Question about PSC QS6000 Plus Handheld
QS6000 Plus with USB programing question
Is programing a QS6000 different with the USB cable?
I have several QS6000 + with the keyboard cable and a book that works for them r44-1540 (rev K) 1999. The one with the USB cable works with barcodes but it adds 2 enters or something.
I tried using my book to reprogram. Return to factory just puts the following on the screen:
000
010
000
Set gives me:
000
end:
000
IS there a different book for one with a USB?
QS6000 Plus
CLASS:QS6-A100 I/F:UNIV USB PC(?)
DATE NOVEMBER 13, 2005 (or maybe 2006)
The document below programs the QS6500 Plus Scanner
R44-2805A Rev C
Available from
http://www.scanning.datalogic.com/sitefiles/manuals.aspx
Posted on Feb 20, 2009
QuickScan 6000 Plus cant get it to work with windows 7. If i use ps2 port, the red scanninglight dissapears after one scan. If I use an converter ps2 --> usb and plug it in usb port, it seems to work...
try the other usb ports. sometimes that works. also make sure that your other usb devices are off if possible. If you are using a usb keyboard try using a ps/2 keyboard. If you have an open usb port in the front try using that instead. I have seen this many times. Good luck.
Sep 22, 2011 | Datalogic QuickScan QS6000 Plus Bar Code...
I have a Dell Optiplex 320 running Windows XP SP2. If I plug in the QS6000 Plus USB Scanner it hangs while booting up. If I wait until Windows has started and plug in the scanner everything works. I have...
Most probably you have only one slot of RAM (a 256MB) if so you will need to upgrade it to more such as 1GB of RAM, the problem seems to be that the OS needs more Random Access Memory to connect with your Scanners drivers and make them part of the system such that you can be able to use it when you log in this becomes a problem as with limited Memory the OS fails to read the drivers and linking the scanner gets interrupted thus hanging on startup as it has other processes using the RAM at the same time and thus sharing it with the Scanner drivers and configurations. After other programs and processes have finished to run and minimal background processes are left after logon then this means more RAM is available so the Scanner can work easily when plugged at this point.
Mar 24, 2011 | PSC QS6000 Plus Handheld
Ive got a second hand psc qs6000 plus barcode scanner. where do download its driver.
If you are looking to program your scanner:
USB Interface
Keyboard Interface
If you are using the USB interface, make sure you are plugging the scanner either directly into the computer, or if you are using a USB hub, it is a powered hub.
I hope this helps.
Aug 20, 2009 | PSC QS6000 Plus Handheld
Windows XP does not recognize the Handheld scanner.
My guess is that the USB hub needs to be plugged in ... if for some reason the usb hub doesn't allow you to plug it in then you need to get one that you can plug in... because I believe the scanner is using more power that the usb port can power. Scanner usually need to be plugged directly into the computer or they need to be plugged into a powered hub.
I hope this helps!!!
cdixon18
The Man Inside the Machine
May 11, 2009 | PSC QS6000 Plus Handheld
Psc qs6000 plus
If, during the programming session, you find that you are unsure of the scanner's settings or wish to reset the scanner's configuration, use the Return to Factory Settings label available in the Programming Overview section of the above programming guides. (Note: Use this label with caution, as it will disable ALL features that may have been programmed since the scanner's installation.)
Apr 08, 2008 | PSC QS6000
Programming a USB PSC QS6000 Plus
Everything you need is came from your system mechanism. The only way to control your requirements is came from your programm coding.
at the start of the string sending must be filtered and rearrange from your program mechanism.
From what system you need to used barcode scanner? Are you using POS?
Hope you like my solution please rate me Solved.
best regards,
Philip
Nov 04, 2007 | PSC QS6000 Plus Handheld
QS6000 Plus barcode scanner
you can not change a qs6000 from ps2 to usb by just changing the cable. the interface inside the unit needs to support usb, to check this look at label with the serial number and if it says "I/F=KBW/RS" your our of luck, and can only use ps2 or rs232. if it says "I/F=UW" then you can just scan 3 barcode from the manual to set the interface to usb
Aug 28, 2007 | PSC QS6000 Plus Handheld
IBM Powerd USB not working
Are you using a USB 2.0 port?
Try a different USB cable.
PSC QS6000 Plus FAQ
Nov 28, 2006 | PSC QS6000
PSC QS6000 Plus Handheld Logo
871 people viewed this question
Top PSC Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Jax Planet
Jax Planet
Roshan Rijal
Roshan Rijal
Are you a PSC Computer and Internet Expert? Answer questions, earn points and help others
