Question about DLX 500 Remote Car Starter
Headlamps work all the time
I installed a bulldog carstarter in my ford 500 and since then I am not able to turn my headlamps off, turn my parking lights on, and the headlamps stay on for seven minutes after the car has been shut off. I tried resetting the amount of time that the lights stay on but it will not reset to that time.
  • 344 Answers
Pull the parking light fuse from the wire harness on the remote starter, it should be a blue 15amp not the green 30 amp, if that works you wired the parking light wire to the wrong one, if not post me and we will go from there
Posted on Sep 29, 2009
2006 f650 no instrument panel lights or running lights can't find the fuse
First , do the headlamps work ? There is a fuse for the headlamp switch F2.17 - 15 amp located in the central junction box ( inside the vehicle fuse box ) also F2.7 a 30amp . . When you turn on the headlamps or just park lamps the dash lights an the running light's should come on . I see in the wiring diagram that there is a microprocessor involved in the operation of the lights . Also i see there is a relay PARK LAMP relay located in the vehicle security module .
Mar 29, 2017 | Ford Cars & Trucks
2000. Where is fuse for tail lights?
Do your headlamps work ?
Park/Marker/License/Tail Lamps
Voltage is applied to the turn/headlamp switch at all times. When the turn/headlamp switch is in the PARK or the HEAD position, voltage is applied to the following components:
The park lamps
The marker lamps
The tail lamps
The license lamp
The front marker lamps are grounded through the turn filament of the respective front park/turn lamp. The front marker lamps light as a result.
The automatic lamp control function turns on the park lamps and the headlamps. This action occurs when the ambient light sensor determines that the exterior lamps should be turned ON based on the amount of available light. When the BCM grounds the park lamp relay, voltage is supplied directly to the park lamps, bypassing the turn/headlamp switch assembly. When this action occurs, the following conditions exist:
The automatic lamp control relay is grounded.
The headlamps turn ON. Refer to Headlights/Daytime Running Lights (DRL) Circuit Description .
The lamps turn OFF when the BCM does not ground the park lamp relay or the automatic lamp control relay. This action is caused by the following conditions:
The available light reaches a predetermined level.
The ignition switch is turned to the OFF position
Mar 31, 2016 | Pontiac Grand Am Cars & Trucks
No low beam. Good high beam. No day lights. What's wrong?
No on the fuse . The LH HDLP and RH HDLP fuse in the fuse block - under hood, supply battery positive voltage to both low and high beam lamps at all times. For manual operation, when the headlamp switch is in the ON position, the headlamp switch supplies ground directly to the headlamps and to the body control module (BCM) on the headlamp low or high beam signal circuit, depending on the position of the headlamp dimmer switch. The BCM uses this signal to determine if the conditions are present to illuminate the daytime running lamps or park lamps.
The headlamps may be turned on 2 different ways. First, when the driver places the headlamp switch in the ON position, for manual operation. Second, with the headlamp switch placed in the OFF position activating automatic lamp control (ALC).For ALC operation, the BCM receives a signal from the ambient light sensor indicating a low or high ambient, outside, light level. Under low light conditions the BCM grounds the headlamp relay control circuit energizing the headlamp control relay. The now closed relay supplies ground through the headlamp switch to the headlamps and the BCM on the headlamp low or high beam signal circuit, depending on the position of the headlamp dimmer switch. When the BCM grounds the headlamp relay control circuit it also grounds the park lamp relay control circuit illuminating the park lamps. The headlamp relay is grounded at G203.
Daytime Running Lamps (DRL)
The low beam headlamps operate at reduced intensity when in daytime running lamps (DRL) mode. The ground circuit to the switch side of the DRL relay has a resistor in-line to reduce the intensity of the low beam headlamps for DRL operation. The body control module (BCM) receives a signal from the ambient light sensor indicating a low or high ambient, outside, light level. Under daylight conditions the BCM grounds the DRL relay control circuit energizing the DRL control relay. The now closed relay supplies ground directly to the low beam headlamps and to the BCM on the headlamp low beam signal circuit. The low beam headlamps now illuminate with reduced intensity. The DRL relay is grounded at G203. Any time the headlamps are illuminated the DRL will not illuminate. Manual park lamps do not effect DRL operation.
Feb 23, 2016 | 2005 Chevrolet Equinox LS
2010. where is DRL module located?
Daytime Running Lamps (DRL) NOTE: The smart junction box (SJB) must be configured when installing a new module. For additional information, refer to Section 418-01 .
The DRL system operates the low beam headlamps at a reduced intensity. The SJB supplies pulse width modulated (PWM) voltage to illuminate the low beam headlamps at a reduced intensity when the following conditions are met:
  • The headlamp switch is not in the HEADLAMPS ON position.
  • The ignition switch is in the RUN position.
  • The transmission is not in PARK (P).
This dealer only repair ,unless you have the ford IDS (factory scan tool ) .
