Question about Lionel Sunoco 6465 Tank Car
I have the frame of a 6465 tank car and a possibility to purchase a plastic lionel lines black tank car body. How do I affix it to the frame???
  • 161 Answers
If there are mounting holes on the supports for the tank body,
measure the distance between the centers, and compare them to the mounting holes on the on the frame. If they are the same, just use screws to mount the tank, If the holes do not match, you'll have to drill new ones and then mount the tank body to the car.
Posted on Feb 13, 2013
How do I blow out the fuel line?
The fuel line runs from the rear of the fuel throttle body down the rear of the engine to the frame, along the frame to the fuel tank. It might have a fuel filter along the way on the frame, If so you can easily disconnect the line from the filter and blow from that point, back to the fuel tank, and forward to the rear of the throttle body. Make sure and disconnect the line from the throttle body so you don't damage the injectors or jam some trash deeper into them. Plus be careful blowing pressure into the tank, the fuel pump is in the tank and might be damaged from the air pressure. Good luck.
Nov 27, 2015 | 1988 Dodge Caravan
How to replace the front light on a lione santa fe train engine
From the Lionel User Guide for this engine.
it forward to release the two rear clips from the frame slots.
2. To remove the lamp, gently push the lamp down and turn counter clockwise to disengage
the lamp from the socket. Refer to Figure 6.
3. Replace the expired lamp with Lionel part no. 600-0363-300, available from your local
Lionel Authorized Service Center or Lionel Service. (For more information, see Lionel
Service on page 12.)
4. To reinstall the shell, first insert the rear tabs on the body into the slots on the frame. Line
up the screw holes on the frame and body shell, and reinsert the screw. Make sure all of the wires are inside the body before you tighten the screw.
This is a 14V bulb
This
Mar 14, 2014 | Lionel Santa Fe Diesel Locomotive Engine...
Fuel filter
You will need to jack up the RR corner of the vehicle to reach it. The fuel filter is fastened with a big clamp to the right side frame rail, close to the fuel tank, just ahead of the RR wheel. Use a small flat screwdriver to remove the two plastic clips from the lines attached to the filter. Be careful, the lines are under pressure, and there will be fuel that will spray out as you unplug the lines from the filter. Use a flat screwdriver to loosen the clamp from the body of the filter and then you can remove and replace the filter. Install the new plastic line clips that are in the box with the filter into the lines and then plug the lines onto the filter until you hear them click in place.
Mar 01, 2011 | 2001 Ford Taurus
Trying to find the location of the fuel filter on 2000 gmc jimmy, tks!
Hi the fuel filter is located under neath the body at the b post on the inside of the frame. one end will have a flair nut and the other will have a plastic quick connector. unscrew the flair nut from the backside of the filter and then carefully depress the tabs on the plastic connector and pull it apart. hope this helps you
let me know if you need further assistance ok
please rate this solution as i have a whole page of unrated posts, thanks
Aug 30, 2010 | 2000 GMC Jimmy
Where is the fuel pump in a 86 lincoln town car located
inside the gas tank, and also onthe driver side frame rail under the car under the driver door hindge inside the frame rail with a plastic cover over it held on with a hose clamp and held to the frame with a self threading bolt that has a 13MM head. has a fuel line ( plastic ) comingout ofboth ends and a 2 wire electrical connector. The tank pump is in the front side of the tank and with the car jacked up by the body it's just above the rear axel and can be removed with the tank still mounted to the car.. The tank needs to be level and less than 1/2 full orr the fuel will come out as the tank is opened. some cars have only the tank pump, and none on the frame.
Jun 12, 2010 | 1986 Lincoln Town Car
Where is the fuel filter on the 1996 Lincoln Town Car
Below driver side rear door just inside of the frame is a stainless tank filter with black plastic hoses with squeeze clips to release the lines and a 5/16" hose clamp holding it in the frame mount.
Nov 21, 2009 | 1996 Lincoln Town Car
Fuel filter
unbolt the filter from the bracket, that is a 5/16" machine screw head size, then remove the nylon clips that hold the lines onto the filter, hold a rag over the fuel line when u remove it, it will have about 30 pounds of pressure.
May 09, 2009 | Ford F-150 Cars & Trucks
Fuel tank selector valve
Black plastic with round screw off bottom with lots of line's coming in and going out, it is on the inside frame rail just behind driver.
Mar 30, 2009 | 1995 Ford F150 Styleside Regular Cab
Lionel Sunoco 6465 Tank Car Logo
156 people viewed this question
Top Lionel Crafts & Hobbies Experts
Jeff Hogancamp
Jeff Hogancamp
J.D. Browning
J.D. Browning
ray gallant
Are you a Lionel Craft and Hobby Expert? Answer questions, earn points and help others
