Question about Brother MFC Office Equipment & Supplies
Can I print on index cards with the Brother MFC-490CW
Can I print on 3X5 index cards
SOURCE: Brother mfc-490cw is offline
If you are running Vista and SNMP is turned off
1. Check to see if SNMP is turned off this is a component of Vista
a- Control Panel
b- Program and Features
c- Left side of screen you should see turn windows features on or off
d- Click on this a window box should open scroll down and see if SNMP feature is checked if it is then turn it off (unchecked) follow these steps
e- Under printers select Brother MFC-940CW printer right click
f- Select run as administrator
g- Select properties
h- Select ports
i- Select button configure ports
j- Under port settings uncheck enable SNMP
k- Click ok printer should be on line
l- To find MAC address for MAC filtering on router
m- Run the brother remote setup program and note the IP address
n- Run the command prompt as an administrator at the prompt type the following “apr –a” without the quotes and then hit return and note the physical address (MAC) for the above IP address you noted. Log on to your router and enter the MAC address from the step above and save.
o- Run the brother remote setup program again and change TCP/IP from “auto to static” please note you must have box checked at the top of the window edit network settings.
p- Restart the computer
Posted on Apr 16, 2009
  • 55 Answers
SOURCE: Brother MFC-490CW Won't Print
If you have installed something since yesterday you might want to use system restore. the program might be causing the flaw. If not dont worry. You will need to uninstall the printer from your printer page and reinstall it. depending if it is a networked printer or a usb connected. If networked all you have to do is follow the install wizard. but if it is a usb you will have to go to the company's website and download a printer driver. after that it should work. dont forget to restart your computer. sometimes that can help too.
Posted on Jun 30, 2009
SOURCE: my Brother MFC-490CW won't print
Did you try onboard print test by pressing INK LEVEL button. I am having similar problem but color prints but black does not. The printer has built in diagnostics that walks you thru some troubleshooting steps. It has you repeat cleaning 5 times and then asks you to replace cartridges if test fails...than repeat tests and call customer support if that does not work. Which I may do soon.
Posted on Jul 25, 2009
  • 41 Answers
SOURCE: brother mfc-490cw won't print. sounds like it's
Does the Brother have a print utility, verifying cartridge levels?
You said you printed 40 pages?
Was there a lot of coverage per page?
You know that ALL printers only ship with STARTER cartridges, might want to check that first.
Does it not print black or color also?
Posted on Dec 01, 2009
pineworks
  • 4041 Answers
SOURCE: problem paper jam printer brother no mfc-490cw
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 27, 2010
It is printing backwards
Click File
Select Print
Choose Brother MFC 490cw
Select Properties
Click on the Advance Tab near the top center of window
You can choose reverse printing options
• Check Mirror Printing to reverse the data from left to right. • Check Reverse Printing to reverse the data up to down.You can choose reverse printing options (3).
Apr 10, 2014 | Brother MFC 490cw Color Inkjet...
My brother printer will print from 2 PC, but will only scan from 1.
HAve you installed the printer software to your Both Computer?
Still having Problem Then follow Us For
Brother Printer Support
Feb 24, 2014 | Brother MFC 490cw Color Inkjet...
My mfc 490cw will not print black ink. What should I do?
Try to clean the print head 2-3 times,if not work you need to replace 100% the print head.If a have been usefut please give me a vote :)
Mar 14, 2011 | Brother MFC 490cw Color Inkjet...
Wont print, no cleaning function. Says unable to clean 46
<span class="f"><cite>www.articlesbase.com/.../<b>brother</b>-<b>mfc</b>-<b>490cw</b>-<b>multifunction</b>-<b>inkjet</b>-<b>print</b>er-<wbr>amp-lc61-ink-cartridge-1797776.html</cite> - <cite>United States</cite></span>
Aug 29, 2010 | Brother MFC 490cw Color Inkjet...
MFC-490CW does not print black ink, what can i do to fix this?
does it print in any of the other colours? if not, it sounds like one cartridge is empty and the printer will not print until you have full cartridges.
Feb 08, 2010 | Brother MFC 490cw Color Inkjet...
Jun 30, 2009 | Brother MFC 490cw Color Inkjet...
How do I print to a 3x5 card on the Brother MFC-7220 multifunction printer?
You should be able to go to start, settings, printers or faxes. Right click the printer. Click on "printing preferences".
Change "size is" to 3x5 if it's available. "Apply" "Ok"
Apr 19, 2008 | Office Equipment & Supplies
218 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
