Question about Kenwood KDC-MP145 Car CD/ MP3 Player
Remove kenwood kdc-mp145 from 1998 Corolla
What do i do after removing face plate?
    President:
  • 720 Answers
Step 1:
The radio is secured to the frame of the vehicles dash, with screws located behind the plastic dash panel (surrounding the radio).
This plastic dash panel unsnaps from the body of the vehicles dash.
Step 2:
The bottom of the plastic dash panel, just below the bottom of the radio, can be lifted up.
Look up from the below the radio and you will notice rectangular openings or insertion points where a flat tool can be inserted to pry out the bottom of the plastic dash panel.
With a flat head screwdriver or other flat object, pry out the bottom of the plastic dash panel.
Step 3:
Once the bottom edge of the plastic dash panel has been pulled out, the sides of the plastic dash panel will begin to separate from the body of the vehicles dash.
You will now be able to put your fingers into the openings on the sides of the plastic dash panel. Gently pull the plastic dash panel until it unsnaps from the body of the vehicle's dash.
Step 4:
Once all the clips on the plastic dash panel have been unsnapped, the dash can be pulled out.
The top of the plastic dash panel will have wires attached to the clock, hazard and defrost switches. You do NOT need to unplug the connectors plugged into them.
Move the plastic dash panel up and set it on top of the body of the dash.
Step 5:
The radio is held in with four (4) phillips screws / 8 mm bolts.
Remove the screw/bolts.
Pull the radio forward.
Unplug the antenna cable, and 2 white connectors from the rear of the radio.
Step 6:
If installing a different radio to your Corolla, buy a "snap on" adapter loom which eliminates the need for cutting any wires (Toyota --> New radio brand), from your local auto accessory store.
GOOD LUCK !!!
Posted on Feb 02, 2013
elecgooroo
  • 57 Answers
SOURCE: Security code?
you cant you have to call kenwood with your serial and model number and where you purchased it from they prob charge you $25
Posted on Jan 10, 2009
  • 119 Answers
SOURCE: Kenwood KDC-715s problem.
the kenwoods with the motorized face platesdevelop one problem with time. the flexable ribbon cable between the main unit & the face plate. as the face open & closes, over time wares out the cable. problem consists of face plate not opening/closing, display missing & and/or some or all buttons not working. note these can also be intermittent problems. typically the part number is located on the cable itself on the side where it pluggs into the main board. since you have a service manual, you should verify it in the manual. good luck.
Posted on Dec 21, 2006
robotek
  • 1512 Answers
SOURCE: Kenwood KDC-322
If you have the remote control for the unit, or can buy one then you can reset the code. Just ask me how...
Posted on Feb 08, 2008
  • 105 Answers
Common Kenwood Security Codes
Many Kenwood radios are configured with the same security codes:
KCAR - This seems to be a "backdoor" to some Kenwood models.
3051 - This is the security code which is printed in the manual of many Kenwood models.
1234 - This is a security code commonly chosen by Kenwood owners.
Entering Your Kenwood Security Code
If the car battery fails or is disconnected, the Kenwood will ask for the security code.
The procedure to enter your security code differs on various models of Kenwood car stereos. Here are three of the more common procedures:
Type 1
During the code request mode, while holding the DISP key depressed, press and hold the Volume UP or DOWN key for 3 seconds until the "..." display disappears.
Enter the security code using your Kenwood remote.
Type 2
Press the "Auto" button and "Track up" on the face of radio at the same time until the four dash lines disappear.
Type 3: Model# DPX-4020 and DPX-4030
Press and hold the 1 then the 6 preset keys until the display shows the letter 'C'.
Entering Letters on your Kenwood Remote
To enter a letter using your Kenwood remote, press a button once for the first letter, twice for the second letter, and three times for the third letter -- then press the Track Up or Next Track key to send the letter.
To send the letter 'A', press the 2 key once and then press the Track Up key. To send the letter 'B', press the 2 key twice and then press the Track up key.
Finally, when you are done entering all of the letters, press and hold the Track Up button for 3 seconds.
The key sequence to enter the security code KCAR is:
5
5
Track Up
Track Up
Track Up
7
7
Track Up
Your Kenwood should then enter tuner mode.
A Security Code Bug in some Kenwoods
There is a reported bug in the security code handling of some Kenwood stereos. In models with thie bug, the security code is stored incorrectly. The workaround is to enter the wrong security code.
In models with this bug, you have to decrement the third character of the security code by one. If your security code was 1111, you would enter your security code as 1101. If your security code was 9999, you would enter 9989.
Posted on Jul 15, 2009
  • 6 Answers
SOURCE: how can i remove protect mode on my kenwood
find the lil hole in front of the face use a paper clip to reset it if it keeps on doing it you got a speaker going bad
Posted on Mar 22, 2010
The radio opens with lights and lsights go out and immediately closes. Keeps opening and closing with no sounds. After doing so for a bout a year... radio came on. However did not come back on when I...
It sounds like it could be a bad ribbon cable. There are two ribbon cables in the deck, so it could be either one, or both. There is also a face position sensor lever inside the deck that goes bad.
Jul 22, 2011 | Kenwood KDC-MP822 CD Player
Unable to remove faceplate or eject cd on kenwood
remove the to of the unit, then the two in the actual cd player, pull out cd player, there will be two more screws,these hold the faceplate assembly in place, remove them. This will allow you to pull a small plastic hook down to let the face plate slide out. then remove the face plate from it's holder, slide it out. Remove the four screws on the back of the faceplate inside the there is a very small piece of plastic that has a hole at one end and squared at the other. This is the problem causing piece. I suggest super gluing this piece where it attaches to the inside of the faceplate. This should fix the problem.
Jan 17, 2010 | Kenwood KDC-516S CD Player
Kenwood KDC - MP 235
I would also check the speaker outputs from the deck. If any of the speaker outputs are touching any metal on the vehicle, it could give that message.
Dec 08, 2008 | iLO XM-MP3-CD Car Stereo
Random Power Off
desvio de llamadas se puso qe ago
Jul 15, 2008 | Kenwood KDC-MP205 CD Player
Kenwood kdc 7009 - just bought car w/ stereo in it, but no remote or codes ?
Look for a small hole in the face plate. Take the tip of a pen and try holding it in for a few seconds. Re-setting it should work.....
Jan 26, 2008 | Kenwood KDC-7009
Kenwood KDC-322
Jan 09, 2008 | Kenwood KDC-322 CD Player
Dec 03, 2006 | Kenwood KDC-715S
Kenwood KDC-MP145 Car CD/ MP3 Player Logo
74 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
