Question about D-Link DI 514 Wireless Router (DI-514)
Cant access router - D-Link DI 514 Wireless Router (DI-514)
    Genius:
  • 1,605 Answers
Connected a CAT-5 cable to one of the LAN port. type in 192.168.0.1 on the addres bar, and press enter.
login with admin and blank password.
Posted on Feb 09, 2009
Cant access to internet
What you problem you are getting ??
Check your router signal strength ,if it is low then it can drop internet connection..try to reboot.
Jan 14, 2013 | Linksys Wireless-G WRT54G Router
Cannot access 192.168.1.1
you need to make sure that you are hard wired to the router before you access the 192.168.1.1, if you still cant access the router page, try to optimize your browser by deleting the cache and cookies. if you still cant access it, try using the www.routerlogin.net
Sep 01, 2011 | Computers & Internet
Cant go to setup for my router 192.168.2.1
you can't access your router IP address? are there any errors? have you connected your computer to your router using ethernet while accessing the router? cause if try accessing your router wireless it will not work this should be done hard wired using an ethernet cable ^_^ also have you tried resetting the router to default by pressing the pinhole on it press it for 5-10 seconds then let go try accessing the router again ^_^
Jun 06, 2010 | Belkin (F5D5231-4) Router
I CANT ACCESS THE ROUTER'S WEBSITE
if you are not able to access a router page
try to reset your router and then try to access the router page .
if it doesnot work then try to reset winsock
start >run>cmd>netsh>winsock reset catalog
then see it work or not
Jul 07, 2009 | Belkin Wireless Pre-N (F5D8230-4) Router...
Router locked. Cant remember the password.. User "root"
The only solution for u to login in to the router is to reset the router.
1.If you forgot your password, you must reset your router. Unfortunately this process will change all your settings back to the factory defaults.
2.To reset the router, locate the reset button (hole) on the rear panel of the unit. With the router powered on, use a paperclip to hold the button down for 10 seconds. Release the button and the router will go through its reboot process.
3.Wait about 30 seconds to access the router.
4The default IP address is 192.168.1.1. When logging in, type in the default User Name “admin,” and the
default Password “admin” then click on the OK button to access the web-based manager.
Regards,
Ayyasam
May 29, 2009 | Buffalo Technology WHR-G54S Wireless...
I cant access router on 192.168.1.1
Press reset and use the router.
or else
Try using telnet.
Mar 10, 2009 | Linksys Wireless-G Broadband Router
Cant get router to access internet
The easiest way to set up this router is to connect it via ethernet cable and then access the router with the default ip address and configure it from there
Dec 08, 2008 | Belkin N Wireless Modem-Router F5D8633au4A
I cant access my router(EDIMAX BROADBAND ROUTER)
Warning the following instructions are likely to RESET THE ENTIRE CONFIGURATION OF THE ROUTER and you will need to reenter it completely. Do not follow these instructions unless you are prepared to reconfigure your router completely from the factory defaults. I am not sure but be careful or consult with EDIMAX support before proceeding.
note the following is from the http://www.edimax.us/ website follow technical support and click
BR-6104 / 6104W / 6104P
Then
If I forget my password, what can I do?
I hope this helps.
Dec 02, 2007 | Edimax BR-6104KP Router (BR6104KP)
D-Link DI 514 Wireless Router (DI-514) Logo
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
