Question about Konica Minolta Bizhub c203 Copier
Trouble code c-4553 - Konica Minolta Bizhub c203 Copier
  • Konica Minolta Expert
  • 337 Answers
Laser Units. There was a massive recall of sorts for these units. all 4 laser units were sent out to all dealers with these machines in the field to replace defective ones. they need to be replaced as a full set. contact your dealer. if you don't have service on it then you have a 300 pound paperweight.
Posted on Jan 30, 2013
Mitsubishi Model Ts 4553 picture dull and dark will cleaning the inside help or do you think I need a bulb replacement
You will want to clean lens and mirror when you replace the bulb so why not try it first. Avoid glass cleaner with amonnia as it will ruin mirror.
Oct 20, 2014 | Televison & Video
Error code 4553
Yellow LASER is bad, try a reset open close right side door. if it comes back need to have the printhead for yellow replaced
Jan 23, 2014 | Konica Minolta Bizhub c203 Copier
Maquina C250 com cod. C-4553
sorry only speak english if this is a c259 and you have error code c-4553 this is a common issue the magenta ;aser unit is faulty
to check this turn of the machine unplug it from the wall switch the lasser unit magenta with the cyan laser unit plug in and power up the machine you should now gett error code c-4552 this will confirm that the laser unit is faulty
I can also give you the part number that you will need to replace the faulty laser unit
part number 4039-r713-00 also rest the the connections on the pwb-d and pwb-m re-flash the mfp with the most current firmware
If the above dose not fix the problem replace ph interface board pwb-g
If the problem still persists replace the mechanical control board pwb-m i have always found changing the laser unit 9 out of ten will fix the issue
Jan 27, 2011 | Konica Minolta Office Equipment & Supplies
C-4553
This is a Yellow Laser Unit Error. SOS signal is not detected even after thelapse of a given period of time after starting the laser output. This is a Rank B error. To clear a Rank B error you open and close the front door and/or do a trouble reset:
1. Turn OFF the main power switch.2. Turn main power switch ON while pressing the Utility/Counter key.3. Touch [Trouble Reset].4. Check to make sure that [OK] is displayed and the it has been reset.5. After turning off the main power switch, turn it on again more than 10 seconds after and check if the machine starts correctly.
Please note: I believe there was a factory bulletin out on this model and Konica Minolta furnished new laser units free of charge. I think that program is over however. These lasers had a high rate of failure due to a design or manufacturing problem.
Dec 01, 2010 | Konica Minolta Bizhub c203 Copier
Need code for 2004 chevy optra am fm cd player
try one of these :
1165 1325 1341 1630 2145 2152 2346 2453 3116 3241 3451
3462 4156 4236 4265 4316 4353 4362 4513 4524 4553 4653
5224 5226 5241 5253 5256 5436 5624 5813 6253 6361 6461"
May 20, 2010 | Toys
Want to use the dish network remote control for my panasonic vcr
The Dish network technician was here on another issue and scanned for the VCR using the remote control. The code is 734.
Mar 25, 2009 | Panasonic Televison & Video
Need raido code for 2001 daewoo leganga please
1165 1325 1341 1630 2145 2152 2346 2453 3116 3241 3451 3462 4156 4236 4265 4316 4353 4362 4513 4524 4553 4653 5224 5226 5241 5253 5256 5436 5624 5813 6253 6361 6461
Posts: 4 Radio Code List:
6361,LEGANZA 99
2253, 3116, 3451, 2152, 4362, 4316
4316, 4513, 4362, 1156, 2145, 1156
6451, 6361, 5624, 5241, 3346, 1165
3241, 4524, 5436, 5813, 3265, 5624
2453, 3462, 3251, 5445, 8253, 1156
2346, 4853, 6645, 5253, 1325, 4136
3116, 3221, 2151, 5312, 2654, 4314
6234, 4356, 1415, 1435,1156, 1651
6361
2152 1165 4362 5813 4513 5241 4316 1651 5346 1341
3241 1652 4524 6361 2145 5436 1857 4353 5632 3451
1638 1156 1636 5324
Dec 09, 2008 | 2002 Daewoo Leganza
Repair of a Mitsubishi TS-4553 46" rear projection television
I checked out past posts on your forum and found the answer there. The TV is working great. I did have a bit of trouble finding the cc in the menu, but finally found it and the problem was solved by turning the cc off. Now I just have to make sure that they don't turn it back on!
Thank you!!!!!
Feb 18, 2008 | Televison & Video
Sd p 4553 tv
when you say cant be seen clearly, please explain?
Jul 03, 2007 | Pioneer SD-P50A5-K 50" Rear Projection...
Open ports for EMULE
I don't know how it is in this specific type of router but i hava a similar one, and u need to go inside ur settings and set up rule for firwall with the tcp 4553
Apr 25, 2006 | 3Com OfficeConnect (3CRXJKL0075/3CRWE554)...
Konica Minolta Bizhub c203 Copier Logo
78 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
