Question about Kodak ESP Office 6150 All-in-One Printer
My printer head won't move in my kodak printer
Printer head dosn't move when printer is on
Printer won't print in colour, keeps saying recalibration needed
Blocked print head nozzles
Inkjet printers need to be used frequently to prevent blocked print head nozzles. You may have blocked print head nozzles.
Try the printer maintenance to clear the printer nozzles.
After several deep cleaning attempts and there is no improvements in the print then a new print head is required. Also try - Removing the print head, run it under hot water for 2 mins, then let soak for 10 min. then used a can of compressed air to dry thoroughly. It may fix the blocked nozzles.
A new print head maybe expensive and it maybe more cost effective to purchase a new printer.
Sep 24, 2012 | Kodak ESP 7250 All-in-One InkJet Printer
My kodak 7250 printed from the laptop wirelessly before we moved across town. Now says disconnected
If the printer is not connecting to the wireless router, you need to address that problem first. It wasn't clear from your problem description whether or not that is the case. If the printer is getting a successful wifi connection then you may need to delete the printer from your PC and re-add it.
Jun 30, 2017 | Kodak ESP 7250 All-in-One InkJet Printer
Electrical problems with a 2002 Satun SL 200, the electrical door locks dosn't work, the mirror adjustments dosn't work, the dome light dosn't work. The engine runs good. head lights work
check all your fuses in engine compartment and under dashboard engine check light comes on every 3000 miles for oil change reminder
Jul 23, 2012 | Cars & Trucks
Kodak 7250 print head jam
This problem has plagued me for a very long time. The issue is that the printer head is "glued" in the resting position under the guard of the printer, so you can't remove the ink cartridges to clean it. Solution is to (I know this sounds stupid, but it works) turn the printer on the side where the printer cartridges are (if they are stuck on the left side, turn the printer on its side so the cartridges are on the bottom). Turn the printer on, and the cartridges magically start moving! I guess there are some sensors that get tricked out when you tip the printer on its side. If the cartridges are still stuck, click the "ok" button, and before it gets a chance to see if you actually fixed the problem, turn the printer off using the power button. It takes a long time, but you should see the ink trap lower (release the ink cartridges) and the ink cartridges start moving to prepare for shutdown! Grab the cartridges when they move out of their hiding place and don't let them go back until you clean the print head so it doesn't get stuck again. Remove the ink cartridges, then push the grey tab to release the print head. Wipe the bottom of the print head clean with rubbing alcohol (it will have a lot of gooey - sticky ink stuck on the bottom). I used nail polish remover since I didn't have rubbing alcohol available. You can also wipe down the ink pad which is where the ink cartridges were previously jammed to clean up more of the mess and prevent this sort of thing happening again too soon. Good luck!
Jan 20, 2012 | Kodak ESP 7250 All-in-One InkJet Printer
WE HAVE A KODAK ESP-3 AND HAVE PUT IN NEW INK (BLACK) AND IT WON'T PRINT. THE COLOR SHOWS EMPTY BUT IT'S ALSO NEW. ONLY WANT TO PRINT BLACK BUT IT WON'T PRINT EITHER JUST SHOWS LOW INK ETC.
First: you need both ink cartridges for the printer to function properly.
Second: You may have a bad printhead, do the following:
Clean the print head then print a demo sheet.
  1. Verify that inkjet paper is loaded in the paper trays.
  2. On your desktop, start the KODAK All-in-One Home Center, then select the Help [?] icon.
  3. From the Help menu, select Maintenance, then select Print head Cleaning. The On/Off light flashes green during the cleaning procedure.
  4. When the On/Off light glows a steady green, press Photo and Copy simultaneously to print a demo sheet.
If the Demo print is bad- IE: no black, blurry print etc., then you may need to replace the print head:
http://www.kodak.com/global/plugins/acrobat/en/service/manuals/AiOPrinters/printhead/AUR1780-9_UE_RevC.pdf
Contact Kodak:
All-in-One Printer Phone Support Live telephone support is available in English and Spanish at 1-800-421-6699, 9 A.M. to midnight, Eastern Time, 7 days a week. The expected wait time for phone support is 15 minutes.
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Jun 27, 2011 | Office Equipment & Supplies
I hae come back from holiday to find my printer is'nt working. Its a Kodak ESP3200 Series and I have had about two years. The on/off switch is on all the time and the LCD screen is blank and nothing...
Try to reset your printer to factory default settings. But before you do that, I'd like you to do this first.
  • Open the printer access door.
  • Remove and install the print head two times.
  • Close the printer access door.
  • Wait until the printer is ready to use.
if this won't work.
reset all defaults to the factory default settings:
1. Press Home. 2. Press "arrow down" to select Printer Settings. 3. Press "arrow down" to select Reset All Settings, then press OK. 4. When you see the message, "This will reset printer settings to factory defaults," press OK
Hope this helps.
Jun 17, 2011 | Kodak Office Equipment & Supplies
Printer error 3515
Kodak ESP-5 error message 3515....tried Kodak way but didn't work....could hear the print head attempt to move but couldn't...unplugged unit from power....opened to expose the print cartridges...removed small screws on sides and back of printer...gently pry open top....turn gears on right side with finger toward front several turns.....check and see if print head will now move to center....(I removed cartridges and print head so I could see the blotter under print head move to back position. Re-installed print head and cartridges.) plugged power cord back in and turned on...unit cycled and then screen showed normal....replaced screws in top panel.....printed test page...back in operation......Don't be heavy handed....plastic will break very easy I think when opening panel if not careful...
Dec 28, 2010 | Kodak ESP 5 Printer
How to clean printer head esp 5 kodak printer all in one
I have replaced my Kodak ESP Printer head twice in two years. I'm with who ever said Kodak refuses top acknowledge the problem. The customer service told me that all printers have problems and they get very few complaints. I dont think I'm buying anymore Kodak products.
Sep 27, 2010 | Kodak ESP 5 Printer
What does error code 3820 mean for a kodak esp5 all-in-one printer
The error message "Carriage Home detection failed" (error code 3820) can be resolved by following these steps:
To resolve this error:
1.Open the printer access door.
2.Disconnect the power adapter from the printer.
3.Gently hold both sides of the carriage, located immediately behind the print-head, and make sure the carriage moves freely.
•If the carriage does not move freely, contact Kodak.
4.Remove the print-head and ink cartridges.
5.Reinstall the print-head and ink cartridges, making sure each clicks into place.
6.Connect the power adapter to the printer.
7.Turn the printer on, if necessary.
8.Close the printer access door.
If the error continues, contact Kodak.
Sep 07, 2010 | Kodak Office Equipment & Supplies
Kodak ESP Office 6150 All-in-One Printer Logo
102 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
