Question about HP DesignJet 5000ps InkJet Printer
Hp designjet 5000 will not see the media, says load media
Media is loaded but it dose not see it, tried to load and unload and it says ready for media
There is a sensor located at the media entry side just before the platen. The assembly can be reached from underneath the rear side of the plotter. The cover has three pressure snaps to remove the cover. The flag is bi-directional, Check to see if it has snaped off its cradle or has broken. If not the sensor is bad, or the flag has worn down below its threshold.
Hope this helps..Good luck
Posted on Jun 20, 2012
SOURCE: Loading Media for DesignJet 330
played with the set up procedure and it fixed itself. thx for the followup
Posted on Sep 09, 2008
  • 53 Answers
SOURCE: HP designjet 430, the data and media light come on at power up
The sad part unfortunatly is that the sensor on the carrage is below minimum specification. The only solution is to change the carrage as a unit P/N C4713-60039 and its going to be expensive. Normally the carrage belt would be replaced at the same time.
Dave
Posted on Feb 23, 2009
  • 53 Answers
SOURCE: Media Rejection
edgie46,
I have some bad news for you. The media sensor is faulty. This sensor is not sold seperatly. The entire pen carrage (head) has to be replaced at quite a cost.
Your part number from an HP parts supplier is C4713-60039
Its strange that is a refurbished machine with a faulty carrage. Maybee you can claim under a warrenty
Posted on May 25, 2009
  • 22 Answers
SOURCE: HP DesignJet 430 wont accept media
This is the problem with the sensor. It tries to read the size of the paper, the sensor is on the side of the carriage assy(cartridges are installed on this assy). You can try cleaning this sensor or get it replaced or some times the service center will replace the carriage unit as a whole.
Posted on Dec 01, 2009
Testimonial: "Is there a specific proceedure that I would use to clean the sensor?"
  • 123 Answers
SOURCE: HP DesignJet 430 rejecting media
When you load the paper, the carriage edge detector measures exactly where the right edge of the paper is located. Then the paper is rolled forward and the edge is measured again. If there is a difference in the measurements, the printer assumes the paper is not loaded squarely and rejects the paper. After you load the paper and the printer asks you to align the paper, take your time, release the paper with the release lever, and line up the right edge of the paper with the right edge of the paper roll. You might have to do it more than once to get it to load. Some plotters are very sensitive and others are more forgiving.
Posted on Apr 15, 2010
Plotter wont recognize edge of clear films when loaded from a roll or sheet. recognized plain paper fine
I would check the sensor on the carriage that detects paper. It might be dirty enough that printer cannot detect the subtle edge of the clear film. It is the blue light that turns on on the bottom of the carriage when you load paper.
Apr 18, 2015 | HP DesignJet 1050c plus InkJet Printer
HP Designjet 5500. Showing message: Media loaded incorrectly. Please see the attached picture, It comes when media already loaded and we switch on machine.
Media loaded incorrectly. Remove media
The media is positioned or aligned improperly.
Before the printer can continue, you must remove and
reload the media. See "Loading Rolled Media" in the User Guide.
media is
H/P Designet 5000 series front panel messages per website
Nov 06, 2013 | Office Equipment & Supplies
Error 45.1.03 for t770
switch off the machine, remove paper and spindle of both roll & 2, close the roll covers, switch on the machine wait until ready mode appears, select load media, select roll 1. Load spindle in in the bank, verify properly seated or not, insert paper to load wait to printer perform load media..if successfully loaded issue closed..:Other services are not advisable to users only professionals can resolve the issue..
Feb 01, 2012 | HP DESIGNJET T770 Printer
Hi i have just inherited a designjet 430,it is not connect to a computer as yet. i have loaded a roll of paper and ran some tests which seem to work ok except when i press the set up button the media light...
Either: the sheet you loaded is
misaligned.
Realign it again. See the Users Guide
for a short tutorial on loading media.
Or: it is an invalid size.
For supported media sizes, refer to the
Users Guide.
Or: the media lever is lowered.
Raise the lever.
Or: the cover is open when the printer is
initializing.
Lower the cover
These are the trouble shooting suggestions from the HP service manual
May 01, 2011 | HP DesignJet 430 InkJet Printer
We spend a large portion of our day desperately trying to load paper and always getting the "paper loaded with too much skew" message. The paper is straight and on the blue line, i'd love to trun...
What type of paper are you using? It's common on cheap canvas or fabrics. Make sure the beginning of the roll about 10 inches must be straight in right side (blue line side). The paper slips upward freely and straight before lowering blue lever. Also this problem appears when your room is dry (low moisture) then PP sticker and some photo paper will curl. This checking feature is very useful for printing on whole roll in a single feed.
Mar 22, 2011 | HP Designjet Z6100 InkJet Printer
MY designjet 430 all of a sudden is not printing straight, but is printing wiggly lines. Any ides on how to fix this?
You can try Print-Quality Plot test to diagnose the problem. Load paper, when ready light up, then press Form Feed and Media Source keys together. After print is done, unload paper.
This plot consists six tests. The third one is Vertical Line Straightness (VLS) test. You can read the HP 430 Service Manual page 6-7, 6-8 and 6-9. These articles will tell you how to correect the problem.
Sep 01, 2010 | HP DesignJet 430 InkJet Printer
Sep 25, 2009 | HP DesignJet 430 InkJet Printer
Media Rejection
edgie46,
May 01, 2009 | HP DesignJet 430 InkJet Printer
HP DesignJet 5000ps InkJet Printer Logo
148 people viewed this question
Seeker5211
Seeker5211
