Question about Sony KP-46WT500 46" Rear Projection HDTV-Ready Television
Sony 46" rear projection LCD HD - picture and sound go on and off
Picture and sound go off, led by on/off button stays green. Then 2 minutes later it will come back on, pic and sound just fine. Then 2-3 minutes later goes off again and continues. If I turn the set off while it is in it's off cycle, the red LED flashes light the light is bad (but I know it is not becuase the picture comes on fine, for two minutes). If I turn the set off while the picture and sound are in the ON cycle, it turns off normally (solid red LED), and I can turn it back on normally. Butthen it only stays on for 2 minutes and will go off by iteslf, then back on again after 2-3 minutes.
  • 5 more comments
  • jheim Jan 27, 2009
    Will post model number shortly. Thank you.
    Thyank you - I'll likely have to do that anyway, but I'd like to have some idea of what it might be so I know I'm being charged fairly. Also, it shows it's a bad bulb by the red LED flashing, but the bulb works for 2 minutes, so I'm wondering if the bulb heats up and opens the circuit - would that cause the sound to go off on these sets too? I don't want to just guess and try a $300 fix until I know it has a chance of working.....
    By "Tube" you mean the really expensive light bulb? This is a rear projection LED - I was told the light buld would last 3-5 years and we're at 4 years now. The bulb used to $500, but I hear they're abotu $300 now.
    Model Number is KF50WE610
    OK - I will do that - Thank you very much.! I'll let you know if it fixes the problem.
  • jheim Feb 12, 2009
    welcomejee was rigth on. Repalced teh lamp and the set is now working fine. Thank you.
  • Shahid Electronics
    Shahid Electronics May 11, 2010
    Please intimate exact model of TV to help you out.
    Genius:
  • 2,920 Answers
Personally i would call a tv repairman out to fix the set.you can get alot of different opinions on here about what it may or may not be but the best thing to do is call a repaiman and let them fix it
Posted on Jan 27, 2009
  • 1 more comment
  • Ronnie Houston Jan 27, 2009
    it could be a tube is going out and yes it would also lose the sound because the tv is shutting down. if the tv is nice and worth fixing and its flashing saying the tube is bad then you know the basis of the problem
    it could be either one but im betting on tube...i may be wrong but the tubes seem to be a pretty common problem for these tvs and there are alot of complaints on here about the same issue and it winds up being one of the tubes.have a repairman chack it and tell you for sure because i cant really tell you which it is from here. he can at least tell you if its a bulb or a tube.
    that dosent tell me if its the bulb or tube just tells me about the tv is all
  • 10,594 Answers
TV symptoms shows weak Lamp and you need to replace Lamp.
Buy Sony original Lamp XL-2100U from Sony Accessories Store for $200 only.
Here is Lamp replacement procedure and its written in user manual too.
Thank you.
Tv turns on have picture then about 1-2 minutes later turns green then shuts off
very common issue indicating the Green CRT has shorted and will need replacement. You can get the Replacement Green CRT for your model from www.tvrepairworld.com they are listed under the Projection Tube CRT catagory
Feb 18, 2012 | Sony KP-46WT500 46" Rear Projection...
Turn on tv...green lamp blinks several times.lights up but no picture...press any remote button timer in green blinks...tv turns off and goes to standby
The tv "LAMP"LED light indication flashes or stay lit?The tv projection lamp been in this tv like 1/2 or 2 years?Tv been on and used like 4 or 5 hours a day?Yes,than the tv projection lamp life are over.Require a new tv projection lamp.
Nov 17, 2010 | Samsung HLP4674W 46" Rear Projection HDTV
TV powers off for no reason
Its your bulb on its way out.
the replacement bulb is a Sony XL-2400 But yours should definately be under warranty
Mar 20, 2009 | Sony KDF46E2000 46" Projection HDTV
Tv sound and pic goes out and green light flashes for 38 seconds
I have the same tv and it did the same thing. I replaced my lamp and it corrected the problem.
Jan 25, 2009 | Sony Grand WEGA KDF-60WF655 60" Rear...
Sony projection TV screen going black.
need to replace the bulb
SONY-XL-2400 replacement bulb
Jan 25, 2009 | Sony KDF46E2000 46" Projection HDTV
AKAI Rear Projection 46"TV has a blank picture with sound only
Is it a CRT or a DLP/LCD projector? If not a CRT, a worn-out projection lamp can cause this symptom. When it is a DLP projector, a faulty Colour Wheel sensor can be the additional problem. If it is a CRT projection unit the High Voltage and deflection circuit must be examined...
Please tell me more about your unit...
Thomas
Jan 19, 2009 | Akai LCT2715 27 in. LCD Television
No picture or sound
3 times error shows that lamp is not installed properly or lamp cover is off / not fixed.
If you replaced TV lamp recently then check lamp cover and make sure to seat it properly.
Need further info, let me know.
Jan 15, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Sony KF-60WE610 Screen and Sound On/Off
All symptoms in your TV shows that you need to replace its Lamp as it has been consumed its life hours and TV requires new lamp. Lamp can be obtained from Sony Website. Price is $200, Hope this info will help you to enjoy your Sony TV in coming days.
Aug 17, 2008 | Sony Grand WEGA KF60WE610 60" Rear...
Sony green power/standby led blinks picture goes out
I had this same problem and after doing some research, I removed the lamp, cleaned it and plugged it back in. It fixed my problem completely.
Mar 22, 2008 | Sony Grand WEGA KDF-60WF655 60" Rear...
Sony KP-46WT500 46" Rear Projection HDTV-Ready Television Logo
237 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
