Question about Ruud Central System Air Conditioner
My furnace keep cutting off
It shows 1 blink so i cut power off then on and then it will run for a while and turns off again
    Problem Solver:
  • 13 Answers
1 blink usually indicates ignition failure. if burners are lighting then cutting off, watch for amber light ( flame) on board, if its not lighting up, then flame sensor needs to be cleaned or replaced.
Posted on Oct 27, 2013
3 Suggested Answers
  • 1015 Answers
SOURCE: I have a Ruud Ac
The first thing I would do is to replace your thermostat. They are not very expensive and it sounds to me like it is defective. Thank you
Posted on May 13, 2011
  • 92 Answers
SOURCE: Ruud achiever 90 plus won`t start at times
sounds like you have a heat pump heat pumps dont work below 30* temps you should have some type of backup heat
Posted on Feb 05, 2009
Furnace wont keep kicking back on. On its own, led light does blink 3 times stops and blinks 3x again
Without knowing fuel or model, it could be bad relay in primary control or loose wiring, on either power or t-stat side.
*I never recommend homeowner attempt to repair/replace any parts on heating appliance. Any information is strictly to educate homeowner on functionality. Always contact a heating professional for service and annual tune-up.
Feb 13, 2016 | Heating & Cooling
Top rollout switch triggers with blinking code *6*, Furnace only runs with cover off
restart unit as soon as your inducer fan came on pump the 2 wires to pressure switch and wait to see how long it stay also watch the flame at the burner
Jan 27, 2014 | Goodman GMS90703BXA Heater
After preheat the fan cuts in for 10 sec then cuts out, cuts in for 15 sec, then cuts out. this continues to longer interviles. I have replaced computer box twice and have spent hundreds and problem
Try Googling the problem. Who have you paid so far, someone from the gas company, or a private technician? Was the technician from an Intertherm dealer? I would think a dealer would have qualified techs.
Nov 26, 2013 | Intertherm 56000 Btu Gas Furnace
Furnace runs 10 seconds and cuts off and will not run again till you adjust the thermostat runs for ten seconds and shuts off again
Don't keep in nutral position (50%) since the cut off and cut on ma be frequently. But your thermostat seems to be faulty as per your statement. Replace it.
Oct 25, 2011 | Weather King 12AJA4801AH Air Conditioner
I have a Ducane MPGA100B4B gas furnace. The furnace only runs for about a minute then shut off. It does this far too frequent.\r\n First the induce draft blower turned on for a few seconds to check for...
Hello, sounds like the limit switch is opening on the furnace.Usually when a furnace goes off on its high limit is becuase the airflow is being restricted making the furnace overheat. a limit switch is there to protect the furnaace from overheating, most cuases are either dirt or the blower motor not running up to speed, anything that cuts down on the airflow will cause the high limt switch to open.
Feb 24, 2011 | Heating & Cooling
The furnace will kick on and the burners will keep going out the process will continue unless i shut the power to the furnace off for five minutes then cut it back onit will run good but the problem will...
check your air filter, a very dirty filter will cause the unit to over heat "180'" The burners turn off the unit cools itself with the blower and then relights.
Jan 24, 2011 | Goodman Heating & Cooling
Gas furnace cycles on and off every 2-3 mins. then the gas cuts off and the fan keeps blowing until the power is cut off. The led light blinks twice.Any ideas?
check out your fan control could be dusty at the back remove it and clean it also check air fiter is clean , or tthe fan conrtol could need replacing
Dec 03, 2010 | Honeywell Programmable Thermostat Heater
Tv cuts off and green light flashes
Yup, it seems a lamp problem can give a blinking green light over the 10 times (1 - 10 times for diagnostic codes), but in my case rather than replace the bulb if it works for a minute then resets with the green light blinking, do what I did.
Take the lamp out and inspect it, it has breather screens top and bottom, if it cant breath because there clogged with dust, clean them, and you can remove the screens, use q-tips and clean the inside. I saved the cost of a lamp and it's working fine!
Jun 27, 2008 | Sony Grand WEGA KDF-55XS955 55" Rear...
Ruud Central System Air Conditioner Logo
76 people viewed this question
Top Ruud Heating & Cooling Experts
Donni Steen
Bill Long
Tim Whalen
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