Nov 18, 2015 | Ford Explorer Cars & Trucks
Why does my 1999 chevy malibu headlights turn on by them self in middle of night
You have a gremlin ! No , just kidding . No it's not the ignition switch ! The headlamps right an left have there own fuse in the under hood fuse box . LH HDLP - RH HDLP . Power direct to the head lamps an they ground through the headlamp switch when placed in high or low beams . Next time they come on wiggle the headlamp switch an see if they go out ! Does your vehicle have auto lights ? Day time running lamps ? The BCM - body control module controls Automatic lamp control !
Battery voltage is applied to the headlamp bulbs at all times. The headlamps are controlled by supplying the ground for the lamps through the turn/headlamp switch assembly or the body control module (BCM). When the turn/headlamp switch is in the ON position, the ground is supplied through CKT 150.
The BCM controls the daytime running lamps (DRL). The system allows the headlamps to operate at a reduced intensity under the following conditions:
The engine is running.
The transaxle is not in the PARK position.
The normal headlamps are turned OFF.
The BCM activates the system by grounding CKT 592. This action energizes the DRL relay. This condition allows a reduced voltage to flow to the headlamps. When the headlamp switch is turned to ON, the headlamps operate normally.
The parking brake provides an input to the BCM. When the parking brake is engaged, the DRL remain disabled until the parking brake is disengaged.
May 30, 2015 | 1999 Chevrolet Malibu
Why wont the headights or running lights work on my 2002 Buick LaSabre?
There are several reasons why your headlamps an running lights don't work , the headlamp switch is a good one ,plus relays an the DIM - dash integrated module an associated wiring ! Here is how the headlamps work , right out of Buick factory service info !
The dash integration module (DIM) provides battery positive voltage to the signal circuits of the headlamp switch. The signal circuits include the headlamp switch headlamps on signal, the flash to pass switch signal and the high beam input. With the headlamp switch in the ON position, a ground path is available for the headlamp switch headlamps on signal circuit of the DIM through the headlamp switch. The DIM provides ground to either the headlamps high beam relay control circuit or the headlamps low beam relay control circuit of the low beam circuit. The position of the headlamp dimmer switch determines which relay control circuit has ground. The DIM supplies battery positive voltage to the relay control circuits, if the headlamps are necessary. The fuse block - underhood supplies battery positive voltage to both relay switch circuits. When the low beam relay control circuit is energized, current flow is to both low beam fuses and to the low beam headlamps. The headlamps have ground at G103 and at G401. When the headlamp high beam relay control circuit is energized, current flow is to both high beam fuses and to the high beam headlamps. The high beam circuit is divided into a left and right side circuit. The current flow of the left high beam is from the fuse to the left high beam lamp. From the lamp, the current flows to the normally-closed contact of the DRL relay to G103. The current flow of the right high beam is from the fuse to the right high beam lamp. From the lamp, the current flow is to ground at G401. When the headlamp dimmer switch lever is pulled toward the driver, the flash-to-pass switch closes. This grounds the DIM flash to pass switch signal circuit. In response to this input, the DIM energizes the HDLP HI BM relay. Both high beams remain on until the driver releases the switch handle. If the low beam headlamps were on during a flash to pass operation, the low beams remain on. The headlights may be switched to high beam with the opposite movement of the headlamp dimmer switch lever.
By running lights , do you mean park lamps or day time running lamps ?
Park, Tail, License and Marker Lamps
The park lamps, including the license lamps, are turned on when the headlamp switch is placed in the PARK or ON position or anytime the headlights are requested. The fuse block - rear supplies battery positive voltage to the switch contacts of the Park LP relay. When the headlamp switch is in PARK or in ON, the park lamp switch on signal circuit of the DIM has a ground path. The DIM provides battery positive voltage to the control circuit of the Park LP relay. When the park lamps and/or the tail lamps are ON, the DIM energizes the park lamp relay control circuit. This closes the switch contacts. Current flows from the Park LP relay to the LH PARK LP and the RH PARK LP fuses. From the fuse, the current flows to the park lamps. The left park lamps are grounded at G103, G401 and G402. The right park lamps and the right tail lamps are grounded at G103 and G401. The DIMR fuse supplies battery positive voltage to the license lamps and to the DIM instrument panel lamp fuse supply voltage - 1 circuit, for interior lamps dimming. The license lamps are grounded at G401.
The best advice I can give is that you take this to a ASE certified professional repair facility unless your a qualified automotive electric repair person !
Diagnostic Starting Point - Lighting Systems
Begin the system diagnosis with the Diagnostic System Check - Lighting Systems . The Diagnostic System Check will provide the following information:
The identification of the control modules which command the system
The ability of the control modules to communicate through the serial data circuit
The identification of any stored diagnostic trouble codes (DTCs) and their status
The use of the Diagnostic System Check will identify the correct procedure for diagnosing the system and where the procedure is located.
