level surface. Observe bubble position. Turn level end for end. Does bubble sit at same position? If not adjust screw untill they match. Test, adjust and so on.
Posted on Aug 06, 2009
SOURCE: I just aquired a Starrett 721 digital caliper that
More than likely. But to make sure: check that new battery is good (voltmeter). Check with ohmmeter across the battery contacts - should read few hundred ohms to few kiloohms. If OK, reinseret battery. Push ON button. Push reset button. If go, congrats. If not, get another caliper.
Posted on Dec 07, 2009
SOURCE: I have a Starrett 749 micrometer that will not
I have a Sterrett 733XFL-1 (O-1" Digital Mic). It turns out that these will only use the Renata Batteries. (Radio Shack Batteries are Renata and some Battery Stores Carry Them). The Renata CR2450 has a smaller diameter negative terminal (smaller diamter back half of battery). If you use an engergizer or other, the battery cover will short against the positive battery terminal and the tool will not work (and the battery will quickly drain being shorted to case)
Posted on Jan 22, 2010
How do i shut off my starrett electronic slid caliper?
Hello there
From the manual here
http://www.starrett.com/docs/other-downloadable-resources/798-electronic-slide-caliper-user-manual---form-951.pdf?sfvrsn=3
Automatic shut off of display after 30 minutes of non-use
Reactivation of display with movement of slide with no
loss of position
Sep 24, 2014 | Cars & Trucks
Starrett no 731
Are you certain the battery is installed correctly? Many electronics won't work if the battery is installed backward/upside down. Do not ask how I know this....[-:
Jan 15, 2014 | Cars & Trucks
Need Starrett 682EMZ Saw Tension user guide
I can't find any available manual. I have an Starrett tension guide before but It was an old model and I don't even have manual for it. Did you try calling Starrett? They might can send you one.
Aug 13, 2013 | Starrett 682EMZ 60000psi or 4000kg per Sq....
How do you set a 722 starrett digital caliper to zero.
Just ran into the same problem. Bought a caliper at a garage sale and it needed new batteries. When i put them in it was reading .006. I held the M button down for 2 seconds and it reset to .000
Jun 16, 2012 | Starrett Electronic Caliper
How do you change batteries in the starrett 3752 heighth gage. I dont have a manual or intruction book
Hello rdm56us, Sorry for the delay but copy the follow link for change your battery, you have need 2 CR2450:
http://www.starrett.com/docs/user-manuals/3752-electronic-height-gage---form-578.pdf
best regard
Apr 28, 2011 | Starrett Garden
How do I calibrate a Starrett model 449 depth micrometer?
Try the starrett web site. You can chat with them there about it. The adjustments are fair easy to do.
http://www.mytoolstore.com/starrett/micro029.html
Nov 12, 2010 | Starrett 50443 12 Machinists' Improved...
Starrett heigth gage instructions
Here is a link to starrett's how to read a vernier height gauge article
http://www.starrett.com/download/251_p122_125.pdf
Give them a call the parts department is very helpful and reasonably priced.
978-249-3551
Dec 27, 2009 | Starrett Measuring Tools & Sensors
Checking level accuracy
Nov 25, 2008 | Starrett Measuring Tools & Sensors
Starrett Electronic Caliper Logo
285 people viewed this question
Top Starrett Measuring Tools & Sensors Experts
Vernon Taylor
ray gallant
Vuk B
Are you a Starrett Measuring Tool and Sensor Expert? Answer questions, earn points and help others
