Question about Garden
My Victa Tornado Trimmer Model TTB2226 AB won't idle. It just cuts out when you lift the throttle. It runs fine on full power. Is there an idle adjustment? The screw on top of the carby doesn'
  • David John Rowe Jan 24, 2013
    Thanks Phil. This is not the problem as the throttle lock is working ok along with throttle cable. The leaver on top of carby also seems to be working in that it comes off fully when trigger is released and goes fully on when trigger is pressed. I can keep motor running as I gradually release trigger however once I get to 3/4 off, motor cuts out just prior to clutch on line head activating. If I keep pressure on trigger motor will keep running.
Weed wackier gas trimmer
didnt specify the make and model so generic answer ---check fuel mixture is correct --check the filter in tank is not plugging up--look for damaged / crack in fuel feed lines-look at spark plug --carb may need cleaning --exhaust port may need cleaning
Jul 04, 2016 | Garden
VICTA TORNADO TRIMMER TTB2226
What do you need to know?
Sep 10, 2015 | Garden
Winder not going back in
Hi pete are you talking about the starter cord or the cutting cord. If it's the starter try and put some lube spray where the spring for the starter is and it should free up. If it's the cutting cord then you have wound it on wrong or not tight enough. Start it again and if this doesn't help let me know via the reply section
Dec 13, 2013 | Garden
EXCALIBUR HEDGE TRIMMER BOGS DOWN AND DIES WITH THROTTLE
I have attached a diagnostic sheet to help determine what is wrong.
May 05, 2013 | Weedeater Garden
Km90 starts but won't run on full revs
The KM90 is a 4mix engine that has valves. You may need to check the valve clearance, using the clearance tool.
Aug 28, 2012 | Stihl Used Km 90r Km90r Pole Hedge Trimmer
Added throttle and cuts out
remove the muffler and run it if runs good open the muffler and clean the screen
May 21, 2012 | Oregon Scientific Complete Carburetor for...
I have a 2 cycle Troy-Bilt TB90BC line trimmer. Won't idle. I've had the carburetor dipped, installed a new carb kit, replace the gas lines, but will only run at full speeds. Dies out easily....
One of three things is occuring here. The IDLE SPEED SCREW (Phillips head) on the throttle plate is screwed in way too far. The L and H mixture screws are open way too much allowing the carb to use excessive fuel, even on startup. Those 2 screws may need adjusting. The metering lever in your carb is not adjusted flush with the carb body flange and is holding the gas needle open constantly. Check these things and post back.
Sep 09, 2011 | Troy Garden
Victa tornado 2 stroke carburettor diagram
I have a victa tornado whipper snipper it won't start. If I poor a lil petrol in carby it will run till fuel burns off than it dies. If I press the fuel build in it pumps fuel through an ideas what could be wrong with it
Oct 30, 2010 | Garden
Ryobi 25cc grass timmer, cuts out when full throttle applied
Are you running a gas/oil mix? If you are try making sure you didnt add too much oil (will usually smoke) and will possibly stall. Your air fuel mixture may be off and need adjusting too.
Aug 17, 2009 | Ryobi 15" Electric Factory Reconditioned...
Mighty lite 26ss starts fine, but needs half choke for a long time. Runs for 10-15 mins. and seems to starve out. Acts like an air leak at carb or downstream. Any ideas?
I fixed one of these with the same problem yesterday. Theonly thing I've found wrong with this little saw is the carbs are terriblyadjusted from the factory and the mixture screws have a 'proprietary' head.they're a flat-topped cylinder with a notch in the side.
fortunately, there is a way to turn them. The insulation on a blue solderlesselectrical terminal will grip the outside of the mixture screws enough to movethem. you use the big end of the insulation you stick the wire into. doesn'tmatter what kind of terminal it is. splices work the best because theinsulation is long enough that you can grab on to it, but I just pulled theinsulation off a spade terminal and used pliers to turn it, as I didn't haveany splices.
I pulled both mixture screws out and cut a slot across the top with a smallfile so I can turn them with a flat head screwdriver. if you do this, only pullout one at a time, they need to go back in the respective seat they came fromor they won't seat properly.