The
Mar 15, 2015 | 2002 Buick LeSabre
Headlights will not shut off after the car has been shut off the only way to shut them off is to disconnect the battery
Your vehicle is equipped with an "Auto Lamp" system. The headlamps will stay on for as long as 3 minutes depending on how you have the control set. If you are certain that this is not the problem and/or your headlamps will not turn off after 3 minutes, perform these checks:
1. CHECK HEADLAMP SWITCH OPERATION
Ensure that the headlamp switch is off. Disconnect the headlamp switch connectors. If the headlamps go foff, replace the headlamp switch. If the headlamps are still on, go to the next step.
2. CHECK CIRCUIT No. 15
Remove autolamp parking lamp relay from the under hood Power Distribution Center (PDC), near the battery. If the headlamps are off, go to the next step. If the headlamps are still on, repair the short to battery voltage in circuit No. 15 (RED/YELLOW wire).
3. CHECK AUTOLAMP RELAY GROUND CIRCUIT
Remove the autolamp parking light relay from the PDC. Measure the resistance between ground (BATTERY NEGATIVE) and terminal No. 2 (DARK BLUE/ORANGE wire) at the autolamp relay wiring harness connector. If resistance is 5 Ohms or less, continue to the next step. If the resistance is more than 5 Ohms, replace the autolamp relay.
4. CHECK THE LIGHT SENSOR AMPLIFIER
Reconnect all components. Disconnect the light sensor amplifier located in the defroster grille on the top of the dash. If the headlamps are off, replace the light sensor amplifier. If the headlamps are on, repair short to ground in circuit No. 218 (WHITE/PURPLE wire) to the headlamp switch.
May 14, 2011 | 1997 Ford Taurus
Changing headlamp, how to..diagram
SECTION 417-01: Exterior Lighting 1999 Explorer/Mountaineer Workshop Manual REMOVAL AND INSTALLATION Procedure revision date: 07/27/1998 Lamp Assembly-Headlamp (Explorer) Removal
  1. NOTE: Make sure that the headlamp switch and the ignition switch are in the OFF position.
    Remove the parking lamp assembly. Refer to Lamp Assembly-Parking (Explorer) or Lamp Assembly-Parking (Mountaineer).
  1. Remove the headlamp assembly.
    1. Compress the self-locking tabs.
    1. Disconnect the electrical connector.
Installation
  1. To install, reverse the removal procedure.
2010&c18=modelyear&c20=n75014&c35=wsm%2clamp%20assembly%u2014headlamp%20%28explorer%29%2csxn%2c417-01%2cremoval%20and%20installation&s=1366x768&c=32&j=1.3&v=y&k=y&bw=995&bh=428&ct=lan&hp=n&[aqe] ddll111_29.gif
Dec 29, 2010 | 1999 Ford Explorer
Can I program the automatic headlights to always shut off when the ignition is shut off - day or night?
I have a 1997 cadillac deville that has both 'daytime running lamps' when put into gear and 'twilight sentinel' which turns the headlamps and parking lamps on at night, and goes off during the day or when it is bright enough.
There is an adjustable delay for the twilight sentinel to turn the headlights off after the ignition key is removed and it is night time.
I had the 'daytime running lamps' installed on a 1990 Cadillac Deville that turns the headlamps only on when the ignition key is switched to on with an aftermarket module. The headlamps are about 70% or so as bright as the regular twiilight sentinel headlamps and parking lights and are designed to go on during the day.
The twilight sentinel overrides this feature when it gets dark outside.
I had the daytime running lamps installed by an auto electric shop that specializes in electrical systems, alarms, stereos, etc.
Does this help?
Jul 10, 2010 | 1998 Buick LeSabre
1994 ford f-150 with day time running lights headlightnot working
The daytime running lamp (DRL) system is designed to turn the high beam headlamps on, with a reduced light output, and without illuminating the high beam indicator lamp in the instrument panel. You have a DRL Module.
The multifunction switch is the stalk on your column.
This is 96 F150 circuit. Don't have 94.
Symptom Chart, Headlamps HEADLAMPS Condition Possible Source Action
  • Headlamps Inoperative
  • Circuitry open/shorted.
  • Damaged headlamp switch.
  • Blown fuse.
  • GO to Pinpoint Test A .
  • Headlamps On Continuously
  • GO to Pinpoint Test B .
  • High Beams or Low Beams Inoperative
  • Damaged multi-function switch.
  • GO to Pinpoint Test C .
  • One High Beam or One Low Beam Headlamp Inoperative
  • Damaged connector.
  • Headlamp bulb damaged.
  • GO to Pinpoint Test D .
  • Flash-to-Pass Inoperative
  • Blown fuse.
  • GO to Pinpoint Test E .
Feb 25, 2009 | 1994 Ford F150 Styleside Supercab
DLX 500 Remote Car Starter Logo
165 people viewed this question
Top Bulldog Security Vehicle Parts & Accessories Experts
Matthew Spark
Matthew Spark
John
John
sonic boom...
sonic boom...
Are you a Bulldog Security Vehicle Part and Accessory Expert? Answer questions, earn points and help others
