Question about LG WM2077CW Laundry XL Front Load Stackable Washer
Lg tromm soap dispencer won't open
Soap dispencer stuck in closed position
  • Anonymous Mar 29, 2014
    soap dispenser drawer stuck
Sofener cover (blue) cap @ not seated or worn
Posted on Mar 06, 2008
  • 51 Answers
Nothing to lock it fully closed......pull harder!
Posted on Jul 25, 2007
SOURCE:
Why does my dishwasher most of the time not desovle the dish soap
make sure when you load it that nothing is stopping the soap door from opening all the way,, most common mistake is loading a cutting board or tray in the front of the lower rack
Nov 20, 2015 | Frigidaire Dishwashers
Detergent dispenser is stuck and cannot open on LG Tromm washing machine
There is a small tab that one has to press down to unlock the retainer clip.
Press this down while pulling the tray outward.
Aug 06, 2014 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG tromm washer soap not empty after wash cycle
I have a front load He LG Tromm model 2455 HG. I never use more than 3 tablespoons for any load. This soap is so concentrated that is all you need, which really isn't very much. Too much soap could possibly cause foam to back up. Starting with the basics, could this be your problem?
Feb 19, 2013 | Washing Machines
Lg tromm washer leaks from detergent drawer
my washer also was leaking from the dispenser and I had a cap from one of the detergent bottles stuck in the inlet hose. Don't know how it got in there but glad I found it so if your washer leaks from the soap tray it could be a cap from your detergent bottle stuck in there.
Nov 04, 2012 | LG WM2688H Front Load Washer
Soap drawer won't open
hi they normally just pull out.just take your time it might have wet powerder on the edges make it get stuck good luck
regards
shaun
Nov 28, 2011 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
The dispenser door is stuck in the closed position. No matter how much I try to jiggle it open the door will not slide out. How do I get the door to open without breaking something?
Hi stuwstark, you could try running a quick wash cyle without any clothes in the tub once cycle is activated you will hear water flowing through the dispencer holder from there you can try riggling the dispencer to see if it will loosen up, in some cases the dispencer holder can become stuck due to dry soap powder clogging up the sliding rails also the dispencer holder can become stuck due to the liquid detergent box "insert" becoming loose and jamming it self up against the top casing of the dispencer holder so by applying the cycle when the water flushes thru the holder could ease the hard powder or could float the insert making it easier to open,try it and see how you go, thumbs up if it helps thanks.
May 06, 2011 | LG WM-2277HW Front Load Washer
LG Tromm WM2496HWM Washer - stops mid cycle
use only HE (high efficiency ) soap,try not to use too much ,run tub clean cycle with a little bleach to kill smell
Jun 12, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Soap dispencer won' t dispence soap
My Bosch intergreted dishwasher is only 3 years old. For the past year, the dishwasher dispenser refuses to open on the second cycle. We have had the repair man here 3 times, and each time he says it's fixed,but it clearly is not. Does anyone know what to do about this??
Barbara Berger
Sep 30, 2008 | Bosch 24 in. SHY56A05 Stainless Steel...
LG WM2077CW Laundry XL Front Load Stackable Washer Logo
398 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
jimorris77
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
