I need the size of the belt or i need to know if all serpentine belts are innerchangable
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
SOURCE: I need the serpentine belt diagram for a ford
Here are two links to take you to the serpentine belt diagrams... choose your engine type.
V6-24 valve engine
http://www.gates.com/common/part_locator/view_diagram.cfm?id=S5021
V6--12 valve engine
http://www.gates.com/common/part_locator/view_diagram.cfm?id=S7021
SOURCE: ford 2002 ford taurus belt
Here is the belt routing for the V6 Taurus. Basically the belt zig zags between adjacent pulleys, the back of the belt on the smooth pulleys and the inside on the grooved ones. Tension the belt so that you can twist the belt 90 deg on its longest run without too much force. Hopefully this helps you.