I also took a file and cut an access notch in the air cleaner housing so Icould adjust the high mix while the trimmer was running. takes 10 seconds witha coarse round file, but a chainsaw file takes forever.
To set your mixtures, screw both mixture screws all the way in until theylightly seat. DON'T tighten them way down, just lightly seated.
now, look at where the notch is pointed and turn them out 1 1/4 turns. turningthem out (counterclockwise) makes the mixture richer. turning them in(clockwise) makes the mixture leaner.
now, screw the idle in a full turn so it idles very high (you'll turn this backout later, but this takes some of the frustration out of tuning the carb). You maywant to take the string head off, as it will 'run' at idle now.prime the trimmer (10 pushes if you haven't tried to startit earlier, 2-3 if you did. you can't over-prime, though, you're just removingair bubbles from the fuel pump)
put it on full choke, grab the throttle with your left hand and pull the recoiluntil it tries to start. if this takes 10+ pulls, turn the low speed jetout(richer, counterclockwise) 1/16 to 1/8 turn. you want to work in smallincrements, or you'll waste a bunch of time overshooting where you want to be.
once you get it to bump over full choke, back the choke off a bit. if you'requick you can usually do this while thetrimmer is trying to run fully choked. most likely you're still going to belean on the high mixture, so having the throttle pulled may kill the saw. if itseems like it's dying when the throttle is pulled, but not at idle, then you needto turn out the high speed mixture screw.Concentrate on getting the low speed jet set so it will idlewith the choke off and the throttle off first. Once you get it so it will idle unattended, you can startbacking the idle speed down. From there, you can adjust the low speed jet whilethe saw is idling. Start by turning it leaner in small 1/16 turn incrementsuntil the speed picks up. If this kills the saw before the idle picks up, youhad it a bit too lean to start. if you get the idle to pick up, richen up themixture 1/16 turn. You want to be just richer than where the speed picks up. Ifthe saw died before it picked up, richen it up 1/2 a turn and start it again. Leanit out as before until the speed picks up, then richen it up a bit. This may sound time consuming, but you can stick ascrewdriver on the idle screw and gently turn it in continuously, so itactually goes pretty quickly once you get the saw to idle.Now that you have it idling nicely, you can adjust the highspeed jet. Start by 'blipping' the throttle. If the trimmer bogs down, richenthe high mixture. Now, if you're WAY rich, it will behave similarly, but with thistrimmer, that's pretty unlikely if you're starting at 1 1/4 turns. One way youcan tell if you're way lean or way rich is with the choke. If it will run fullthrottle with the choke part way on or if it picks up faster with the choke partway on, you know it's too lean. The choke richens the mixture up to compensatefor the gas condensating in the throttle bore when the saw is cold. If thechoke kills it, you're too rich.if it will run, then you can adjust the high speed similarlyto the idle. A leaner mixture will have more power and spin a higher RPM to apoint, but it will also run MUCH hotter and an excessively lean mixture willseize the piston. So, you're going to want to err on the rich side. You'lldefinitely be able to hear the rpm change, a way rich mixture will be almost 1/2the speed of the proper mixture, and a too lean mixture will sound like thetrimmer is going to fly apart at the seams. Once you get the high mixture to the point that you can grabthe throttle and the saw will pick up to max speed in less than a second, thenyou're ready to cut something. You may need to adjust the mixture leaner for abit more power if it bogs down in normal grass trimming, or if it is running througheverything including big weeds without changing speed, you should probablyrichen it up. This is NOT a big trimmer, it SHOULD bog down a bit if you loadit up.A final note about this trimmer, I never could get it to acceleratesmoothly from idle to high speed. It lags for about 1/4 second just above idlethen it picks up as it should. It runs fine once it gets past that hesitation,you can vary the throttle to be delicate around things, ect, but if you let itidle, it does hesitate when you pull the throttle again.I was pretty surprised how well it ran once I tuned itthough, this one is my boss's and he's got a 3-blade cutting head on it that'sa lot heavier than the string head and it will spin it just fine. It will cutdown saplings to maybe 5/8".Good luck!
Jun 26, 2009 | Homelite Mighty Lite Lawn Trimmer
Garden Logo
182 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
