Question about HP Office Equipment & Supplies
Error message 49 4C06
Yesterday my Hp 4650dn laser jet printer started giving me this error message when printing from my mac. If I remove the printer from the computer, and then reinstall it will work for "a" print job, then quit again. It has never done this before, why now? It still works when plugged into the laptop with Vista on it? HELP I am getting a tad frustrated here
ctf1800
  • 4402 Answers
SOURCE: HP Laserjet 3050 won't print - os X
Power off printer, disconnect all leads such as USB, network, etc and power on again.
Does it power on to the normal state?
Are there any messages on the control panel or light patterns (eg off, on, flashing etc)?
Posted on Jan 10, 2008
SOURCE: HP Laser Jet 4350tn issue
Take the paper out of the trays and check the trays mechanism, lift the tray by hand and make sure nothing is obstructing the movement or something broken.
Posted on Dec 21, 2007
Soulvisitor
  • 1113 Answers
SOURCE: Printer HP Laser Jet 7400
A critical firmware error has occurred that caused the processor on the formatter to abort the operation.
This type of error can be caused by invalid print commands, corrupt data, or invalid operations.
In some instances, electrical noise in the cable can corrupt data during transmission to the printer.
Other causes include poor quality parallel cables, poor connections, or specific software programs.
99 % of time it is a corrupt file or poor connection, I have also known it to be the firmware, dimm or formatter board on rare occasions.
Recommend check hp web for any firmware updates, check connections and that driver is installed impecablly and use known good files to test.
Posted on Dec 27, 2007
SOURCE: HP Laser jet 2840 wont scan
See this post for a possible solution
http://forums11.itrc.hp.com/service/forums/questionanswer.do?threadId=1249370
Posted on Oct 01, 2008
SOURCE: laser jet 2430tn printing slow
Check the way your print Jobs Spool up in your PC. you may have a totally different set up for printing in your new computer that takes two or three extra steps(such as spooling the print job) prior to actually sending it to the printer to be printed. If you have a user manual for your new computer, check the printer set up and see if it is set up to print directly to printer or print to spooling folder then to printer. Also try a different driver if you wish, I know the 2430 can use either PCL5 or PCL6 drivers... I'd start there and see if there is a difference.... the problem isn't your printer obviously its the way your computer is communicating to it. Best of luck to you.
Faxgenius.
Posted on Nov 12, 2008
HP LASER JET 2300 52.00 ERROR
HP LASER PRINTER 2300 ERROR 52.X
1. A temporary scanner start up error.
2. This can also be the shutter tab on the print cartridge. Replace the toner cartridge.
3. Replace the scanner ***'y.
4. Replace the engine board.
Tallon41
Sep 12, 2012 | HP LaserJet 2300 Printer
Hp color laser jet 2605dn gives me a message printing document but does not continue print it then tels me to turn of printer and turn it back on
According to your problem, The instruction is correct.First remove all pending print job from print queue by double click on printer in printers and faxes wizard. Then reboot the printer and system both. After turn on give a print job. If it doesn't help you then check the page setup in printer properties.
Apr 28, 2011 | HP LaserJet 2605dn Printer
HP 4650dn says 49.4C serivce error
Are you trying to print a PDF file from the internet?
The Jetdirect card could be the problem, especially if it's the 615n type, as they fail a lot..
The most likely cause is the firmware, which can be changed by installing Web Jetadmin on a PC on your network. You will need to have internet access in order to obtain the latest firmware. Most of the FW images from 2008 are the cause of the 49.4c errors. So you need to install a newer image (if not available you will need the post 2008 file).
Here are directions for setting up Web Jetadmin
http://h20000.www2.hp.com
Also, if the printer doesn't come to ready, try removing the cable to the network card and turn on again as it could be a job stuck in some print queue that is still trying to print causing the error. If you are able to get the printer to ready with the jet direct card connected you do not need web jet admin to upgrade. A better way may be to run a config page from the information menu and on the second page will be the tcp/ip address. Download the firmware upgrade to the printer and then ftp the address into your web browser which should look something like ( ex: ftp:/192.168.2.10) where the info after the forward slash is the ip address and hit enter and you should come up with a Port icon in the window. Just drag the firmware upgrade file to the icon and it will upgrade the
firmware.
Hope this helps you
Oct 28, 2010 | HP LaserJet 4650dn Printer
I can't print out with my 1160 and computer
Always try downloading the appropriate driver first, but if it just doesn't work you can always use the postscript version of the HP Laser-jet 4 driver in the Windows driver list and still get most functionality under Vista on almost all HP laser printers.
Mar 02, 2010 | HP LaserJet 1160 Printer
HP Laser Jet 3030 not work
remove scanner glass and use compressed air to blow out the scanner
Sep 23, 2009 | HP LaserJet 3030 All-In-One Printer
Hp2300 laser printer
52.x PRINTER ERROR alternates with To continue turn off then on Possible printer control panel error messages 52.0 PRINTER ERROR 52.1 PRINTER ERROR 52.2 PRINTER ERROR Description A temporary printing error occurred. The x can equal one of the following: 0 = Scanner error 1 = Scanner startup error 2 = Scanner rotation error This error can also indicate a problem with the shutter tab on the print cartridge. Action
  1. Turn the printer power off, and then turn on the printer power.
  2. If the message persists, check the print cartridge for damage.
    1. Verify if the shutter tab on the cartridge is broken or damaged. click on the below link. Shutter tab on the print cartridge
  3. 1 - Shutter Tab
  4. Replace the cartridge if damaged.
If the message continues to persist, then download the printer software based on operating system and reinstall.
HP Laser-Jet 2300d Printer Software
Regards
Chittaranjan
Dec 11, 2008 | HP LaserJet 2300d Printer
Laser jet 5 will not print from my laptop. was fine until yesterday. now get error message. did all tests. printer printed out test sheet. computer printed out test sheet. just cannot print a document.
Looks like this is second printer installed on ur lappy... if that is so open Printers and Faxes and make ur laser jet 5 as default printer. Can give more accurate solution if u'll mention what error msg u got...
Plz Rate Me... Thanks.
May 13, 2008 | Office Equipment & Supplies
Can't print to a shared HP Laser Jet 2015 printer (Mac)
On the two non working computers...uninstall the printer drivers and uninstall any info about the printer reboot.reset up each indivual (the two non working ones)computer with new drivers from web.reboot and they should work.RICHARDM69
May 02, 2008 | HP LaserJet P2015dn Printer
4,257 people viewed this question
Seeker5211
Seeker5211
