Question about Tablets & eReaders
Coby kyros tablet wont auto-rotate anymore
My screen will not auto-rotate any more. i have tried the obvious rebooting it, and with no success. i have looked in my settings, and turned it off, then back on, but refuses to budge from landscape mode. i have a keyboard case that i got for it, and i thought that might have something to do with why it wont go back, but ive tried unplugging it and then turning auto-rotate back on: nothing. i've tried powering it off, then unplugging the keyboard: STILL nothing. if anybody can help me, i would really appreciate it!!!
anjana03
  • 361 Answers
SOURCE: tablet pc rotation
u can use once time alt+ctrl+ any type arrow to roated screen
Posted on Jun 13, 2009
SOURCE: Disable TC4400 auto rotate
First in Control Panel -> Tablet and Pen Settings, select Display Tab, then click on Change button next to Sequence. I set 1 as Landscape - Primary, then 2-4 as None.
Second, Go to Control Panel -> HP Quick Launch Buttons -> select Preferences tab -> uncheck the checkbox that says, "Enable Automatic Mode Change"
This worked for me!
Posted on Jun 16, 2010
  • 76 Answers
SOURCE: my apps libaray on my
Sounds like you need to reset AppsLib.
This fix will wipe all your data, so be sure to back everything up.
Go to Settings.
In settings go to Go to "Privacy".
Select Factory Reset.
Select Reset Device.
Connect the unit to the computer using the USB cable and "Select" Erase Everything" The following will occur: • The screen will display COBY • The screen will display Android • The unit will reboot to the Menu screen
Step 6- The unit will prompt to calibrate. Hold stylus on the center of the target. Repeat as the target moves around on the screen. ****DO NOT *** press Return or Home". The unit will display "calibrate success" and will return to the main /home menu automatically. If for any reason the unit went into standby mode and the touch screen does not respond, reset the unit using a pin.
After the Factory Data Reset, do not launch the Applibs yet until: 1- You have configured your Wi-Fi 2- Check/enable "Unknown Sources"- Go to Settings, Application Setting. Done.
You can now open appslib.
Posted on Feb 28, 2011
  • 14 Answers
SOURCE: everytime i turn on my
Link
phandroid.com/2008/10/25/how-to-reset-your-g1-and-start-from-scratch
"It came time to part with my review unit of the G1 (Thanks T-Mobile!) and send the phone back to its rightful owner. But what about all the personal info on the phone? The apps, texts, e-mails, AIMs and all that jazz? A quick search of AndroidForums.com turned up an easy way of restoring your G1 to factory settings:
if you power off your phone and hold the home (shaped like a house) and the end (red hangup button) for about 20 seconds you get a triangle with an exclamation point and a picture of the G1.
Now all you have to do is pop open that pretty QWERTY keyboard and there are several keyboard shortcuts you can use to accomplish what you want to do:
Home+Back reboot system now - (Soft Reboot)
Alt+L - Toggle log text display - (Toggles between the exclamation and menu options)
Alt+S - apply sdcard:update.zip - (Not brave enough yet)
Alt+W - Wipe data/factory reset - (What I chose, had to re-register, out of the box settings)
thee last option (Alt + W) and restored my borrowed G1 to factory settings. I'm sure the soft reboot could be helpful too, should you run into problems a troubled application may have caused. We didn't try the other 2 options so use at your own risk.
By the way, I couldn't live without a G1 so I made the leap and purcahsed a G1 with a T-Mobile service plan. I'm still a loyal Verizon customer and will simply have to keep both plans... but I NEEDED the G1. So basically, you can expect the application reviews and insight you've gotten at phandroid.com to cotinue since we've got our very own device now!
[Via Android Forums]
Posted on Apr 08, 2011
SOURCE: my coby kyros internet tablet wont turn on
i cannot turn on my coby kyros internet tablet after charging and there are no answers or problem tips in user manual
Posted on Jul 11, 2011
After i system reboot my tablet the screen is not working anymore
the screen could be bad. i broke mine and just used a mouse and keyboard with it, till i can get a new screen
Mar 24, 2014 | Coby Kyros Tablet
Coby kyros MID 7022 wont unlock main screen....swiping only meets halfway then screen goes black..help?
ok try the reset button plug the power cord before you start. look where is the reset and use a small point toothpick .
Nov 03, 2013 | Coby Kyros 7" Touchscreen Tablet
Coby Electronics Corporation Coby Kyros MID9042-8 9" 8 GB Tablet Computer - keep shutting down
Turn the tablet all the way off, press and hold the VOL - and power at the same time for 8 to 9 seconds, it will show a green android guy with a system recovery menu. Use vol - to go down to Wipe Data/Factory Reset, press the power button to select it, go down to 'yes' to confirm, press the power button to select it, it will wipe the tablet, you then press the power button on 'reboot system'.
Apr 23, 2013 | Tablets & eReaders
My coby kyros mid9742 will not start up at all it just keeps rebooting
Apr 19, 2013 | Coby Kyros 716829701508 Tablet PC
My coby screen is frozen
i forgort my password on my coby kyros i tried to reset but it keeps going to my password
Mar 22, 2013 | Coby Kyros 716829701508 Tablet PC
I need to download driver software for my coby kyros MID7015 so i can sync it to my pc
i have coby kyros mid7010-4g tablet
it just load the coby logo then penguin logo then android_ text
i tried the factory rest ( power + back + home ) ..
it gives " Unexpected updater mode! Please reboot your device.
How do i proceed from here Any help please.
Mar 20, 2011 | Coby Kyros 716829701508 Tablet PC
My apps libaray on my coby kyros mid7015 isnt working!!! everytime i try to go into the apps libaray it keeps saying that theres been an unexpected problem and that it has to "force close" why is...
Go to Settings.
Feb 28, 2011 | Coby Kyros 716829701508 Tablet PC
Tablets & eReaders Logo
65 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
