Question about GPS
My wondermedia wm8650 gets stuck on loading screen
My wondermedia wm8650 gets stuck on loading screen how can i hard reset it
4 Suggested Answers
SOURCE: WonderMedia WM8650 Android 2.2 7"
1. Go to Settings
2. Go to Applications
3. Go to Manage applications
4. Go to all tabs
5. Gp to "Market" applications
6. "Clear Cache" then "force stop" - DO NOT CLEAR DATA
7. Now go to "google service framework" applications
8. "Clear data" then "force stop"
9/ Reboot your machine/
This should solve your problem
Posted on Dec 14, 2011
bronk50
  • 27725 Answers
SOURCE: forgot my wondermedia wm8650
restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
Windows Advanced Options Menu
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice
select safe mode with command prompt
Click start run type cmd press Enter
black screen should open DOS mode
this will vary depending on your operating system
type in net user username
For eg. If you want to change administrator password , type net user Administrator
it will prompt you to enter the new password
enter the new password and the password is changed
if this fails you will need to
Select safe mode with networking to download
you could download all of these or just one save them to a usb drive for later use if one fails to remove the password
Windows Password Recovery Basic
http://majorgeeks.com/CmosPwd_d239.html
A CMOS BIOS password recovery tool
Editors note: This tool should only be used by experienced computer users. Please see the enclosed read me if you would like to run it from Windows. Failure to follow instructions (from Windows) will cause your anti-virus to flag this as a virus.
http://majorgeeks.com/Dr._Freeware_System_Utilities_d6416.html Dr.Freeware System Utilities which includes data recovery software, data backup, password reset tools for Windows helps you to maintain your system. Dr.Freeware is freeware, you can download and use it for free.
hope this helps
Posted on Oct 18, 2012
  • 35 Answers
SOURCE: How to master reset or reinstall software for a WM8650 UBEROID tablet?
Try see my blog lol, you can see video how to reset your tablet.
http://pcgadgetdeni.blogspot.com/2013/02/forgot-passwordpattern-unlock-of.html
Posted on Feb 26, 2013
My gotab 7 is stuck on the android loading screen how do you fix that
Turn off your gotab hold the volume up button and power button down at the same time. Then it should say recovery menu in red letters on the screen? Then press and hold just the power button again to hard reset the device I hope this helps?
Oct 05, 2014 | Aquachek Extra Strength Tylenol GoTabs
Feb 26, 2013 | Tablets & eReaders
My wondermedia wm8650 gets stuck on loading screen when i turn it on
Test your PSU power supply unit or replace it if your power supply units fan is not working your PSU is faulty http://pcsupport.about.com/od/toolsofthetrade/f/powersupplytest.htm WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards Remove the memory modules from their slots. Take the opportunity to clean the slots on the motherboards and the memory module connectors. Use compressed air to blow dust away and clean contacts with a soft cloth. Do not use a metallic vacuum cleaner if it touches any component it may create a short and cause damage to the motherboard or other components. Do not use solvent that may attract dust and never poke things like cotton buds in to slots. lightly rub an alcohol (Methylated Spirits) on a cloth not to hard let the alcohol do the work on the copper gold or silver tabs and r Allow the pins to dry. They will air dry in a matter of minutes. If reseating the memory did not resolve the issue try swapping the location of the memory. If you have only one stick of memory in the computer try moving it to another slot and then boot the computer. Check the memory module and memory slot contacts. They are either copper tin or gold. The colour will tell you which they are. Mixing tin and gold can result in corrosion that prevents proper contact. Look for any sign of physical damage to the memory module, memory slots or the motherboard. Reseat the memory modules. You should hear an audible click when they are in place. Do not use too much force to reseat the memory module in to the slot this can cause damage to the module, slot or motherboard. The hardware that you are trying to access is damaged or failing.
The device drivers for the hardware are faulty or incompatible. Could be a problem with the Hard Drive or the Hard drives PCB http://www.onepcbsolution.com/ There is a connection problem such as a bad cable for internal hard drives
Test all power and data leads that attach to your hard drive IDE,SATA
the leads from your MOTHERBOARD TO THE HARD DRIVE make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty if its a flat 40pin ide this will be the first to fail Make sure all leads that are attached to your drives dvd\cd and floppy (If Applicable) have secure connections and are not faulty. or just replace them they could be faulty a computer needs power and data to travel through every working device and continue its cycle and have an end so any faulty leads will end up with a computer error
Hope this helps.
Jan 22, 2013 | Computers & Internet
My maylong m250 tablet is stuck on start up screen iv used the needle sized pinhole to reset , that doesnt work i need to know how to unstick this home screen
Hi ,
Have you tried removing the battery , this will also reset your tablet ,
please let me know if this works ,,,,,thanks good luck Roy
Nov 19, 2012 | Computers & Internet
Forgot my wondermedia wm8650
Safe Mode
Enable Boot Logging
Enable VGA mode
Debugging Mode
Reboot
hope this helps
Oct 16, 2012 | Computers & Internet
How to fix a hanged/frozen/non responsive Maylong M-250 tablet
You need to reflash it with a new firmware via the Micro SD slot. Just did this for mine and now it works great. The tablet has the chip WM8650. Use WM8650 uberoid v121.
http://www.androidsoldier.com/2013/08/universal-wm8650-uberoid-v121-all-in-1.html
Aug 15, 2012 | Maylong M-250 Universal Tablet PC
1. Go to Settings
4. Go to all tabs
Sep 05, 2011 | Computers & Internet
1300 nuvi screen comes up loading maps and stops
A Garmin Nuvi 1300 that freezes on 'loading maps,' or is acting erratically is symptomatic of having corrupt firmware.
To correct this, I recommend backing up your favorites, clearing all user data, and if it still is stuck, then updating your Nuvi firmware.
Follow these three steps to take to get your Garmin Nuvi 1300 running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin WebUpdater to replace its firmware / system software.
I hope that helps.
_______________________________________
Garmin Nuvi 1300 Manual Download
Garmin Nuvi 1300 QuickStart Download
Garmin Nuvi 1300 Favorites Backup
Garmin Nuvi 1300 Hard Reset
Garmin Nuvi 1300 Webupdate
May 19, 2010 | Garmin nuvi 1300 Car GPS Receiver
New GARMIN 660 Won't get past the Intro screen
Problem solved: I got through to Tech Support. They suggested a 'hard reset', which solved the problem: Put you finger on the lower right screen while you power up and it will do a hard reset---and it will get past the "loading maps" screen, where it had been stuck.
Dec 25, 2007 | Garmin Nuvi 660 GPS Receiver
GPS Logo
94 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
