Question about Lexmark Z735 InkJet Printer
Lexmark Z735 keeps saying "no cartridge"
I have a new cartridge in it but it still says no cartridge in it...I have reset,rebooted,unpluged,removed and replaced the cartridge to no avail,please help! I am thinking of taking out the printer and rerunning the program all over again to see if that helps. I have a APC surge protector on the computer,but we have had some bad storms here in Florida lately. Could that have anything to do with it?
  • 1 more comment
  • Peggy Hicks Jul 22, 2007
    Yes it's exact words are....Print Cartridge Missing.....and it is really in there! Thanks for trying to help.
  • Peggy Hicks Jul 24, 2007
    Thank you to every body who tried to help me,I gave up and bought a hp printer instead...
  • Anonymous Mar 23, 2008
    We're having the same problem with ours. I tried the eraser trick and that didn't work. This is the 2nd time we're replaced our cartridge, we had no problem the first time. I even tried to put the old one back in but it still gives me the same message.
  • 432 Answers
What happens when you put the old cartridge back in?? Does it still say NO cartridge?
Posted on Jul 21, 2007
  • 624 Answers
It could be damaged from power surges, however, I still would be inclined to suspect the cartridge. Like CompuGuy suggested try replacing the original cartridge if you still have it and try again. If there is no chance look at the cartridge you?ll see electrical contacts that match up to contacts on the cartridge carrier. Inspect them all for damage and if you find nothing try cleaning them with a soft pink or white, non-residue/abrasive easer. If there is any oxidation on them that should remove it. Replace the cartridge and try again.
Posted on Jul 23, 2007
SOURCE:
Any black ink cartridges work on Lexmark z735 printer?
The cartridges compatible with this printer (at least within Europe) carry the code 18C0781 and are commonly know as the Lexmark 1 cartridge.
Dec 20, 2012 | Lexmark Z735 InkJet Printer
Je ne troune pas une bonne impression apres avoir remplir mon catouche d'encre
Note that Lexmark does not recommend using or refilled cartridges. Refilled cartridges tend to degrade print quality and cartridge performance. It is best to use only genuine Lexmark cartridges for your Lexmark printer.
You can try to reseat your cartridges into the printer. However, if problem continues, please replace your refilled cartridges with new genuine ones.
Jul 26, 2011 | Lexmark Z735 InkJet Printer
I just purchased a new black ink cartridge for my printer and it is not printer. The printer stop printing. I have a Lexmark X1270
Try to re-seat your cartridges into the printer.
  1. Open the printer cover.
  2. Remove both cartridges from the printer.
  3. Close the printer cover.
  4. Unplug and re-plug the printer into the power source to reset it.
  5. When the printer turns on, re-insert your color cartridge first. Close the printer cover and check for any errors.
  6. If no error appears, open the printer cover and reinsert the black cartridge. Close the cover and check for errors.
  7. If error appears when black is inserted, try to insert a different known working cartridge (your old cartridge maybe) to determine if it's a faulty cartridge issue.
If you can make a copy using the Copy button on the printer operator panel without a problem, then it could be a communication problem between your printer and the computer. A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply reboot your pc and unplug and re-plug the printer into the power source to reset it. When everything is back on, try to print again.
If problem continues, please contact Lexmark Technical Support Center for additional assistance.
Jul 06, 2011 | Lexmark X1270 All-In-One InkJet Printer
The blue light on my lexmark z735 printer is blinking. also when i go to print, it says there is a connection problem. any suggestions?
It could be a slight communication problem. Disconnect the printer from the pc. Reboot the pc. Open the printer cover and remove the cartridges. Close the cover. Unplug and replug the printer into the power source to reset it. When the printer turns on, reinsert the cartridges. Reconnect it to your computer. Try to print again.
May 25, 2011 | Lexmark Z735 InkJet Printer
Wats the cartrige number for lexmark Z735 printer
Follow this link to Lexmark's website. There is an extensive list of cartridges available for this printer and you gave no indication as to what you needed. http://www.lexmark.com/lexmark/product/home/725/0,6970,204816596_653399455_483733205_en,00.html?tabId=7 Don
Jun 12, 2009 | Lexmark Z735 InkJet Printer
Lexmark x3470 message "printer cartridge missing"
Normal 0 Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 09, 2009 | Lexmark Z735 InkJet Printer
How do i change the cartridge in my lexmark z735?
hi . To change the cartridge you must lift the front cover and the cartridges will come in the centre of the printer. after that you pull gentely the cartridge out careful. some tipes of printers have over the cartridge some plastic cover if so pull it up form the tfnt of the suport. after you manage to do that befre instaling the new one remove the strip ovrer the new cartridge. the revers tehnic willl bee required good luck
Dec 20, 2008 | Lexmark Office Equipment & Supplies
I have changed my printer cartridge, it is the correct cartridge for a Lexmark Z735 and it keeps throwing up a message "unsupported cartridge"
Hi There,
Thanks for back up call, the " fault" has been sorted by disconnecting the printer, re-connecting
and re-booting the system. As the cartridge was a non Lexmark type we can only assume the
system identified this when the printer was rebooted, but cannot say so with any certainty.
Thanks again,
lyn_mike
Sep 13, 2008 | Office Equipment & Supplies
Help me !!
Lexmark usually does not distribute replacement install disk.
Contact Lexmark here, to see if the disk is available.
If you do not have the disk you must download the software from Internet, follow instructions below,
Click here:Official Lexmark Drivers and Software
A web page will open, follow instructions, select model, select operative system etc., and click on download .
Chose to download the file in my documents when asked.
Afterdownloading,find the file,doubleclick on the file, if you get introubles ,then followinstructions below to reset and reinstall:
  • Unplug printer USB.
  • Go to control panel >> installed printers in Windows and remove (delete ) any installed printer from printer list.
  • Download driver from website and run the file.
  • Follow driver installation wizard.
  • Plug back printer when prompted from installation wizard.
Note:some printer does not work on Vista
Sep 05, 2008 | Lexmark Z735 InkJet Printer
yes ı have your problem help me please
Mar 23, 2008 | Lexmark Z735 InkJet Printer
Lexmark Z735 InkJet Printer Logo
219 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Ekse
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
